2nd gas tank / anti theft idea - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-26-2003, 01:36 PM   #1 (permalink)
Member # 12878
Send a message via AIM to Taso Stambolis
how would I add a small gas tank to a jeep? I've had a idea for this anti theft method for a long time now but never looked into how to do it. The plan would be to have a small tank that is filled by maybe an overflow of fuel when you fill up your normal tank. The tank would be small enough that the perp would go a few blocks and then have the jeep run out of gas on him.
Taso Stambolis is offline   Reply With Quote
Old 02-26-2003, 01:42 PM   #2 (permalink)
HybridPOS's Avatar
Member # 14442
Send a message via Yahoo to HybridPOS
Take your coil wire in with you at night.....
83 CJ-7, 360 .030 over, shaved heads on the pane.
105 inches of noise and booger welds.
HybridPOS is offline   Reply With Quote
Old 02-26-2003, 03:00 PM   #3 (permalink)
Member # 2485
Send a message via Yahoo to RCKRATZ
If that's what you want to do, why don't you just put your fuel pump on a hidden switch somewhere?
Keith Ratzburg aka "El Rolo"
Friends of Fordyce-Director
RCKRATZ is offline   Reply With Quote
Old 02-26-2003, 03:17 PM   #4 (permalink)
Member # 14004
I think Jacob's ignition has a feature like that. When armed, it will start and drive about 30 seconds, then die. Nothing like blocking traffic to attract attention...
82 CJ7 - TBI 304/T18a/D300/44/70/4.88/40's
87 Samurai - GSX carbs/16V 1.6/GRS-II/linked rear/31's
Kreep is offline   Reply With Quote
Old 02-26-2003, 03:49 PM   #5 (permalink)
Jackstand Wheeler
4Bangler's Avatar
Member # 12152
Simply install an SM420 with a tempermental 2nd gear and leave the rig parked in 4-low, if the screaming engine bouncing off the rev-limiter in 1st doesn't detract them, grinding and jumping out of 2nd will, and stalling in 3rd will send them packing, hell, if you make your Jeep run and look like total shit on top of that, the perp might even leave you a few bucks on the seat.
'46 CJ-2A, '47 CJ-2A, '48 CJ-2A, '50 M38, '52 M38A1, '62 CJ-3B, '62 CJ-5, '65 CJ-5, (2) '66 CJ-5's, '67 CJ-5, '69 CJ-5, '69 J-3000, '70 CJ-101, '74 DJ-5, '74 CJ-5, '77 CJ-5, '78 CJ-5, '78 CJ-7, '78 Wagoneer, '95 YJ, '97 XJ...None of them run.
4Bangler is offline   Reply With Quote
Old 02-27-2003, 03:22 PM   #6 (permalink)
Member # 849
That will stop the thief for about 30 seconds while they take one of your spark plug wires and use it to replace your coil wire...
Damn thieves
Dan
84 CJ-7 with some stuff
47 CJ-2a without stuff
[URL="http://www.n2jeepn.com"]http://www.n2jeepn.com[/URL]
Dan84CJ7 is offline   Reply With Quote
Old 02-27-2003, 03:35 PM   #7 (permalink)
Jackstand Wheeler
4Bangler's Avatar
Member # 12152
Not on a 4cyl...
put pu put put pu pu put put put....
Old 02-27-2003, 06:18 PM   #8 (permalink)
Mr.N's Avatar
Member # 1635
At least 80% of that sounds like the voice of experience
Proud Catholic | My Dana Articles and Info -> http://77cj.littlekeylime.com/web_rs44.html
Mr.N is offline   Reply With Quote
Old 02-27-2003, 09:03 PM   #9 (permalink)
Member # 15724
Send a message via AIM to GoatFish
I need to do something with my YJ soon. I got my ZJ stolen at school in November, got it back a week later it looked like someone took it to a demolition derby and let it rip. Anyways, it will be just about that time of year again to pull the YJ out, and I will be driving that to college now and then and I would like to keep it were I parked it this time. So has anyone weird a fuel pump cut off switch? Basically, what is the best way to do it?
its all about the sawzal
GoatFish is offline   Reply With Quote
Old 02-28-2003, 08:03 AM   #10 (permalink)
Member # 7711
There should be a relay for the fuel pump. Wire it to the switched side of the relay. That way there is no problem with current. Just hide the switch under the dash someplace you can feel or can not see. Some people use a magnetic switch. You swipe a magnet across part of your dash to trip the switch. Just don't lose the magnet =).
Ben
Sunset the unconstitutional USA Patriot Act!!
Serious discussion makes Bubba sad -BRB
MNBen is offline   Reply With Quote
Old 02-28-2003, 12:16 PM   #11 (permalink)
El Guapo
TexasBlake's Avatar
Member # 9722
take your rotor off.
I want to know if there's some way to make a fuel pump switch, but have a code for it. Are there any electrical locks similar to those that are on bicycle locks, with the sliding nmbers? Or what about a combination of 3-5 switches under the dash that must be swithced on off in the right combination? Anyone understand what I'm getting at here?
TexasBlake is offline   Reply With Quote
Old 02-28-2003, 12:28 PM   #12 (permalink)
Blame Canada's Avatar
Member # 5176
You're making it more complicated than it seems. And by adding more to the system, you just inventing more to go wrong/break down.
Remember the KISS rule: Kiss My Ass.
Or, Keep It Simple Stupid.
My $0.02
I keep my post count low by posting in chit-chat.
STOLEN!!! -->'80 CJ-7 w/ 258 I-6,T-176,D300, '94 YJ tub, '83 toy axles front & rear, Smirffield front axles, w/3.90's, 'YJ rears up front, and a bunch of home-grown patches, all sitting on BFG 35" MTs.
Post #411
Blame Canada is offline   Reply With Quote
Old 02-28-2003, 01:41 PM   #13 (permalink)
rockmup's Avatar
Member # 16699
Why not just use an ignition master switch? Hide it somewhere and just flip it when you need to.
I spliced into the neutral safety switch in my jeep (automatic) and it will never go anywhere I don't want it too. The same could be done with an ignition
07/C2 SOT
/Making guns and fun toys, one hammer swing at a time
Need quality ammo ?
AMERICAN LEAD DISTRIBUTORS
Need a POV system ? REPLAY XD
rockmup is offline   Reply With Quote
