Transfer case noise 89 wrangler!!! - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-14-2003, 10:22 AM   #1 (permalink)
Member # 15271
Just a question, 1989 wrangler with 160,000 miles and i noticed that under a load the transfer case is making a noise. It sounds like the chain is slipping on the gears. My question is weather this is common for the amount of miles,or do i need to look elseware?
Just a little info would be great.
thanks
4x4dad
The kids will take our place.Teach them well!!!!
KEEP THE RUBBER SIDE DOWN!!!
4x4dad is offline   Reply With Quote
Old 06-14-2003, 12:20 PM   #2 (permalink)
Member # 15606
Sounds like you know whats wrong.
'88 YJ, SOA, 8.8 w/Detroit and 4.10's NV3550, and 36's
Neal'88yj is offline   Reply With Quote
Old 06-14-2003, 05:12 PM   #3 (permalink)
Moderator
apeters89's Avatar
Member # 7647
My chain started slipping under load as well. I replaced the chain with a $20 junk yard chain and it has worked fine. Just make sure the case you pull it out of hasn't been thrashed on, or you can buy a new one from somewere like 4wd hardware, etc...
Check out our new Team Ape Eater Racing Like us on FaceBook
KF5EQF
Sniper Fab
4x4Oil SBwinVPS Custom Splice C2GFab
apeters89 is offline   Reply With Quote
Old 06-14-2003, 06:01 PM   #4 (permalink)
Quit changin my shit
Otto Man's Avatar
Member # 18977
Send a message via AIM to Otto Man
crack up the case, replace chains, seals, and bearings, reassemble, and you got an almost new case, for about $300.
Originally Posted by Sully
It's a respect issue. Just because you can, doesn't mean you should.
Would you tell your Grandmother to go suck a big black cock, just because you could?
Otto Man is online now   Reply With Quote
