Aftermarket inner C ? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-14-2012, 07:30 PM   #1 (permalink)
Member # 191552
I have a Dana super 60 with 4 inch tubes and am looking for some inner C's that can be bored to 4 inch with not taking to much material away from the inner C's and making them weak! Are there any on the market or am I screwed?
JMDCUSTOMZJ is offline   Reply With Quote
Old 05-15-2012, 09:12 AM   #2 (permalink)
Low Range Drifter
JohnnyJ's Avatar
Member # 7903
You could call Reid or Crane and ask.
How thick are the tubes? If the id of your tubes is 3.5, you could buy 3.5" knuckles from Reid, and mount them on some 3.5 od tube with say 6 extra inches of stickout. Then you could slide that tube inside your axle tube and rosette weld it and weld the knuckles to the 3.5 od tube and your 4" tube.
DEAK Racing #715 TREC B / Ultra 4 Mod Class Rig
Thanks to Drivetrain Specialists and PAC Racing Springs for your support
JohnnyJ is offline   Reply With Quote
Old 05-17-2012, 12:48 PM   #3 (permalink)
Member # 47730
overson is making some new ones that will work and eorp has some billet ones in the works also.
a bunch of tube.a v8 and other stuff..
2nuts4u is offline   Reply With Quote
