engine dying
i have an 87 yj with 4.2 and an mpi fuel injection kit on it. yesterday on the way wheeling, it started to loose power like it was running out of gas. we got it started and what is wierd is, if you sprayed wd-40 in the throttle body, it ran like a champ. it only does this when it is hot, about 210 on the guage. you let it cool down and it runs fine. i cleaned the k&n and changed out the fuel filter. i replaced the throttle possition sensor about 5 months ago. i have noticed a raw gasoline smell but cant find any leaks. im thinking that its running rich and that is causing the temp to go up and shutting the computer down, killing the engine. lots of gas comes out of the valve on the fuel rail, one of the first things we checked cuz of the "running out of gas symptoms" i havent been able to duplicate it since i changed the fuel filter but it hasnt been as hot either.
Only in a Jeep |
Member # 14841
Overheating will not occur from too rich a mixture. It might happen if the mixture is too lean. Assuming your temperature gauge is correct, 210 degrees is not excessively hot. It shouldn’t have an issue at that temperature. I vote for vapor lock. As I recall, the Mopar system uses an in-line fuel pump that draws from the tank. This can sometimes lead to vapor lock issues. I would invest in a fuel pressure gauge and see what happens to the pressure when it starts this again. If your pump is near anything hot, you can relocate it. Or you can install an in tank pump.
-Old Army |
i would be willing to bet you have a vacume leak. i had the same problem with mine. i thought it was the gaskets on the carb but it turned out to be the gaskets on the intake/exhaust manifold. jeep had a shitty designe and the intake and exhaust gasket it all one piece. i have been through two of them on mine. take that WD40 and spray it around the intake manifold. if the idle goes up then you need to pinpoint the problem. the reason that it runs better with wd-40 is because with a vacume leake, too much air is getting into the combustion chambers.
hope this helps....it will be easier to check for a vacume leak before replacing parts...
Steven W My Website 82 CJ-7 - SOA, geared, locked, 35's 02 Ram 2500 - Cummins, 4x4, 6spd |
