Outer knuckle u-joint problems - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-23-2003, 04:22 PM   #1 (permalink)
Member # 17583
I've got a bad half shaft on my front axle. I've got a ford 9" w/31 spline inters and 28 spline outers. I'm going to change the outers shafts to larger ones soon but untill then I'm planning on welding the caps to the half shaft. I know the heat is going to damage the inside of the cap and reduce the life of the u-joint but I only need a couple of trips before I get the new axle shafts.
I'm going to use a cutoff wheel to slightly notch the ear and the cap then tack weld the cap in place. Anything I missing with this plan?
This is what I'm having a problem with.
[IMG]F:\150946e\3rd Partition\Data\Jeep\MyJeep\Axles\ujoint.jpg[/IMG]
ScottDeLano is offline   Reply With Quote
Old 07-23-2003, 09:11 PM   #2 (permalink)
Cue-Ball's Avatar
Member # 17311
damn that is a bad bad problem. Those red X's are a bitch when the crawl up in your drivetrain.
Q
Nex Pro Evinco "Death Before Defeat"
Cue-Ball is offline   Reply With Quote
Old 07-24-2003, 09:56 AM   #3 (permalink)
Member # 17445
If you have a Dremel tool or other small die grinder, I would recommend notching out the yoke for full-circle clips. I have tried welding the caps, and I (currently) run full circle clips (stock shafts/760X joints). The welds just seem to weaken everything, I only got 2 trips with welded caps. With full-circle clips, I have 3 trips now and not a single cap has even spun on me.
[url="http://mysite.verizon.net/dchurch1/jeep/CJ5"]'73 CJ5[/url].
donjr5 is offline   Reply With Quote
Old 07-24-2003, 12:32 PM   #4 (permalink)
Member # 6581
Send a message via AIM to hightechdave Send a message via Yahoo to hightechdave
damn "x" sneaked on to my driveshaft once, broke it clean in half
83 CJ7 with stuff
hightechdave is offline   Reply With Quote
Old 07-24-2003, 04:09 PM   #5 (permalink)
Member # 17583
That aggravates the crap out of me. I guess i'm doing something wrong on attaching the pic to the post. I guess I need to go back to the newbie catagories.
Why is it that some people can see it and others can't!!!
