Member # 12397
Alternative to Anti-wrap Ladder on SOA CJ
O.k I finished my SOA on my 1982 CJ8 with 36" TSLs Ford 9" rear, Dana 44 front, 5.0, blah, blah blah...
Put RE 1.5 SOA YJ springs in front and had customized stok YJ springs in rear. Well after a couple of trips the passenger side (side with the anti-wrap ladder bar) springs in the rear flattened out. I just bought some RE springs for the rear but I am afraid to use the ladder bar because at $125. I can't afford to replace the RE springs every fouth wheeling trip. SO I come here asking for anti-wrap bar/ladder alternatives. I used the search engine here to get the info I needed on building the bar and didn't see any alternative ideas. So what else can I do? Mark
Wheelin..It's what's for breakfast. |
Member # 14570
4 link
Are you saying you bought the RE SOA springs, with the reverse spring eyes, and are about to put them on? I just put those on my brothers YJ, and they helped a lot with his axle wrap, he is not running a ladder bar. |
#4 (permalink) | |
Moderator
lift to run this thing. Maybe I'm just not seeing it right. All new ideas are certainly welcome, and this seems to be working well for those already using it, so it's obviously another solution to the problem whether I see it correctly or not.
Check out our new Team Ape Eater Racing Like us on FaceBook KF5EQF Sniper Fab 4x4Oil SBwinVPS Custom Splice C2GFab |
Member # 62
I think you are prematurly pointing the finger at the anti wrap bar. I understand your concern for your newly aquired and expensive RE springs however there is a 99% chance, at least in my mind, that the wrap bar did not lead to spring sag. This is unless the designe of the ladder bar causes some kind of bind in the spring (upper traction bar mount doesnt allow enough movement and causes springs to S when flexing) The Bambar uses the same principles to limit axle wrap, only it relies on the springs themselves as the lower bars of the link setup.
You have just ran into a problem many have incountered before you, stock YJ springs even if beefed up are not up to the task of wheeling.
Jeff Neves |
#7 (permalink) | |
Non-Lemming
Member # 840
Take another look at the pics. It's all above the pumpkin and the gastank isn't an issue.
Well I have a simplified version torque bar link run with a similar concept. I essentially made a center triangle style truss directly over the diff housing welding the ends to the tube itself(I have a Dana 60, wouldnt recommend on a dana 35). I wanted to mount a center link with the length matching that of the length from the front spring eye to center of axle. I then wanted to match the angle from the center eye of the front spring mount to the center pin of the spring pack at normal ride compression. By doing this I have a center link that almost matches the horizontal travel of the rear housing. Its much simpler then the compound center link we're talking about here on the hyperlink.
As for my spring wrap history though,........even with this simple center link, I still managed to wrap 3 BDS passenger side rear springs(they are garbage for SOA or anything over 38"). I then went to RE 2.5" heavy duty spring pack with add-a-leaf and havent any major right side sag. With a single link leaf spring set up the right spring is going to take a beating because of the torque effect from the drive shaft. The RE are a much better spring then the average lift spring and a world better then the stock YJ spring.
http://www.12voltguy.com/ <<SEABASS44 rocks!! Friends don't let friends buy AGR !! 91 YJ, 39.5 Boggers, Eatons, HP D60 fr 63", D60FF rear 62", Detroits, AtlasII 4.3, NV3550, 4.0L(190k on it), Warn HS9500, 03 Dodge 3500 QC, 4x4, CTD HO, 6spd, DRW, Smarty Jr, Brentz 19.5" |
#9 (permalink) | |
I am not saying it doesn't work for those that use it, or that they didn't put a lot of time into it, but when it comes down to it, its just another single arm setup.
#10 (permalink) | |
Member # 62
AMEN!
Jeff Neves |
Not to sound like a dumbass newbie, but what I figured out from seeing it over and over again is the lack of bumpstops. Most people do a SOA and never even bother with bumpstops. Once the springs go into negative arch there shot. Just my .02
Mike Greenwalt AdventureWorks Motorsports Pro-Mod #818 Would like to thank there sponsors, EMSoffroad http://www.awmotorsports.com AW Motorsports on facebook-become a fan |
#13 (permalink) |
Member # 22512
Here is a product from Nth Degree Mobility.
http://www.nthdegreemobility.com/stinger.htm I like the idea since I have very little room on either side of the pumpkin due to my dual exhaust to use a ladder bar. I don't think that it would be considered a single bar setup due to the fact that the pinion is hard fastened to the unit. I was wondering if anyone has any experience with this type of setup? Last edited by Limerick; 10-14-2003 at 06:47 AM. |
#15 (permalink) | |
Member # 22512
The one that was not available until October 2003 is their redesigned model. They were selling a different one before this one which was based on the same concept. |
#16 (permalink) | |
Member # 12397
Look closely at the Passenger side spring, see how it is arched backwards? That is my problem (and theirs too evidently) heres the picture As for the feedback thanks guys, I guess I should have specified GOOD, WORKING alternatives to the ladder bar. I intend to run just the RE springs (no antiwrap) this weekend to see how they hold up on my Ford 9" and 36s. I agree that the stock YJ springs no matter haw they are "built" are just polished pieces of shit doing noting but adding weight. I hope the REs do me right like my front one have. If It's wrapping out of control I'll be back. Thanks again Mark
#17 (permalink) |
Member # 2616
Has anyone had any luck with this design?
<>< <>< <>< If you have a sticker on your rig that says " Its a jeep thing you wouldent understand " you DONT understand. Last edited by Weezer; 10-14-2003 at 02:46 PM. |
#18 (permalink) | |
Member # 13576
But, it is basically just the same as the traditional traction/anti wrap bar. It just attaches in a different manner. I am not keen on it either though. Seems to me the best designs are the traditional one, and that BamBar. best way to fix that wrap, 4 link.
It ain't pretty, but it works |
#19 (permalink) |
Member # 12397
Can anybody here testify to the bambar.
Can you get vertical (well almost vertical) with all the weight on the rear axles and still get "zero axle wrap" ? I guess I just can't seem to get over the fact that it looks to me like there is still going to be some pinion pivot. Am I wrong? Are these guys drinking the Cool-Ade or am I just missing the boat?
#20 (permalink) |
Member # 4835
thats still a single position setup and yes the pinion will walk up and down.
Idealy you need somthing at top and bottom thats allows for no pinion walk. Redo your antiwrap bar. Your springs are what failed, and not from the bar. If anything a correctly engineered ladder bar will keep the springs from sagging. Last edited by "D"; 10-14-2003 at 03:40 PM. |
#21 (permalink) |
Why would a ladder bar cause the springs to flatten out. Wouldn't that more likely be just from use. And if it is from the ladder bar how would a setup like this:
be much different. Looks pretty much the same to me except that without the "ladder" structure it would prolly just bend.
http://www.blackstar-racing.com/ |
#22 (permalink) | |
Member # 17311
Q
Nex Pro Evinco "Death Before Defeat" |
#23 (permalink) | |
Member # 5060
Re: Alternative to Anti-wrap Ladder on SOA CJ
Are you running properly placed bump stops to limit negative arch? ANd what do you mean by "customized stock" YJ springs? If you had them re-arched or soemthing I would say thats your problem... Personally I'm running a ladder bar with 2.5" lift springs with no problems with plenty of use...don;t see how a properly designed bar would mess up one side really. MJ |
#24 (permalink) | |
Member # 2095
'79CJ5,soa,d44/60,t18,d18w/Obrian 3.6low,5.13's,35x14.5SSR's '02 Z71 |
#25 (permalink) |
Member # 7875
Everyone is saying 4 link
(so join'em) Just think about what I was talking to you about at Reiter - 2 leaf springs 4 shackles and 4 link - you can always play around with coil springs or c/o's later if you get tired of leaf springsI think that is about the only way you are going to get rid of that forced neg. arch (mine does the same thing) - Just my 2 cts Matt Bumpstops would help too....
