4L60E problems - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-10-2012, 07:28 AM   #1 (permalink)
Member # 143016
4L60E problems
I have a 5.3 mated to the 4L60E in my cj,and it only shifts if I let off the gas a little or if I do it manually. Any ideas?
vortec85cj7 is offline   Reply With Quote Quick reply to this message
Old 04-10-2012, 07:40 AM   #2 (permalink)
Newbie
Member # 158798
Check your throttle position sensor
Greg Ducato is offline   Reply With Quote Quick reply to this message
Old 04-10-2012, 07:43 AM   #3 (permalink)
Member # 143016
4L60E problems
What am I checking?
Old 04-10-2012, 08:01 AM   #4 (permalink)
flatblack51's Avatar
Member # 121033
What year is your Trans? Did you just install it? If so its your DRAC module I'm on my phone otherwise I'd post pics. It's a white odd shaped plastic box with a circuit board inside ussually with in a foot or two of your ECM
Thank you to My sponsors:
Pro Comp tires
PRP Seats
Maximum Transmissions
Goatbuilt
Trail Ready Beadlocks
Socal Print Shop
Broadsword Racing
#4889
flatblack51 is offline   Reply With Quote Quick reply to this message
Old 04-10-2012, 08:49 AM   #5 (permalink)
Member # 143016
4L60E problems
Nope u def don't have that. I don't have any empty connectors so how does it plug in?
Old 04-10-2012, 10:18 AM   #6 (permalink)
Member # 121033
You have to have the DRAC module and a VSS for it to shift. It's all electronic it needs the pulse from the VSS and the drac reads that and tell the Trans when to shift
Pro Comp tires
PRP Seats
Goatbuilt
Socal Print Shop
Broadsword Racing
#4889
Old 04-10-2012, 10:20 AM   #7 (permalink)
Member # 121033
Did the motor Trans and harness all come out of the same vehicle?or is the harness a painless or Howell?
Pro Comp tires
PRP Seats
Goatbuilt
Socal Print Shop
Broadsword Racing
#4889
Old 04-10-2012, 10:27 AM   #8 (permalink)
Member # 121033
http://www.tbichips.com/drac/
Pro Comp tires
PRP Seats
Goatbuilt
Socal Print Shop
Broadsword Racing
#4889
Old 04-10-2012, 01:04 PM   #9 (permalink)
Member # 143016
4L60E problems
The motor and trans were purchased separately. The harness and PCM that came with the motor was modified for a 4 wire hookup. Do you have a picture of the drac?
Old 04-10-2012, 01:30 PM   #10 (permalink)
Member # 121033
I'm on my phone. Check the link I posted you need to figure out what year Trans you have and the harness will need to be reworked or get another Trans
Pro Comp tires
PRP Seats
Goatbuilt
Socal Print Shop
Broadsword Racing
#4889
Old 04-10-2012, 01:57 PM   #11 (permalink)
Member # 143016
4L60E problems
The trans is 2002. The motor is 2003
Old 04-10-2012, 06:32 PM   #12 (permalink)
Member # 121033
??? Hmm PM Wayne hartwig I'm surprised he hasn't chimed in on this but check the 5.3 thread and he's all over it he should be able to guide you.
Pro Comp tires
PRP Seats
Goatbuilt
Socal Print Shop
Broadsword Racing
#4889
Old 04-10-2012, 09:26 PM   #13 (permalink)
Member # 143016
4L60E problems
Ok. I forgot to mention that I have a Novak t case adapter and screw in vss
Old 04-10-2012, 09:47 PM   #14 (permalink)
Member # 121033
So you have the VSS I'm wondering what may have changed from the mid 90's to the 2000's as far as the shifting mechinism. I've done research and came up with nothing. Who did your harness? I'd call them and ask
Pro Comp tires
PRP Seats
Goatbuilt
Socal Print Shop
Broadsword Racing
#4889
Old 04-10-2012, 10:41 PM   #15 (permalink)
Bo185's Avatar
Member # 48545
There is not fucking DRAC on a Gen III setup!
If its shifting at all the VSS is most likely good.
'73 Scout II Vortec 6.0L 4L65e np241
'73 1210 Travelette SV392, T-34, 60/14bff 4.56's 35's
'01 VW Beetle TDI-50mpg or better!
Bo185 is offline   Reply With Quote Quick reply to this message
Old 04-10-2012, 10:50 PM   #16 (permalink)
Member # 121033
cool good looking out dick! thanks for clarifying
Pro Comp tires
PRP Seats
Goatbuilt
Socal Print Shop
Broadsword Racing
#4889
Old 04-11-2012, 05:11 PM   #17 (permalink)
Member # 143016
4L60E problems
I have another symptom; if you let off the gas going 20mph or more, the jeep basically coasts until u apply throttle then it catches the gear again
