Dana 60 spacer ? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-07-2012, 08:14 PM   #1 (permalink)
Dudewayne's Avatar
Member # 125011
Arrow Dana 60 spacer ?
Got no response on non-hard core so here goes.....
I put a 1" high steer arm on my 60 front and want to use the original cap on top of the knuckle.
What are you using for a homebrew spacer between the top bushing(plastic) and the spring before putting the cap back on ?
Possible to use just fender washers or a piece of 1" solid round stock to take up the 1" space ?
I've searched but only found the spacers you can buy or get rid of the springs kits.
The rig is trailered and never hits pavement all junkyard parts.
Thanks, Duane
'95 YJ SOA Dana 60 front, Dana 60 rear Chevy 305/350 205 44s 105"WB Full Hydr,Shackle Reversal
Dudewayne is offline   Reply With Quote Quick reply to this message
Old 08-07-2012, 08:18 PM   #2 (permalink)
Member # 127171
Picture?
Most either have a big hole and go over the cap, or eliminate it all together. What brand are you talking about?
sleepsontoilet is offline   Reply With Quote Quick reply to this message
Old 08-07-2012, 08:26 PM   #3 (permalink)
Dudewayne's Avatar
Member # 125011
yeah, no cap, bought just the arm off a guy here, supposed to be a Crane brand arm, but no markings.... trying to piece it together. It's a keyed arm, so I keyed the knuckle at my buddy's machine shop, and putting it all back together.
I've seen the kits to delete the springs but don't really want to buy anything else.....Top of the arm is OPEN leaving the spring to hang out unless covered by the cap
pretty much like this..... http://www.polyperformance.com/shop/...rm-p-1200.html
and they want $35 for a cap..........F that
Old 08-07-2012, 11:45 PM   #4 (permalink)
AgitatedPancake's Avatar
Member # 42341
Yeah, all you need to do is cut 1" out of the cap and reweld it back together. I built a 1 ton ZJ, and the owner wanted me to weld the high steer arms on. The only way I could do so and still make everything serviceable was to cut and reweld the caps. I'd guess this is about exactly what you're looking to do.
The right knuckle is how the arms are meant to fit. The left arm has a cap that I modified to maintain factory pressure, while being bolted from the top instead of underneath.
Dovenosed 5 speed WJ on 9"s
AgitatedPancake is offline   Reply With Quote Quick reply to this message
Old 08-08-2012, 04:19 AM   #5 (permalink)
Dudewayne's Avatar
Member # 125011
trkklr77 and AgitatedPancake, Thanks for the help and the pics. Cutting the cap today.
