HeiserOilMotorsports
4.2 liter engine questions, and suggestions needed...
Ok guys, as you probably deduced from my sig, Ive got an 89 yj, with the carbed 4.2... The carb hasn't given me much of an issue, thank God... Well... now the motor is giving me problems.. It won't stay cool anymore, and Ive replaced everything in the cooling system. I have a feeling that the head gasket is slowly deteriorating. I also have an exhaust manifold leak, and my valve cover gasket leaks.... Here is my dilemma... Im short on cash... But I could probably afford to stick a new head gasket on, machine the head, replace the valve cover gasket, and replace the exhaust manifold. OR... my only other option at this point is to swap in a reman 4.2, and keep my carb crap for now, which I planned either way, because I can't afford EFI at this point.. The jeep has almost 220,000 miles on it... What would you do? replace just the broken parts, or just go full bore and forget about it? As of now, the engine still produces good oil pressure, so Im not that worried about it.. On the other hand, it would be nice to drop a fresh motor in it... but thats big $$... So... let me have it....
![]() Thanks! Scott
Black Star Status! |
did you try to replace the fan clutch?
You could probably find a good used/junkyard 4.0 for a decent price. You would have to get the puter and harness too though. Then again, if you aren't having any problems with your carb, just get the head resurfaced, replace your lifters and push rods and slap it back together. (don't go cheap on gaskets) You can do a Junk yard EFI later on down the road.
83 CJ-7, 360 .030 over, shaved heads on the pane. 105 inches of noise and booger welds. |
At 220,000miles, I would be concerned about the rest of the engine being worn as well. This is around the point where most 4.2Ls give up the ghost.
I would go the reman route just for speed of getting the job done. But a reman engine is not likely to have the exhaust manifold on it so add that into the budget. Go for a 4.0L HO engine if it is available to you. But with out the fuel injection side of things, I would rather have the 4.2L.
Ask me anything about a Cummins, I stayed at a Holiday Inn last night. |
#5 (permalink) | |
Scott
i would save up the money and just run this motor tell it quits. when you have enough money go and buy a better motor and put it in.
jeeps, a never ending project 90yj with full width axles, rear 14bolt 5:13's , HP44 front 5:13's with high steer and an ARB, all on 44044's. LS1 motor w/ sanderson headers LS6 intake...3.8 ATLAS 32 spline F&R...4L60E tranny |
#11 (permalink) | ||
If anything, Im going to buy an F350 PSD to tow my junk with, but that will still get alot better gas mileage than my jeep is currently getting.Scott
#12 (permalink) | |
#14 (permalink) |
$1200 for a reman is not bad. It cost me more than that to do a full rebuild, and that was pulling strings for a couple major discounts. And it was months of downtime, borrowing vehicles to get to work.
I could have swung in a reman in a weekend. Damn, wish I had known better.
#16 (permalink) |
go try to find a 99 and later 4.0 block. you can put all your carb crap back on it, and when you are ready you can do the MPI conversion.
The 99 block was the first year with the crank girtel, it keeps the rattles down. You'll have to convert to a cheap electric fuel pump, so buy 2. I have a 99 block with all the 94 mpi Carb stickers. It passes smog with no problems, no questions asked. and almost 0 emmitions.
88 4.0, np435, atlas, d44's arb, on 37 |
