clutch problem - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-30-2003, 05:41 PM   #1 (permalink)
Member # 17286
Arrow clutch problem
i have a 93 yj and when go to put it in gear it wont go. but after i pump the clutch for a while then all the sudden it will work fine. my question is do you all think that it is the clutch, master cyl, slave cyl. or all three. any help would be wonderfull so i can get it back in running strong. thanks
k2snowboard is offline   Reply With Quote
Old 04-30-2003, 05:57 PM   #2 (permalink)
Member # 8665
check the fluid level and then bleed it
rockr is offline   Reply With Quote
Old 04-30-2003, 07:32 PM   #3 (permalink)
Member # 17286
ya i tried that so its been done. thanks
Old 04-30-2003, 08:04 PM   #4 (permalink)
I make websites!
Member # 12429
Just out of curiousity exactly "how" did you bleed it ?
My 4x4 Blog
Rockwell axles too!
Todd W is offline   Reply With Quote
Old 05-01-2003, 08:24 AM   #5 (permalink)
Member # 15453
I think that year model has a hydraulic throwout bearing (instead of a slave cylinder) that typically goes out first. It begins to leak, all your fluid leaks out, clutch doesn't work. You refill the master cylinder, bleed it, it works for a while until the fluid leaks out again. If this sounds like your situation then that might be your problem.
Also, Christina Agulera is skanky, man
Southbound is offline   Reply With Quote
Old 05-05-2003, 09:55 AM   #6 (permalink)
Member # 3376
No clutch
It definitely sounds like you have a throwout bearing travel problem. There is a hydraulic problem somewhere.
Four Dice 4 Wheel Drive Club
85 4Runner
mudratz is offline   Reply With Quote
Old 05-05-2003, 12:03 PM   #7 (permalink)
Johann's Avatar
Member # 4251
As mentioned by others youare likely having problems with the internal slave cyl. They are the DEVIL! I went through 3 in a year before I decided to research converting to an external slave set up. Going on three years and no problems.
Simple bolt on swap of existing stock part availible at your local junkyard. I have posted the how to several times here. Search for this topic and my user name and you will find the info that I gleaned from this very site.
Who ever invented the internal slave has earned a special place in hell.
Details removed for clarity
Johann is offline   Reply With Quote
