Navman's YJ 5.0 - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-12-2012, 02:29 AM   #26 (permalink)
Newbie
Hoose's Avatar
Member # 179197
Good looking build. I like it.
2003 ford F-350 srw ex cab long bed 4x4 7.3L
98 TJ with some stuff
2012 KOH Modified 4555
Get your Atlas support rings here
www.roarkfabrication.com or call 606-286-0681
Hoose is offline   Reply With Quote
Old 06-12-2012, 09:55 AM   #27 (permalink)
tjjared413's Avatar
Member # 46942
looking good!
04tj with round tires
04 d-max tow rig
tjjared413 is offline   Reply With Quote
Old 06-18-2012, 08:57 PM   #28 (permalink)
navman's Avatar
Member # 123845
Got some more work done this past weekend. Kenny finished welding up the upper link mounts. Some of its tig and some mig. Dave stopped by and pitched in by grinding off some of the old leaf mounts and prep for welding
navman is offline   Reply With Quote
Old 06-19-2012, 05:47 AM   #29 (permalink)
Member # 74881
Thank god I showed up late, you wouldn't have gotten anything done had I gotten there earlier. Looking good Mark, giddy up!
mika360 is offline   Reply With Quote
Old 07-04-2012, 03:08 AM   #30 (permalink)
navman's Avatar
Member # 123845
I finally got some more work done on this. Got the front cage mounts fabbed up. Kenny welded them all up. I spent a lot of time getting everything measured up and it came out dead on.
Old 07-04-2012, 03:10 AM   #31 (permalink)
navman's Avatar
Member # 123845
more
Old 07-08-2012, 10:00 PM   #32 (permalink)
navman's Avatar
Member # 123845
Got some more done on the rear link setup this weekend. Had a couple pieces of 1/4" bent up for the lower axle mounts. I drilled and cut them accordingly then tacked them to the axle. Kenny finish welded the upper link mounts in place.
Old 07-08-2012, 10:51 PM   #33 (permalink)
Diablo169's Avatar
Member # 63382
Send a message via AIM to Diablo169
Clever way of mounting your cage. Keep it coming!
--- 80 Proof --- TJ Juggy Build
"14 Bolt don't give a shit. It takes what it wants."
-Little Sluice Memorial Weekend 2012
Diablo169 is offline   Reply With Quote
Old 07-09-2012, 02:28 PM   #34 (permalink)
navman's Avatar
Member # 123845
Some jackstand flexin
full bump (5"+)
full droop (11")
ride height
Old 07-16-2012, 03:41 PM   #35 (permalink)
navman's Avatar
Member # 123845
Got some more cage work done over the weekend.
Old 07-17-2012, 08:43 PM   #36 (permalink)
navman's Avatar
Member # 123845
Got the dash pad removed and the lower windshield bar cut. Also started on the seat support setup.
Old 07-22-2012, 08:56 PM   #37 (permalink)
navman's Avatar
Member # 123845
Finally figured out my rear frame section and got the saw out. Took longer to resupport the jeep than it did to cut the damn frame.
Old 07-24-2012, 11:44 AM   #38 (permalink)
and Scooby
BenE's Avatar
Member # 80653
good build so far, keep it up
She’s got a silk dress, and healthy breasts, that bounce, on his, Ital-ian lea-ther so-fa.
My Junk here
BenE is offline   Reply With Quote
Old 07-24-2012, 05:07 PM   #39 (permalink)
Member # 127171
What's going on with the tub? Good lookin build, it's just missing in one pic, and catch a glimpse of it in another.
"You never really know a woman until you meet her in court!"
sleepsontoilet is offline   Reply With Quote
Old 07-24-2012, 08:17 PM   #40 (permalink)
navman's Avatar
Member # 123845
The red tube is the original beatass tub that I'm using to mock up stuff. I've chopped it up quite a bit for clearance and measuring etc. The blue one you see on the first page is getting boatsides and an aluminum rear dovetail section. Thanks for the comments guys
Old 07-24-2012, 10:05 PM   #41 (permalink)
Gravy's Avatar
Member # 105716
doesn't look like much vertical seperation at the rear on the axle side
00TJ 35sp60s 106wb
Fabing & Wheeling is about having fun. If not: You're doing it wrong
Gravy is offline   Reply With Quote
Old 07-25-2012, 04:35 AM   #42 (permalink)
navman's Avatar
Member # 123845
It's kind of hard to see in those pics, but there is 9" of seperation between the uppers and lowers. I used a tall truss for this reason.
Old 07-25-2012, 12:51 PM   #43 (permalink)
Twisty's Avatar
Member # 97798
Hey Mark, did you weld the tubes to the pumpkin on the 8.8?
As always, looking good, and top notch fab. Hope you make FC before Sunday morning, this year!!
88 MJ buggy - D60/14b, 3&4 link, air shocks, 203/205, 5.38s, full hydro
newenglandjeepz.org
Twisty is offline   Reply With Quote
Old 07-25-2012, 08:15 PM   #44 (permalink)
navman's Avatar
Member # 123845
Yes Tim, I did that back when I did the original 8.8 swap. Daves bender and notcher definately made this possible. Thanks and yes before sunday morning!!!
Old 07-30-2012, 11:59 PM   #45 (permalink)
navman's Avatar
Member # 123845
Got a bunch more done, finally starting to see the end. Sorta
The axle truss and lower link mounts are all welded in the shock tabs are done.
Old 07-31-2012, 12:00 AM   #46 (permalink)
navman's Avatar
Member # 123845
next got the ORI's mocked in place
Old 07-31-2012, 12:02 AM   #47 (permalink)
navman's Avatar
Member # 123845
and finally Kenny got the rear frame welded in
Old 08-01-2012, 02:19 PM   #48 (permalink)
celticcross's Avatar
Member # 118461
Very cool build. Love the way you tied the cage in.
celticcross is offline   Reply With Quote
Old 08-04-2012, 10:49 PM   #49 (permalink)
navman's Avatar
Member # 123845
Got all the remaining rear brackets designed and cut out. Gave the swag bandsaw a workout today.
Old 08-09-2012, 08:12 PM   #50 (permalink)
navman's Avatar
Member # 123845
Kenny stopped over today and got the rear suspension upper mounts all welded up. Pictures say it all on his work.
