TJ 1 Tons "Learn as I go" project - Page 4 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-30-2013, 04:46 PM   #76 (permalink)
esniper's Avatar
Member # 165927
My chop saw couldn't hold the tabs well enough so I broke out the plasma. Here is my make shift table clamped to my trailer.
My Website
My Build Thread http://tinyurl.com/l3w3xgp
esniper is offline   Reply With Quote Quick reply to this message
Old 05-30-2013, 04:48 PM   #77 (permalink)
esniper's Avatar
Member # 165927
After the rough cuts with the plasma I needed to make all the upper tabs relatively close to the same. Since I am in a rental house at the moment I don't have all the tools I would like to have so a vice and a grinder works.
My Website
Old 05-31-2013, 12:01 AM   #78 (permalink)
oregon_mudrunner's Avatar
Member # 99077
Looking good so far, I'm the guy who bought your Mtrs and trailreadys. Where did you get the 5x4.5 to 8x6.5 adapters?
oregon_mudrunner is offline   Reply With Quote Quick reply to this message
Old 05-31-2013, 12:49 AM   #79 (permalink)
esniper's Avatar
Member # 165927
Hey dude! I hope you are putting them to good use. I got them off Amazon if you can believe that!
This was a reply to Oregon_Mudrunner who bought my old TR bead locks and 37" Goodyear MTR's. - Not sure where the original post went but oh well.
My Website
Old 05-31-2013, 12:52 AM   #80 (permalink)
esniper's Avatar
Member # 165927
Here is the link:
Wheel Adapter 5 Lug 4.5" to 8 Lug 6.5" - Pair : Amazon.com : Automotive
My Website
Old 05-31-2013, 09:58 AM   #81 (permalink)
Member # 99077
Yeah they have been working out good, love the Mtrs in the snow. Thanks for the link, but it looks like there out of stock for now.
Old 06-04-2013, 11:38 PM   #82 (permalink)
esniper's Avatar
Member # 165927
I made some more progress.
Tacked in the truss, lower links axle and frame side.
My lower links are @ 41.5" and my uppers are at 29.05".
The driveline is really close to the lower link bar. I haven't articulated it yet to see if there is any chance of impact. It is about an 1.5" from the link. I was thinking I need to lower the lower brackets on the axle side maybe. <- Thoughts from anyone who has done this before?
Any other advice is welcome also. Anything in these pictures look sketchy to anyone????
My Website
Old 06-04-2013, 11:40 PM   #83 (permalink)
esniper's Avatar
Member # 165927
Hey, don't mess with Hello Kitty. <- Kids duct tape. That pussy is bad news!
My Website
Old 06-04-2013, 11:42 PM   #84 (permalink)
esniper's Avatar
Member # 165927
My Website
Old 06-05-2013, 12:19 AM   #85 (permalink)
esniper's Avatar
Member # 165927
My stretch puts my wheel base @ 101". I plan on stretching the rear again about 10" so overall will be about 111".
My Website
Old 06-05-2013, 04:48 PM   #86 (permalink)
esniper's Avatar
Member # 165927
I am going to go ahead and drop the lower link brackets at the axle down to the eye whole even with the lower half of the axle tube. This will give me my 10" or 25% vertical separation and give more space for the driveline.
My Website
Old 06-05-2013, 11:37 PM   #87 (permalink)
esniper's Avatar
Member # 165927
Got the link brackets dropped down to where I am @ 10" of vert seperation. This also created more space for the drive line.
My Website
Old 06-05-2013, 11:41 PM   #88 (permalink)
esniper's Avatar
Member # 165927
Pictures for personal friends to reference. Here you go Glenn:
My Website
Old 06-05-2013, 11:44 PM   #89 (permalink)
esniper's Avatar
Member # 165927
Took the truss off and welded it up. Waiting to put it on till I get my vent fitting and the lower link brackets welded on all the way. They are tacked in place now.
My Website
Old 06-07-2013, 10:09 PM   #90 (permalink)
Member # 189986
It looks like your lower link mounts will hang up alot. I would do the skid so they are flush, not hanging down. Or maybe go straight with the uppers to the frame.
jeff76 is offline   Reply With Quote Quick reply to this message
Old 06-07-2013, 10:35 PM   #91 (permalink)
esniper's Avatar
Member # 165927
I doubt it I will ever hang up on these brackets. They will be so close to the 40" tire that an extra 1.5" of bracket hanging at a drop approach angle shouldn't hang up.
My Website
Old 06-08-2013, 09:21 PM   #92 (permalink)
Member # 189986
There is a reason most people shoot for a flat skid. They also shave diffs to gain 1-2". Good luck with the build
Old 06-08-2013, 10:45 PM   #93 (permalink)
Member # 127171
People destroy calipers in the rocks, and you don't feel that brackets too low? I'm with Jeff, I can't see your lowers fairing well at all.
sleepsontoilet is offline   Reply With Quote Quick reply to this message
Old 06-08-2013, 11:14 PM   #94 (permalink)
esniper's Avatar
Member # 165927
Well before welding them in I called Artec and Ruff Stuff and both of those businesses recommended doing it this way. At any rate I am not worried about it. Thanks for the advice.
My Website
Old 06-08-2013, 11:17 PM   #95 (permalink)
esniper's Avatar
Member # 165927
Tonight I got the truss welded and lower brackets welded in. I hit it with some paint except for my upper link location. I still need to slide it back under the rig and get the angles set and tack them in for testing.
My Website
Old 06-08-2013, 11:17 PM   #96 (permalink)
esniper's Avatar
Member # 165927
My Website
Old 06-08-2013, 11:17 PM   #97 (permalink)
esniper's Avatar
Member # 165927
My Website
Old 06-11-2013, 11:30 PM   #98 (permalink)
esniper's Avatar
Member # 165927
I am trying to figure out where I want to cut my lower links. I have been doing some research on thread depth for my rod ends. According to one article in the link below I will need to thread my rods 1.5 x's the rod diameter.
I have pretty well made rod ends so I could go 1 x's the diameter @ 1 1/4. I think I will call the manufacture "Artec" and see what they recommend.
EMF Rod End FAQ
My Website
Old 06-12-2013, 06:49 AM   #99 (permalink)
Member # 1636
Thread the lowers in all the way. leave them in while you weld the inserts into the tube and do not try to remove them until the tube is cool to the touch, or they will not thread back in without re-tapping the inserts.
chris demartini is offline   Reply With Quote Quick reply to this message
Old 06-12-2013, 07:41 AM   #100 (permalink)
Coma1's Avatar
Member # 41600
Is there a reason you're not welding in the corners of the lower axle link capture? Maybe just not done it yet?
Coma1 is offline   Reply With Quote Quick reply to this message
