Member # 6234
you've got to have more than 4" to start with
![]() i suggest that you go to www.ifsja.org with these questions... you'll just get flamed on this board (hint: check out www.rustysoffroad.com and www.skyjacker.com; call people and ask about suspension lifts)
85 W150, 94 YJ, 86 Bronco Last edited by WillyPete; 12-19-2002 at 08:20 AM. |
Member # 8532
Get a sawzall, cut fenders. Still not satisfied? Move the outboard leaf spring mounts underneath the frame, that should give you more than four inches. Still not satisfied put a four inch lift on it and have eight inches of lift.
WILLYS-Anything Else Is Just An Imitation |
well there are two options first if you go over to rusty's he sells 6" spring lifts... but with a spring lift you are going to get some pretty rough ride and you aren't going to flex too well... the other option is doing a SOA (spring over axle) which will net you about 7 inches of lift. softer ride better flex and if you mess up a spring they are cheaper to replace... but it is going to either take a little welding skill on your part or a little bit of cash to pay someone, I had to pay someone because I don't have a welder.
Also with the rear since its already SOA you will have to gain those 7 inches. You can do what me and many others have done over on the IFSJA.com and do a shackle inversion in the rear using a guy name Todd Grisko's shackle inversion kit for the rear of wag/chero's. This kit will even you out with the SOA in the front. But the best advice I has already been told to you.. GO OVER TO www.IFSJA.org anything you will ever need to know about a Full Size Jeep can be answered there. Good Luck.. check out my signature for a link to pictures of my SOA 83 wag
[URL=http://www.dekonia.com]'83 Wag,[/URL] SOA, 360 [URL=http://www.fsjnetwork.com]Full Size Jeep Network... More Jeep, Less Filling[/URL] [URL=http://www.freeiPods.com/default.aspx?referer=8979853]Get your free iPods or iTunes gift certificate here![/URL] |
#6 (permalink) | |
Member # 144
That's because you're a pinko fascist. - Haole I know what antidisestablishmentarianist means |
Member # 112
This would be a great board to ask that question on. http://www.specialtyparts.com/cgi-bin/yabb/YaBB.pl
This board is a better one for asking if anyone has found a spring that lasts longer after doing what you are wanting to do.
[COLOR=yellow]it's all about show & shine[/COLOR] [COLOR=Lime] Stiffy®? why screw around with anything less? [/COLOR] Charter member PBB mod divorce club for men. |
