Cherokee Bolt-pattern??? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-04-2003, 12:54 PM   #1 (permalink)
Banned
Member # 20084
I want to put a solid axle under the front of an S-10. I think the best axle to use would be a Dana 30 from under a Cherokee. I need to know the bolt circle pattern of this axle, so I will know whether or not to swap the rear axle too. Thanks.
MonsterGM is offline   Reply With Quote
Old 07-04-2003, 01:01 PM   #2 (permalink)
Fistful of Boomstick
usmcdoc14's Avatar
Member # 13344
Send a message via AIM to usmcdoc14 Send a message via Yahoo to usmcdoc14
a simple search using the "search" buttom in the right hand corner would have resulted in an answer of
5 on 4.5
Doc-14 Tactical Products:
When it absolutely, positively needs to be made from random crap found in the back of my garage.
You cant ban knowledge, learn to make your own guns right Here.
New York, Colorado, Maryland, Conneticut….is your state next? Yes it is. Write, Vote and Fight.
usmcdoc14 is online now   Reply With Quote
Old 07-04-2003, 01:02 PM   #3 (permalink)
Member # 5021
Swap both axles.
Don't be "THAT GUY" on the trail.
www.voodoowax.com
The Rockslut is offline   Reply With Quote
Old 07-04-2003, 01:51 PM   #4 (permalink)
Member # 9690
if your going to go through the hassle of putting a strait axle in your s-10 you might as well put a 44 in there.
norcalXJ is offline   Reply With Quote
Old 07-04-2003, 04:17 PM   #5 (permalink)
Member # 15049
Originally posted by The Rockslut
Swap both axles.
Yea, you need that heavy duty dana 35 in the back.
1986 K30
sw99 is offline   Reply With Quote
Old 07-04-2003, 06:11 PM   #6 (permalink)
usmcdoc14's Avatar
Member # 13344
not if he finds a XJ with a 44 rear they are not all that elusive, its not like seeing a sasquash
i agree dude if you are going threw the b!tch of doing a SAS on that S-10 go and fid a donor vehicle with some strong axles that matches the transfer case you are going to use and just put both axles under it
