Member # 2949
My YJ has the shakes bad! So bad it cracked my front windshield. I've checked U-joints, axles and ring and pinion. Could it be the springs? whatever the problem it's cause some bad axlerap! Any suggestions?
Got .45?
Member # 9274
the front end shakes? if so its called death wobble. have fun trying to cure it! it could be a million things adding up to lots of slop, or it could be one thing. search for Death Wobble, you will find tons of info.
what size tires? what front axle? what steering? what springs? these all factor into the DW equation.
94 YJ w/ 5.3L, TH400, Atlas, and 42" Pitbull Rockers |
#4 (permalink) | |
Doublewide engineer
Member # 6971
Wow, lot of info there, are we supposed to mysticaly cure it for you? Bent wheel, seperated cord in tire, out of balance tire, flatspotting in mornings, bent shaft, bad shocks, worn bushings... How the fawk is it set up? Fawkin dan's
I'm the "tack tack tack" welding nazi. http://www.pirate4x4.com/forum/showp...&postcount=218 ![]() "I didn't mean to kill nobody ... I just meant to shoot the sonofabitch in the head. Him dying was between him and the Lord." R. L. Burnside |
#5 (permalink) | |
Got .45?
Member # 9274
jesus, you are just a plethora of discription... what kinda tires? wheels? axle? bent DS? no wait fawk it, i am done helping your ass.
Moderator
Member # 5861
dude, what lift you have, slip yoke eliminator in the transfer case? propoer shimming and angle in teh rear axle, etc etc???? if you want help, please be more descriptive on your problem.
G |
Ah, the notorious Death Wobble. It can be caused by so many things it's not even funny. Worn suspension components.... all sorts of things. Assuming it's not related to your tires/wheels, which is a whole other set of new problems. We need more info.
