Member # 127171
95 yj
Never thought much about starting a build thread here, but was asked where mine was, so here's my attempt at building a beater. Forgive the timeline, as it's copied and pasted from another forum.
Specs: 95 YJ backhalved Chevy 60 KP 5.38's, yukon spool, yukon inner/outer w/spicer joints, 35 spline inner/outer w/spicer joints as spares, RPM offroad Fat Girl flanges 14 bolt 5.38's Detroit TMR shave with artec truss waggy fronts, 16" fox airshock rear, 4 link rear ruffstuff 7/8 heims with 1.75" .25 wall uppers, ruffstuff 1.25 heims with 2" .25 lowers LQ4/FRMVB350/205 39.5x13.50/16.5 iroks on 12 bolt H1's Hopefully I won't need a winch... Here's what she looked like they day I drug her home. Sold the Dodge 60 front as it was a cad housing and too much work to do it as simple as I'm going for. Sold the rear 70HD as it was just too dang big. Hope to go full bore by the first of the year. ![]() All my friends drive low riders ![]() ![]() ![]() Got her some Christmas goodies
"You never really know a woman until you meet her in court!" |
Member # 127171
We made the cut line using jacks and a bucket of oil. Then applied a little sawzall action. Went to boot the diff cover on to make the cut line, and the problems started. The newer model AAM 14 bolts use a metric thread diff cover bolt that ruffstuff was unaware of. We called everyone, and googled with all our might to find zero info on the bolts size. Finally found a dealer who knew and grabbed a box of 100 from fastenal, can't buy just a few anymore.
Dave Gutwillig burning it in for me ![]() ![]() First stage of mockup. Shooting for the 110-112 wb. This is around 111 ![]() ![]() showing diff clearance on 42's, right at 14 3/4" with 30 psi in them. ![]()
Member # 127171
![]() Picked up a MAST performance oil pan. Should fix any clearance issues. ![]() Has improved baffling built in. Should keep it from losing any oil pressure. ![]() Got the 205 put back together, and bolted everything together. going to try it at 18* first, the other holes were clocked a little too far. Ready to be dropped in. Gonna have to find something different for exhaust, header tubes run directly in front of the spark plugs.
Member # 127171
A $560 box from Liquid Iron Industries
![]() Ruffstuff goodies came in today. 2" .250 wall dom for crossmember mounts seat belt mounts 3/4" weld washers ![]() And another box with psc goodies ![]() Got the harness back, and mostly installed. ![]() A little Ron Davis goody ![]()
Member # 127171
Picked up something for the jeep
![]() ![]() Bought something a long time overdue. I capped one of the frame rails today, and kept having to turn down the heat. Gonna be nice not chipping flux anymore. ![]() I've been absolutely racking my brain on how to backhalf this stupid thing. Whether to run a U, or boxed off like an Ultra4. I can't beilieve it, but I actually got the measurements and angles right and it fit perfect. I'm happy with how it turned out. Now to decide the down bars. Not sure if I should bring them down like the pic, or put a 25-30* bend at the top? What say ye? ![]()
Member # 127171
What say ye? I wound up with about a 50* bend to make it level on top and flow with the other tube. I kinda like it this way. Gonna work on the other one tomorrow.
![]() ![]() ![]() Started on the seat cradle, and am very happy so far. Problem is the front tube. I have to wait until the 205 is under it and see if the floor needs cut to fit, and exactly where it will sit in relation to the tubes path. I may get lucky, and it actually cross the adapter which has a good gap. Anyone see another way to run the forward cross tube without losing too much headroom? ![]() ![]() Added the harness bar, and other down tube. Starting to look like a jeep again...
Member # 127171
Nailed it, I'm getting stoked with every tube. I used a little 5 lb sledge and massaged the floor a pinch. Seats feel comfortable where they are.
![]() No major progress, but I decided to try my hand at fabbing up my own seat mounts. 2" .188 strip. Just gotta drill a hole and burn them in. ![]() I got the lower backhalf complete, and Artec cell mount welded in solid. Did the two bars of lacing behind the seat, still have to do the outer two and the bars below where they tie in. That way it isn't a dead node. Thinking of trying to find a way to tie that bar into the frame as another structural tie in. Opinions welcome ![]()
Member # 127171
Added the outer bars. Now I need to figure out the lower portion, and start tying it into the frame.
![]() ![]() ![]() Didn't like the visibility being blocked by the poly performance kits dash bar, so I cut it out and threw it in the scrap pile. Since I can't really reuse the stock yj gauges, and the wiring harness was cut to pieces, I went ahead and scrapped it as well. Gonna try my hand at a simple flat dash. Added some console bars while I was at it, to mount the Art Carr shifter to. Got the bars from A pillar to the firewall tacked on as well. Then I pulled the cage to finish welding the underside. I need some suggestions on the door bars. I really like the stock modified setups I've been seeing. Also like the simple bent hip bars. Just not sure which route to go. Todays progress: ![]() ![]()
and Scooby
Great job Sleeps.
Is that where you are now, or is it already done? I like how you just throw an engine in the back of your carpeted suburban. I never noticed you were from Humble (pronounced with a silent “H”). My wife and I both went to high school there (a long time ago LOL).
She’s got a silk dress, and healthy breasts, that bounce, on his, Ital-ian lea-ther so-fa. My Junk here |
#12 (permalink) | |
Member # 127171
Couldn't justify 1k for a YJ bolt in radiator, so I have to make a hoop for that, and it will tie in through the firewall to the A pillar. The tub is sitting on the frame, so I'll have to massage it to make my artec 4 link brackets work. The body mounts are shot, that has to be addressed as well. Been looking at boatsides hard mounted to the tub, welded to the frame as a fix. There's a light at the end of the tunnel finally. I bought it in the fall, but have just started building. Been just collecting parts so far. Sue Ellen gets used hard. It actually has husky liners front to back. I've had 3 sets of tons, 42's, 39.5's, 6.0/350, 2.5/AX-15, etc all back there this year. I don't think anything about laying the seats down and hauling what I need. Someday I'll buy a trailer, haha.
#13 (permalink) |
and Scooby
Sounds to me like you got one.
![]() Finish that monster up and head on up, we should hit Clayton together, always a good time.
#14 (permalink) |
Member # 31410
What size were the 14 Bolt diff cover bolts? I may end up with the same problem, I have a late model 14 Bolt too. I haven't had a chance to look at it much yet, I'm finishing my front 60 before I tear in the rear end.
#18 (permalink) | |
Member # 127171
Thanks for the compliments, I wasn't expecting much attention in this section. Far as racing, maybe someday. I'm still learning to wheel and build, and a race rig takes a bigger budget. A lot of it is going to be done to race standards, such as the fuel system so if I do, I'm not paying for it twice.
"You never really know a woman until you meet her in court!" Last edited by sleepsontoilet; 07-03-2012 at 08:17 PM. |
#19 (permalink) |
GM at TWF
This is the worst thread title for a build ever.
ANDY<--- ME! TrailWorthyFab.com<--- THE BEST DOUBLE BEAD LOCKS! Project: Dookey's revenge<--- My Junk! OFF ROAD GEAR<--COOL SWAG! |
#20 (permalink) |
Member # 127171
Should I have put "Competing with Dookey for the slowest build on pirate, oh yeah, it's a 95 YJ Backhalved on tons"?
#21 (permalink) | |
GM at TWF
![]() I was just subscribing to your thread to keep dibs on the process.
#22 (permalink) | |
Member # 127171
2.5/Ax-5/231/300 cad 60/70HD on XJ's 2.5/AX-15/231/300 cad 60/70HD on XJ's 2.5/AX-15/300 4:1 cad 60/14 on XJ's 2.5/AX-15/300 4:1 chebby 60/14 waggy front/XJ rear 6.0/350/205 60/14 waggy front 4 link rear on air shocks I stripped the casting bolts on the 60. Gonna try helicoil first, but she may wind up with another artec truss and some links if she don't act right.
#25 (permalink) |
Member # 127171
No need to buy, I should be able to throw them in an envelope with a stamp. Just let me know if you need them.
