what spline input shaft np231?? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-06-2001, 05:52 PM   #1 (permalink)
Member # 2358
I was wondering how many splines on a np231 that is in a 1989 yj 6cy with and auto. I just bought the yj and didn't realize the t-case was cracked, front drive shaft pogo'd the t-case. I have some out of a 4 cyl 5 speed (21 spline), can the input shafts be interchanged between the t-cases??
Craig
1992 YJ "Pepe`" soon to be for sale
1994 YJ "??" for sale
Ever stop to think and forget to start again
CrazyCraig is offline   Reply With Quote
Old 12-06-2001, 06:29 PM   #2 (permalink)
Member # 3169
Re: what spline input shaft np231??
Craig
Should be 23 spline with the auto, according to an AA table I have.
98TJ; AtlasII; 35 SSR's; ARB's, etc
AzJeep is offline   Reply With Quote
Old 12-06-2001, 06:47 PM   #3 (permalink)
Member # 7051
Send a message via AIM to Josh 89XJ
89 was a funky year with the AW4 231 combo. Some of them had 21 spline. Gotta pull it and check.
There's no time like the present....well, except for that time you did two chicks at once. That was WAY better than the present!
Josh 89XJ is offline   Reply With Quote
Old 12-06-2001, 07:22 PM   #4 (permalink)
Member # 8584
Send a message via AIM to Steevo Send a message via Yahoo to Steevo
Yes, the input shafts can be swapped
Steevo is offline   Reply With Quote
Old 12-06-2001, 07:26 PM   #5 (permalink)
WyoJeeper's Avatar
Member # 1040
89s with the 6 and auto had the TF999 not the Asin tranny. And its 23 spline.
Rick
WyoJeeper is offline   Reply With Quote
Old 12-07-2001, 06:39 AM   #6 (permalink)
Mr. FixIt
DE Jeeper's Avatar
Member # 5295
What year is the 4 cyl t-case. If both cases are YJ cases all the parts are intercangable. The case behind the auto will be a "long" 23 spline input. The 4 cyl, 5 spd will have a "short" 21 spline input. T-cases with AX-15's in front of them had "short" 23 spline shafts. You can not swap TJ t-case input parts because they changed the input bearing style. In short it the cases are both from a YJ or XJ you can swap parts. I would buy a new chain while you have it apart, but that is just my $.02.
'88 YJ with not much '88 YJ left
We-Rock Stock Class
Team Mall Crawler #609
Sponsored by:
The Drive Shaft Shop www.driveshaftshop.com
Delaware Jeep Assoc. www.delawareja.com
DE Jeeper is offline   Reply With Quote
