YJ steering question while swaping in fullwidths? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-23-2003, 10:52 PM   #1 (permalink)
Member # 15699
Send a message via AIM to yeehaw87
ok so im swaping in 76 ford fullwidths i got my hiems and tue adapters from poison spyder and the DOM will be here on friday
so my question is im too poor to go hysteer at the moment and im running 2 in BDS springs SOA and i know the dragling is gona hit the spring so how do you get arond that bend the drag link like a z and gusset it? anyone got a pic on how they did it?? thanks chris
93 yj built HP44/BB 9" 488's spooled, 37" SSR's ,superwinch s 9000,too much shit to list ask if you are curious
yeehaw87 is offline   Reply With Quote Quick reply to this message
Old 07-24-2003, 01:04 AM   #2 (permalink)
lojones's Avatar
Member # 12017
I dont have any recomendations for making a Z type bar but when you do get a little cash, you can start by buying the passenger arm. Then you can run the new draglink and leave the tie rod below until you can get another arm.
79 CJ7 EFI401>th400>Atlas II 4.3> 60/14, 38.5 SX's, H1 beadlocks
lojones is offline   Reply With Quote Quick reply to this message
Old 07-24-2003, 04:26 AM   #3 (permalink)
bigdude's Avatar
Member # 6007
Or just make your tie-rod out of some 1.5", .375 wall DOM and always leave it in the stock location. After about 5 trips I realized I couldn't bend it, so why move it
4-Seats of Fury
LS1, 700r4, Atlas 3.0, 2.5 SAWs, Reds
Lead Foot Syndicate
bigdude is offline   Reply With Quote Quick reply to this message
Old 07-24-2003, 07:24 AM   #4 (permalink)
Member # 18601
Smile
GET THE HIGH STEER ARMS FROM POISON SPYDER. I HAVE THE SAME EXACT SETUP FROMTHEM AND IT WORKS SWEET. NICE ANGLES AND SIMPLE SETUP THAT DOESN'T LIMIT FLEX. I HAVE A FRIEND THAT HALF ASSED IT AND HIS HILL BILLY WELD STEER ARMS LIMIT HIS FLEX MAJOR.
88YJ
67M715
00Excursion 7.3
SVENG52 is offline   Reply With Quote Quick reply to this message
Old 07-24-2003, 10:00 AM   #5 (permalink)
GirlfriendYJ's Avatar
Member # 13774
Send a message via AIM to GirlfriendYJ
you cant bend that??? must be teh 4banger pushing your rig
go ahead adn zlink and gusset for a temporary fix...
then save your money and buy a passenger side arm...then put the drag link up top
then save more money and buy a driver side arm and put the tierod up with her....put the tierod behind the axle too...whats what i did with 2" bds springs...plenty of clearance...
you can see my pics for the arms i made and my setup
"THE GIRLFRIEND" - 1991 YJ
OTHER JEEPS: 85XJ-88XJ-91YJ-94YJ-99WJ-01TJ
GirlfriendYJ is offline   Reply With Quote Quick reply to this message
Old 07-24-2003, 12:18 PM   #6 (permalink)
bigdude's Avatar
Member # 6007
Could be the 3200 lb rig, you're right
4-Seats of Fury
Lead Foot Syndicate
Old 07-24-2003, 12:24 PM   #7 (permalink)
Member # 13774
or you could get on it harder!
Old 07-24-2003, 12:29 PM   #8 (permalink)
Keith Strong's Avatar
Member # 477
Send a message via Yahoo to Keith Strong
Use a YJ rear track bar.....cut the ends off and weld on bungs for the ends
[CENTER][SIZE="5"]
[/SIZE][/CENTER]
Keith Strong is offline   Reply With Quote Quick reply to this message
Old 07-24-2003, 12:54 PM   #9 (permalink)
Moderator
ashmanjeepXJ's Avatar
Member # 10249
Sounds like too much work to do it wrong, bending .25in walled tube is kinda hard, then adding gussets.. wasiting tube...
I figure your halfway to the cost of doing it right...
Just sell some blood or something and buy the single highsteer arm.
Dave
AZ Undertaker
ashmanjeepXJ is offline   Reply With Quote Quick reply to this message
Old 07-24-2003, 08:57 PM   #10 (permalink)
Member # 15424
Re: YJ steering question while swaping in fullwidths?
If you bought the stuff from poison spyder, you aint poor, so do it right.
Pass side arm and have the flat top machined.
It does add up, but why spend money not doing it right?
I think the z shaped bar is a stupid idea.
My lengthy plan includes a double ended pass side high steer arm, cause i am going to use it for the ram that I also plan to install. I still have not seen any reason to move the tie rod up yet either.
90YJ | HDOR | WEBILT | ID4x4A
gripguru is offline   Reply With Quote Quick reply to this message
Old 07-24-2003, 09:59 PM   #11 (permalink)
Member # 15699
ok well i jsut plain dont have the money to do it right now this swap is gettin expensive im leaving for PURDUE in a month i gota watch my pennies i would love to see a pic of a z setup i saw a guy at THE BADLANDS that did it and i took a pic but now i cant find it??
Old 07-25-2003, 10:38 AM   #12 (permalink)
Member # 13774
here ya go dude...its the offroad club i started while i was at purdue...some good guys in that club...pretty active too...have fun...great school
http://porc.purdue.org/forum/index.php
Old 07-25-2003, 03:22 PM   #13 (permalink)
Member # 12440
Send a message via AIM to funflaty
for $.50 a pound you can buy some 1" thick steel plate and make your own. Then all ya gotta do is drill some holes and you're ready to go. Make sure you get the ackermann right or the thing won't turn right.
funflaty is offline   Reply With Quote Quick reply to this message
