Member # 6777
CJ-10a Buildup Questions
I have been putting a lot of thought into what the basis for my next project would be and today I found a CJ-10a. I have searched here and on the net but I have found little info on them. I like that they are different from the more common Jeeps and I kind of like the look. I was thinking of buying it and putting the cab, fenders, front clip, and hood on another Jeep frame and adding a pickup style bed similar in style to the Willys pickup or the FC-150.
I have found different sources of info concerning the frame. Some say it is a shortened FSJ frame and others say it is not. Does anyone know the truth for sure? I would want to set the body on a new frame from another Jeep but I want to know which one is the correct one before I get too deep into it. If you have any good CJ-10a links please share them. Thanks.
74 CJ-6 304/TF999/D300/D30/D44 - Beach Jeep - build in progress. |
Doublewide engineer
Member # 6971
I'm the "tack tack tack" welding nazi. http://www.pirate4x4.com/forum/showp...&postcount=218 ![]() "I didn't mean to kill nobody ... I just meant to shoot the sonofabitch in the head. Him dying was between him and the Lord." R. L. Burnside |
Member # 12801
Here is another pic
Didnt think you guys have these in the states ?? I thought they were an australia and Canada only Jeep The one in the pic has a EFI 360 NV4500 dana 70 and dana 44 front |
Doublewide engineer
Member # 6971
I've seen a few of em converted by the airforce for use as plane tugs. Texas A&M fireschool has a couple running around on campus. Chris Duram started competing in his CJ10 that started as a plane tug if I remember right. They are out there, just not as easy to find here as they are in other countries.
#6 (permalink) | |
Member # 6777
I have not bought it yet as I am waiting to find out about another deal with some D60's. |
#7 (permalink) | |
Member # 6777
Member # 11874
That thing is cool as shit; what's it have for stock drivetrain? I've seen lots of pics of Duram's rig but always thought the front clip was custom - I never knew they made this model.
![]() Cool project, keep us posted.
Toyotas are cool. |
#9 (permalink) | |
Member # 556
'86 CJ-7 Laredo: recent 'restification' '83 Scrambler: under construction |
Member # 4658
These are a few links i have bookmarked on cj-10's. Hope they help.
http://autos.groups.yahoo.com/group/CJ-10List/ http://www.4x4mag.co.uk/junefeatures/magjeepcj.htm Tim
* [URL=http://www.tim-morris.com/74JEEP/index.html]1974 CJ-6[/URL] |
#11 (permalink) | |
Be yourself, by yourself. |
#12 (permalink) | |
Member # 11057
I would think it'd be easier to just use the existing transfer-case and block that range-fork into one position. If that's the case, then making it 4wd would be as easy as adding a front differential, unblocking the range fork and adding the linkage and the lever. Anyone have pics of the inside of a CJ-10a transfer-case? |
#13 (permalink) |
Member # 1792
I have only seen one in person!That was the other day!I think the guy is just starting to build it.Not sure if it was an Airforce one or not.Cheepin
CJJuggy.FI406/465/205/D60/14bolt FF on 39.5 Swampers.Kids 70Jeepster fullwidth on 34/9.50 swampers. |
#14 (permalink) | |
#15 (permalink) |
Member # 11057
That's good to know. A regular AM208 should bolt right to that TF727 tranny, though, giving 4wd (well, with the addition of a driver's-drop front axle; SOA with a full-width Ford high-pinion D60 would go well with that extra-wide D70 out back).
#16 (permalink) | |
Member # 6777
My goal is to build a low buck hardcore rig that is not typical of what everyone else is doing. Right now I am in the planning and parts collection stage. I will start building when my YJ sells and I get a good daily driver (4cyl YJ or MJ). |
#17 (permalink) |
Member # 6777
Anyone know anything about the frame on the 10A? Is it a CJ frame or FSJ frame? I have found multiple sources of frame info but they do not agree on it. I am hoping it is a FSJ frame and then I will buy the 2 door 79 Cherokee down the street and plop the 10a cab on it with little or no mods. Then I will change the TC to a 208, throw the axles under it, then start the fine stuff.
I tried to get on the Yahoo CJ-10 group but I haven't heard back from them. |
#19 (permalink) | |
Member # 6777
#21 (permalink) |
Member # 6777
I found out that the physical frame rail is the same as the FSJ frame but the body mounts are unique to the 10a. If I pull this off I would probably do the offset rear spring thing on the stock frame. I was hoping for ample DS length in the rear so I could keep the stock tranny and not eat u-joints.
I wonder if a CUCV 6.2 would fit under the hood.
#22 (permalink) | |
B-RAD Fabrication TDO DYSFUNCTIONAL ROCKCRAWLERS |
#23 (permalink) |
Member # 6777
I'm still trying to find a correct answer on that one. I may drive up to measure the stuff on the one I am after in a couple weeks and then decide if it is feasable or not. Looks like the GM D60 front will be a bolt in SOA as the perch width is the same as a FSJ and FSJ front axles supposedly are a direct swap. I am just worried about the 14bolt rear fitting in ( I realize I may have to move the perches - no big deal) and having adequate DS length without frame mods. I want to build a decent HD trail rig using as many common existing parts as possible and have it come out super cheap and strong.
I have seen a CJ-5 with a 454 under the hood so I know it is dimentionally possible to stuff a 6.2 in there, I just wondered if anyone had done it and if it would be worth it. 6.2's are cheap and plentiful, plus I could steal the whole drivetrain from a CUCV. As an alternative I am keeping my eyes open for a 4BT cummins as I thing I remember them being used with GM trannies in bread trucks. Anyone care to fill me in on that? |
