LT1 xj? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-21-2003, 12:53 PM   #1 (permalink)
Member # 20613
Send a message via AIM to 85NIGOTA
LT1 xj?
I have a LT1 engine, i was looking to swap it into a 4 banger xj. Can this be done? Any suggestions will help thanks
85NIGOTA is offline   Reply With Quote
Old 06-21-2003, 01:52 PM   #2 (permalink)
Member # 62
V-8's actually fit really nice, I wouldnt start with an XJ as a project vehicle however. But what ever floats your boat.
Jeff Neves
NE-RokToy is offline   Reply With Quote
Old 06-21-2003, 07:05 PM   #3 (permalink)
Johann's Avatar
Member # 4251
What year 4 liter?
The really early ones (pre 87?) have a different fire wall that causes some problems. But even that can be overcome. There is a guy local that has a chevy 305 in his.
NAXJA is your best source for all things XJ
Details removed for clarity
Johann is offline   Reply With Quote
Old 06-22-2003, 02:01 AM   #4 (permalink)
Dummer'n Moose Poop
Thump's Avatar
Member # 789
I wouldn't recommend an LT-1 into a Jeep, or any vehicle that could see water splashing into the engine compartment.
This is because the LT-1 uses an optispark ignition system that is a big placenta-looking "distributor" mounted directly to the engine behind and below the water pump. These are very susceptible to moisture and other contaminants in the engine bay (there is actually a note to NOT pressure wash a vette engine due to this part).
The early one's had a sealed system that wasn't too well sealed and was problematic from the start. Later on they put a vent and drain in, but that didn't work worth a crap either.
To change these things out is not something I would want to do on the trail, and they are almost too expensive to be carrying a spare around anyway.
Sorry to be the voice of warning, but I don't want a fellow Jeeper stuck on the trail for something like this.
Glenn
I'm a man, but I can change, if I have to, I guess- Man's Prayer (Red Green)
Thump is offline   Reply With Quote
Old 06-22-2003, 09:00 AM   #5 (permalink)
nobody20's Avatar
Member # 12393
There are a couple of XJ's out there that have an LT-1. I saw one from the SF Bay area that had one and it was a sweet swap.
You may want to consider trading your LT-1 for another engine. I have some recommendations, but don't know about how much money you want to spend.
There are ways to remove the high-voltage from the opti.
http://www.pirate4x4.com/forum/showt...highlight=ltcc
Also, you can remove the opti and install HEI distributor
http://www.pirate4x4.com/forum/showt...highlight=opti
http://www.pirate4x4.com/forum/showt...&highlight=lt1
You might want to look around these forums:
http://www.lt4.com/cgi-bin/bbs/config.cgi
http://web.camaross.com/forums/
http://www.f-body.com/index.html/
BTW noob find out about SEARCH
79 CJ-5 a bunch of stuff but no chrome, no Bestop, no Genuine Steel and no Steel Horse.
383 LT-4. D60, D44, D300 4:1, SM420, SOA, 4-link w/double shackles, etc.
88 YJ, 350TPI, 700R4, D300 4:1, rear SOA D44 w/Warn floating axles, coil front D44 w/Warn Axles
nobody20 is offline   Reply With Quote
Old 06-22-2003, 01:37 PM   #6 (permalink)
Member # 20613
Yea i dont know if im going to do it or not, i just have the engine, im going to build a wheeler, and i found a cheap xj so thats why im using it as a platform. i have big plans for it. I think ill just keep the stock engine, i found a 4.0L so that should last for awhile. Thanks for ur help
