Spal dual 11" fan, pics anyone ? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-11-2003, 07:49 AM   #1 (permalink)
Member # 13554
Anyone have pics of the Spal dual 11" fan installed on a CJ ?
Preferably with a 4.0 ...
Thanks
Tony W
wiltech is offline   Reply With Quote
Old 06-11-2003, 02:09 PM   #2 (permalink)
High5's Avatar
Member # 1700
i don't have pic's and i do not have a 4.0 but i do run the SPAL dual 11" fans on my cj's radiator and it is a perfect fit and they work great.
High5
IT'S 1TON O' FUN!
High5 is offline   Reply With Quote
Old 06-11-2003, 02:14 PM   #3 (permalink)
Member # 13554
Do you have the 258 then or a V-8 ?
How close is the end of your water pump pulley to the fans ?
Thanks
Tony W
Old 06-11-2003, 02:46 PM   #4 (permalink)
TPIJeep's Avatar
Member # 2082
Send a message via AIM to TPIJeep
Thats about all I have.. Oh, thats a 415 cube, SBC with a Griffin 27.5x19 alum radiator, 190 all the time!!
I am normally only a danger to myself don't make me include you!!
BioHazard Buggy Build Thread
Southern Motor Sports
Ruston, Louisiana
TPIJeep is offline   Reply With Quote
Old 06-11-2003, 02:55 PM   #5 (permalink)
Member # 13554
Looks sweet.
If you can can you measure the diameter of the motors ?
I'm worried that the one on the right might be into my idler pulley.
Thanks
Tony W
Old 06-11-2003, 02:59 PM   #6 (permalink)
TPIJeep's Avatar
Member # 2082
Originally posted by wiltech
Looks sweet.
Thanks
Tony W
Here are the dimensions..
http://www.carolinarodshop.com/11dual.htm
Motors are right at 4.5" in diameter and are spaced right at 12" apart center to center..
Good Luck, they work GREAT!!
Ruston, Louisiana
Old 06-12-2003, 11:26 AM   #7 (permalink)
High5's Avatar
Member # 1700
Thanks
Tony W
i run a chevy vortec 350 and my current measurements will not help you i now run all of this in a custome toyota fj40/buggy. my measurements will not help you.
High5
IT'S 1TON O' FUN!
Old 06-17-2003, 08:55 AM   #8 (permalink)
Member # 16209
Tony,
While this won't answer your question about the SPAL fans, here are some pictures of my F-A-L #575 fan.
The clearance between the idler and fan is 3/4", between water pump and center of fan assembly is 1". The package is 2-5/8" thick at the motors. I don't think the 4-1/4" thick SPAL would work for me, there isn't enough room to slide it for clearance.
Gary
gmoabrim is offline   Reply With Quote
Old 06-17-2003, 03:31 PM   #9 (permalink)
CJ5inFourWheelDrive's Avatar
Member # 19668
Just curious, but from the looks of it you are sourcing these from parts vehicles? Or are they aftermarket, I need to get a dual fan setup for my rig as I want to be able to shut it off for water crossings. Thanks,
- Zach
(1975 Jeep CJ-5) Being built: 2x4 A-500C frame, C&C 14 bolt w/discs & Detroit, D44 mini-spool, Flat Tops, Mad Mac Double Arms, 4.56's, SM420, D300, AA & Novak adapters, SOA on 2in. BDS YJ springs with a reversal, extended wb; 6in. front, 3in. rear, TJ flairs, hummer rims, hydroboost w/68' Vette M/C…
CJ5inFourWheelDrive is offline   Reply With Quote
Old 06-17-2003, 03:41 PM   #10 (permalink)
High5's Avatar
Member # 1700
- Zach
SPAL fans are aftermarket.
High5
IT'S 1TON O' FUN!
