You want amps? I got your amps! - Page 4 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-17-2006, 02:51 PM   #76 (permalink)
Member # 52223
On a side note,
If you plan on doing this swap in your YJ, don't forget you'll need to upgrade both of your Alt fuses in the main fuse box under the hood. When I installed my new Alt out of a 99 Dodge 1500, the increase amp output blew both fuses. Took me a couple of hours to figure that one out.
[COLOR="Lime"][SIZE="5"][B]HELP FIND HIS MISSING 6 YEAR OLD BOY!!!!!![/B][/SIZE][/COLOR]
[B][CENTER][SIZE="2"]Home of the RROCK Mafia:[/SIZE][/CENTER][/B]
[CENTER][SIZE="3"]
[/SIZE][/CENTER]
[SIZE="3"][B]At least when Clinton lied, no one died.[/B][/SIZE]
kooters94yj is offline   Reply With Quote Quick reply to this message
Old 03-03-2007, 06:41 AM   #77 (permalink)
Member # 65801
Alonng the lines of this thread. Rumor has it that you can change the alt pulley size to allow the alt to develope higher amperage at low RPM
I have found that night time hard winching situations (with headlights on) sometimes lacks the juice for the operation even with my foot on the throttle.
Any one does this? Is it just a band aid fix?
I'm pretty sure I can make that...
Jeep itch is offline   Reply With Quote Quick reply to this message
Old 11-29-2007, 01:48 AM   #78 (permalink)
Member # 20592
Send a message via AIM to gumbojeepyj Send a message via Yahoo to gumbojeepyj
I remembered this thread from a while back and searched for it to help another jeeper out....
after reading it through again i had to bump it back up....it's just good damn tech.
Blake
http://www.lockitupoffroad.net
gumbojeepyj is offline   Reply With Quote Quick reply to this message
Old 11-29-2007, 02:23 AM   #79 (permalink)
Member # 87159
Send a message via Yahoo to ARB_jon
go to bed gumbo
97TJ/4.0/ax15/231,300/44spool/8.8welded/4.10/36" iroks
www.lockitupoffroad.net/jong.html
ARB_jon is offline   Reply With Quote Quick reply to this message
Old 11-30-2007, 01:27 AM   #80 (permalink)
Member # 20592
ugh, blow me
Blake
Old 11-30-2007, 11:45 AM   #81 (permalink)
Rotten Sperm
Nordic1's Avatar
Member # 63386
Nice Tech! Now get your pics to show up
Nordic1 is offline   Reply With Quote Quick reply to this message
Old 01-01-2008, 01:00 PM   #82 (permalink)
Member # 3983
Originally Posted by dorfs View Post
A quick addition on identifying them. If you look at the front, the heavy duty ones have 2 circles cast around them, (as seen in the 5th pic) and the smaller ones have 1 circle. I was asked once to install a heavy duty alternator on a 2000 XJ for one of Fort Carsons MP's ride. I did have to make some small modifications to the lower mounting bracket for clearance. But when I installed the heavier ones on my 4.0 and 5.9, it was a direct swap.
Re: 2000XJ install....just to confirm because you are the only person I can find that's done one post 1998 model year....You didn't have to 'reclock' it, I read on NAXJA this might be necessary.
And in case it helps anyone else here are a couple pics I found on-line that may help identification (you can see the double rings mentioned elsewhere):
136amp / 56027913
117amp / 56005685AC, 56041822AA
LynchMob is offline   Reply With Quote Quick reply to this message
Old 01-03-2008, 09:11 PM   #83 (permalink)
Member # 96003
So has anyone found a solution for 2001 and up Jeeps?
I mean spending 500 bucks on a Wrangler Power Product Amp is a little friggn crazy if you ask me..
unscathed is offline   Reply With Quote Quick reply to this message
Old 08-15-2008, 05:46 PM   #84 (permalink)
Member # 89438
can anyone tell me the way the two wires you have to cut go onto the 56027913?
-99 TJ-
bagboy is offline   Reply With Quote Quick reply to this message
Old 10-28-2009, 04:54 PM   #85 (permalink)
YXwhenUcanFAB?'s Avatar
Member # 44612
BTT for an answer to this question. The wires in question are for the field coil. On my XJ that this is going in, i had a 2 wire plug, the new 136A alt has 2 ring terminals. Are they polarized?
Jeep...the other white meat.
YXwhenUcanFAB? is offline   Reply With Quote Quick reply to this message
Old 02-11-2010, 09:38 PM   #86 (permalink)
Member # 18650
Send a message via AIM to chadjans
Anyone have a link to the mising photos within this thread? More specifically the wiring mods required?
chadjans is offline   Reply With Quote Quick reply to this message
Old 03-10-2011, 09:50 PM   #87 (permalink)
GFY Racing's Avatar
Member # 136091
Location: Back in the good 'ol U S of A after three long deployements!
Hmmm....6 and 1/2 years old thread with good tech, why not bump it up!
BTW, for everybody asking questions years after the thread was started, try looking at the dates
Fighting for the right for SORRY PIECES OF SHIT to protest at soldier's funerals.
1989 XJ on 35s Work in Progress
GFY Racing is offline   Reply With Quote Quick reply to this message
Old 03-11-2011, 08:00 PM   #88 (permalink)
jeep09's Avatar
Member # 143697
www.powerbastards.com makes great alternators now too
jeep09 is offline   Reply With Quote Quick reply to this message
Old 03-11-2011, 09:35 PM   #89 (permalink)
Member # 18650
Pot calling the kettle black?
Old 07-08-2013, 06:10 AM   #90 (permalink)
lethaljeep's Avatar
Member # 190687
Couple of questions.
Do you have to upgrade the main power lead to the alternator for a thicker gauge wire?
Also, what do yall recommend upgrading the fuse to so it doesn't blow with the new install?
Thank you.
lethaljeep is offline   Reply With Quote Quick reply to this message
Old 07-12-2013, 08:35 AM   #91 (permalink)
lethaljeep's Avatar
Member # 190687
Originally Posted by Travis Waldher View Post
Shoulda asked me. Already did that swap. I remember looking at the alt in the Jeep. Thinking gawd, that looks familiar, popped the hood on the dodge and realized they had the same case. LOL Didn't even have to swap rubber parts around, straight bolt in. I *think* the pulleys were even the same.
For those that haven't done this, mine is a 4.0L 92 YJ, the alt came from a 1996 Dodge Ram 1500 5.9L V8.
Thing I don't get, 120A alt for a Jeep is nearly $200, the nearly identicle 136A alt from a Dodge truck is $150. (new prices obviously)
I think if it says Jeep they have to try to rape you.
Used this alternator, bolted right in. just swapped my fuses for two 60amps.
Old 07-12-2013, 07:52 PM   #92 (permalink)
Jeepman14wheel's Avatar
Member # 46071
Great thread going to pick up a new alternator tomorrow!
Jeepman14wheel is offline   Reply With Quote Quick reply to this message
Old 07-15-2013, 08:56 AM   #93 (permalink)
Member # 113063
Thanks to this thread I am now sporting a new 160 amp alternator on my 06! Awesome write up. Thanks for all the awesome info.
BUILD IT! DRIVE IT! BREAK IT! BUILD IT STRONGER! DRIVE IT HARDER! BREAK IT AGAIN!
TXYeeper is offline   Reply With Quote Quick reply to this message
Old 07-19-2013, 10:24 AM   #94 (permalink)
Member # 312354
You can change the pulley size. When you pick up a new alternator they usually come with a "dyno slip" that tells you their output at a given alternator rpm. If you can do a little math you can figure out how fast your alternator is spinning compared to your engine and adjust the pulley size to put the alternator in a more efficient part of its curve. Most peak out around 6000rpms at the alternator.
ironmangq is offline   Reply With Quote Quick reply to this message
