anti friction pads for leaf springs - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-07-2003, 05:01 PM   #1 (permalink)
Member # 16830
Rebuilding my leaf spring packs. I know origanally they had a plastic anti friction plate between a few of the leafs. My question is how important is it to have these in the leaf packs? I know I have ran for about a year without them also this is a trail only rig if it matters.
jeepguy616 is offline   Reply With Quote Quick reply to this message
Old 10-07-2003, 07:40 PM   #2 (permalink)
Member # 15049
All of mine have worked their way out of the packs and no problems. I usually only run a leaf pack for two years if i'm luck though.
1990 V10 Blazer
sw99 is offline   Reply With Quote Quick reply to this message
Old 10-08-2003, 08:50 AM   #3 (permalink)
Member # 23265
Did you use an anti-friction paint or coating when you refinished the leaves?
SundevilYJ is offline   Reply With Quote Quick reply to this message
Old 10-08-2003, 08:56 AM   #4 (permalink)
ItsaCJ6's Avatar
Member # 6340
I want to call this a Newbie post but...... Graphite paint is available at your local autoparts store. Grease works. but the teflon sheets will probaly fall out over time. and yes you want the springs to slide back and forth....Rusted up shit don't slide well...
shameless plug.....For the best deal on 8 lug disc brakes click here-->
Marc
In what appears to have been an understatement, the plant operator described the situation at the Number 4 reactor as "not so good."
Love and kisses, Zaphod..
ItsaCJ6 is offline   Reply With Quote Quick reply to this message
Old 10-08-2003, 06:10 PM   #5 (permalink)
Member # 16830
Ok so call it a newbie post. I could give a rats ars. Its the first time I am playing with home built leaf packs from different jeeps. I am plulling all the leaves apart and cleaning all the rust off and painting and assembling them. I did not even think about graphite paint sounds like a plan. I just don't want to put them plastic pieces of crap back in to just fall out after a few runs.
Thanks for the help.
Any opinions on spring clamps??? I need something
Old 10-09-2003, 04:53 AM   #6 (permalink)
Member # 15049
I just heated up the old ones and straightened them out and rebent them and used the again.
1990 V10 Blazer
Old 10-09-2003, 11:37 AM   #7 (permalink)
MC
Nose to grindstone
MC's Avatar
Member # 21997
Send a message via Yahoo to MC
they work good after you heat them? did not know that
MFGS of the STAR-LAB CNC machines
The finest CNC plasma tables
Made in the USA by Bulltear and can be found online at
and at local welding stores
Hypertherm and Thermal Dynamics
We also make parts for AMC
MC is offline   Reply With Quote Quick reply to this message
Old 10-09-2003, 11:47 AM   #8 (permalink)
Keith Strong's Avatar
Member # 477
Send a message via Yahoo to Keith Strong
*edit.......are you talking abotu the springs or the clamps?
[CENTER][SIZE="5"]
[/SIZE][/CENTER]
Keith Strong is offline   Reply With Quote Quick reply to this message
Old 10-09-2003, 12:34 PM   #9 (permalink)
Moderator
ashmanjeepXJ's Avatar
Member # 10249
I like the YJ style clams that are riveted into the leaf. I didnot bend mine I Just cut the little bent tabs off then after re packing them I welded the little tab back on, I sprayed water on it after welding so the leafs wouldent see much of the heat..
Dave
AZ Undertaker
ashmanjeepXJ is offline   Reply With Quote Quick reply to this message
Old 10-09-2003, 07:44 PM   #10 (permalink)
Member # 15049
I was refering to the question about the clamps. Sorry if that was confusing! That's what happens when you drink lot's of New Castle and try and type.
1990 V10 Blazer
Old 08-18-2005, 04:48 PM   #11 (permalink)
jeep_boy02's Avatar
Member # 34115
When you refer to "Graphite paint" do you mean spray-on graphite lubricant type stuff, or an actual colored paint that has graphite in it or something so it has less friction? Just wondering if I should look for a specific kind of paint(flat black) and primer for my leaf packs.
jeep_boy02 is offline   Reply With Quote Quick reply to this message
Old 08-18-2005, 07:37 PM   #12 (permalink)
kwrangln's Avatar
Member # 6971
Call it a hack job if ya will, but it worked. Plasma cut the eyes off the second leaf, semi rounded the end, and cut a hole for the plastic slider. For the clamps, heated and straightened, then drilled a hole through em for a 1/4-20 bolt and nylock nut. Without the pads, got alot of creaking when turning from lock to lock while not moving, pads cured it. Worked smooth and flexed great. Second leaf in the pack is a main leaf minus the eyes.
I'm the "tack tack tack" welding nazi.
:flipoff2:
"I didn't mean to kill nobody ... I just meant to shoot the sonofabitch in the head. Him dying was between him and the Lord." R. L. Burnside
kwrangln is offline   Reply With Quote Quick reply to this message
Old 08-19-2005, 01:45 AM   #13 (permalink)
Member # 8093
Call National Spring if you feel motivated. Last I checked the teflon pads were ~$0.25 each.
Since you are somewhat unfamiliar with quality leaf construction, and the attention that goes into making them, then perhaps call a few of the better known makers to see if they will share their knowledge. I don't get paid to do this anymore, so I pass on jabbering over the phone & talking to others when others can do this as their job.
u-joint is offline   Reply With Quote Quick reply to this message
