72 cj-5 frame - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-06-2001, 02:32 PM   #1 (permalink)
Member # 1332
Lightbulb 72 cj-5 frame
I have 72 cj-5 that has a broken frame. I am looking to put a new frame under it but I am having a hard time finding a good frame out of a 72. My question is what year jeep frames will work under this body? I found a 78 but I am not sure if this will work? Any advice?
tlancaster is offline   Reply With Quote
Old 12-06-2001, 02:55 PM   #2 (permalink)
Member # 940
What is so broken that it cant be fixed? To answer the question I would think about 55 to 72.5 are the same. I have the frame out of my old 66 that you could have for a case of It is cracked in some spots and mostly boxed. I also have buggie leafs on it front and rear.
WWW.PCRYO.COM
Deep Cryogenic Tempering Service
Find all my products at
www.KICKASSOFFROAD.COM
916-434-6978
Custom Axles built to order.
Got 40 spline? I have the hubs, spindles, and axles you need to kickass!
Custom Hummer wheels and centers
Axle Resplining
66CJdean is offline   Reply With Quote
Old 12-06-2001, 04:04 PM   #3 (permalink)
Member # 2095
'72 - '75 should be the same.
'71 & older are ~2" shorter wheelbase. the length was added in the engine compartnent in '72 to accomodate the straight 6.
'76 & newer are a stronger frame w/ same wheelbase (83"), but body mounts may be different.
'79CJ5,soa,d44/60,t18,d18w/Obrian 3.6low,5.13's,35x14.5SSR's
'02 Z71
CJ-Jeeper is offline   Reply With Quote
Old 12-06-2001, 05:44 PM   #4 (permalink)
Member # 6151
tlancaster,
Your log name freaks me out everytime I see it. What is really weird is that I just got done fixing the broken frame on my cj-5.
I had to read your post about three times. I kept saying to myself "I dont remember posting here."
I dont know if find this as strange as me
alancaster AKA Tony Lancaster
Guess you had to be there. I'll go back to drinking my now.
T3
alancaster is offline   Reply With Quote
Old 12-06-2001, 05:51 PM   #5 (permalink)
Member # 6151
Oh yeah,
Forgot to say, Just buy some steel, Jack the thing up, put it on jackstands and burn some steel.
One thing to keep in mind is that you dont want to weld vertically on your frame. Sure you may have to weld the cracks vertical but weld a diamond SHAPED plate over the top of that weld. And then weld a strap of steel to the bottom of the frame.
Best thing to do is pull your tub off this winter and box the rest of the frame.
T3
T3
Old 12-06-2001, 06:56 PM   #6 (permalink)
Member # 940
66-72.5 come with the 4 or v6 72.5 up came with the I6
WWW.PCRYO.COM
916-434-6978
Axle Resplining
Old 12-06-2001, 07:08 PM   #7 (permalink)
emsoffroad's Avatar
Member # 1802
Send a message via AIM to emsoffroad
You can use the 78 frame but you will have to mave your spring pads out and the body mounts. in 76 AMC boxed the frame and tapered the ass end out a few inches. I put an older frame under a newer 5. Here in the rust belt there tends to be a problem with the boxed frames.
EMS Offroad
emsoffroad is offline   Reply With Quote
Old 12-07-2001, 12:41 AM   #8 (permalink)
Brad's Avatar
Member # 3239
Send a message via AIM to Brad Send a message via Yahoo to Brad
i replied to your ad in the wanted section, i got a 65 boxed cj5 frame,no cracks
B-RAD Fabrication
TDO DYSFUNCTIONAL ROCKCRAWLERS
Brad is offline   Reply With Quote
