YJ Brake Booster Upgrades? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-26-2003, 06:36 AM   #1 (permalink)
Member # 11737
Send a message via AIM to Jeeptoy91
Angry YJ Brake Booster Upgrades?
I just got a 96 XJ dual diaphram booster thinking I could adapt it to my YJ. Its not going to fit. Has anybody found a donor vehicle for a dual diaphram booster for a YJ?
I did the master cylinder upgrade but need more line pressure. I wanted to install the booster for more line pressure.
I am driving a 1991 YJ, 4.0, Auto Tranny.
Just a YJ with some expensive parts
Jeeptoy91 is offline   Reply With Quote
Old 10-26-2003, 07:59 AM   #2 (permalink)
Member # 6589
I thought that a brake booster only helps with pushing the pedal not actually increasing brake line pressure.?
blt2crl is offline   Reply With Quote
Old 10-26-2003, 12:39 PM   #3 (permalink)
Member # 11737
Nope
The added volume of fluid stiffened the pedal and decreased line pressure at the calipers. If I boost the pedal pressure I can force more pressure on the fluid at the calipers. I can only move my pedal about 1/2 the way down now.
Old 10-27-2003, 08:05 AM   #4 (permalink)
Member # 12795
78 Mercury Marque
[URL="http://www.geocities.com/onetonyj"]http://www.geocities.com/onetonyj[/URL]
1tonyj is offline   Reply With Quote
Old 10-27-2003, 09:18 AM   #5 (permalink)
Member # 11737
What?
I got the master cylinder from that same vehicle. I thought that was a hydroboost vehicle?
Are you saying I can use the vacuum booster off the same Mercury car and its dual diaphram and will bolt up to a YJ?
PS: What's happening with the springs?
Old 10-27-2003, 11:51 AM   #6 (permalink)
Member # 12795
It works GREAT with my 4 wheel disc. Bolts on!
The spring should be here around the end of the week.
Old 10-27-2003, 01:20 PM   #7 (permalink)
Member # 9994
1tonYJ,
so, are you running both the Merc.Marque booster and master cylinder? and this bolts directly to the YJ booster bracket?
please clarify.
thanks!
matt
1984 CJ-8
1986 CJ-7
1981/1992 CJYJ
1994 RAM 1500 4x4
Custom Fabrication Parts:
[url]www.troutindustries.com[/url]
jeepnmatt is offline   Reply With Quote
Old 10-27-2003, 04:19 PM   #8 (permalink)
Member # 11737
Cool Clarify Please
Yes please do clarify. Are you running both the booster and the MS from the 78 Marquis? I am already running the MS.
Old 10-27-2003, 07:02 PM   #9 (permalink)
Member # 9467
I'm running a booster from mid 80's Chevy G30 van. The mounting bracket holes from the YJ need to be enlarged slightly as the studs are larger on the van booster. I bought the MC from JB conversions as I was short on time. Looks like it's from a Chevy truck but I haven't checked the numbers. The setup works awesome with dual piston Ford calipers on all 4 corners. Still using the stock proportioning valve and the fronts just lock up before the rears. I haven't been in another YJ with anywhere near as good of brakes.
lt1yj is offline   Reply With Quote
Old 10-28-2003, 05:21 AM   #10 (permalink)
Member # 12795
Just the MC from the Marque, the booster is Jeep, proportioning valve is Jeep.
Old 10-31-2003, 08:38 AM   #11 (permalink)
Member # 11737
Question GM Booster
Besides the bracker holes what other mods were required? Did you have to do anything with the pedal rod to connect to the pedal lever? Is the booster rod at the master cylinder adjustable?
Got pics?
Old 10-31-2003, 09:47 AM   #12 (permalink)
Member # 9467
Re: GM Booster
Originally posted by Jeeptoy91
Besides the bracket holes what other mods were required?
I had to fabricate a bracket to hold the brake light switch.
No.
No
Got pics?
No, I'm not really sure if they'd do any good but I can snap some early next week if you really want them. I think I have one of my engine compartment that may show the booster/MC. I'll look and if I do I'll post it later.
Old 11-04-2003, 09:40 AM   #13 (permalink)
Member # 11737
pics please
I would like to see the pics of the booster, MS and all installed (side view). I also would like to see how you attached the pedal to the booster rod.
Old 11-07-2003, 09:26 AM   #14 (permalink)
Member # 9467
Here's one I had on my computer. Not a really good shot but all I had now. I'll take some more this weekend.
Old 11-07-2003, 10:45 AM   #15 (permalink)
Member # 11737
Talking Cool
Thanks.
