232 vs. 258 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-14-2003, 09:33 AM   #1 (permalink)
Member # 773
232 vs. 258
What are the differences visually between a 232 and a 258? Are there different casting numbers?
Joe
miscellaneous debris on four tires AKA Jeep
Rokmycj is offline   Reply With Quote
Old 04-14-2003, 10:29 AM   #2 (permalink)
El Guapo
TexasBlake's Avatar
Member # 9722
the easiest way would probably be to look at the intake/carb. THe 232 is 1bbl and the 258 is 2bbl except for the really early ones in SJs.
Do you know what year and vehicle it's out of?
TexasBlake is offline   Reply With Quote
Old 04-14-2003, 11:16 AM   #3 (permalink)
Member # 773
it is out of a 74 cj5. That is why I am curious. It's old
Joe
Old 04-14-2003, 11:59 AM   #4 (permalink)
El Guapo
TexasBlake's Avatar
Member # 9722
then it would be 232
Old 04-14-2003, 04:08 PM   #5 (permalink)
Member # 9574
'74 came with both types of I-6's, both were 1-bbl.
Look on the machined pad right where the head and the block meet on the passenger side. There should be a 6 digit number.
If it starts with an A then it is a 258, if it starts with an E it is a 232.
This space for rent.
KnetAZ is offline   Reply With Quote
Old 04-14-2003, 09:07 PM   #6 (permalink)
CSP
Member # 1533
Ummm, no. The one barrel was the only carb available through at least '75 in CJ's with either the 232 or 258. A friend has a '78 258 with the one barrel also.
KnetAZ has the correct answer.
CSP is offline   Reply With Quote
Old 04-15-2003, 09:30 AM   #7 (permalink)
Member # 773
Thanks for the info guys. Hopefully I am going to pick up a 74 258 this week.
cheers
Joe
Old 04-15-2003, 09:45 AM   #8 (permalink)
El Guapo
TexasBlake's Avatar
Member # 9722
Well then I stand corrected, all the 232s I've seen are 1 barrel, all the 258s were 2 barrel.
