HP60 Standard cut - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-07-2003, 03:24 AM   #1 (permalink)
Snatch Block's Avatar
Member # 11285
Red face HP60 Standard cut
It there someone that makes a standard cut ( rotation) for a HP D60? I am looking to put one on the rear of ma heep.
While your down there, mind giving a ring job?
Snatch Block is offline   Reply With Quote
Old 11-07-2003, 03:46 AM   #2 (permalink)
MC
MC's Avatar
Member # 21997
Send a message via Yahoo to MC
SB Ive never heard of a hp standard cut, but if its a standard cut, just go get standard cut gears, chances are teh pinion is angled so the regular standard cut, ARE regular standard cut, i even sell those
Industrial Quality CNC machines at a Hobby Price!
USA Quality is job #1
We build CNC plasma tables, click me
American Motors Engine HERE!!
1-651-257-7917
MC is offline   Reply With Quote
Old 11-07-2003, 04:03 AM   #3 (permalink)
Member # 11285
What ring and pinion does Danatrac and Currie use
Old 11-07-2003, 04:49 AM   #4 (permalink)
speedo's Avatar
Member # 23262
Re: HP60 Standard cut
High pinion and low pinion both rotate the same direction. The
high pinion isn't reverse rotation it is just cut the opposite
direction so that the pinion will drive on the drive side of the
gear and not the coast side like a low pinion does when used
in the front.
Gus
speedo is offline   Reply With Quote
Old 11-07-2003, 06:19 AM   #5 (permalink)
Member # 11285
Re: Re: HP60 Standard cut
in the front.
Gus
Yes, but when you put a HP in the rear it rotates on the weaker side of the gear. So like I was asking, does someone make a standard cut ring & pinion ( like in a rear Diff) for this.
Old 11-07-2003, 06:22 AM   #6 (permalink)
speedo's Avatar
Member # 23262
Re: Re: Re: HP60 Standard cut
No
Old 11-07-2003, 06:27 AM   #7 (permalink)
Member # 15992
there was a thread about this not too long ago. someone was going to try to make them. IIRC it got nixed.
i can go everywhere everyone else does -- the new england mantra
kjp98TJ is offline   Reply With Quote
Old 11-07-2003, 06:29 AM   #8 (permalink)
Member # 11285
Re: Re: Re: Re: HP60 Standard cut
No
Ok, Kind of dumb though. Alott op people are/ have done this. So that being said, has anyone with a HP in the rear broken the gears?
Old 11-07-2003, 06:51 AM   #9 (permalink)
P&T Jeeps's Avatar
Member # 3916
how much HP/gearing do you have? a RC D60 can handle some pretty good torque....
TJ; ARB'd & ChroMo'd 1-tons; 42" IROK's; Atlas 4.3; 4-linked, 106" WB...
The Build
P&T Jeeps is offline   Reply With Quote
Old 11-07-2003, 06:55 AM   #10 (permalink)
Member # 11285
Nothing major (4.0) , I am just asking because I know that the torque will be on the weaker side of the gear. I busted a D60 F.F axle shaft with a 4.0, lock right /4.10 gears and 38.5 SX's.
Old 11-07-2003, 07:09 AM   #11 (permalink)
P&T Jeeps's Avatar
Member # 3916
I'd bet you broke a stock 30 spline shaft which isn't too hard to do. But you should be fine on your worries of destroying a D60 R&P w/ that setup, IMO....
The Build
Old 11-07-2003, 07:16 AM   #12 (permalink)
Member # 11285
You are right on the 30 spline.
Old 11-07-2003, 07:16 AM   #13 (permalink)
Member # 940
I busted the ring gear on my HP60 on about the 3rd trip out but feel it was due to a bad gear set not the design. i have ran for years no on the set i replaced that 1st one with and have had no problems. A friend of mine runs a 472 big bolck with a 4 link rear going to 39.5X18 boggers and has yet to bust one. From the torque he has been able to get the pinion nut to loosen and have the pinion start driving into the carrier.
WWW.PCRYO.COM
Deep Cryogenic Tempering Service
Find all my products at
www.KICKASSOFFROAD.COM
916-434-6978
Custom Axles built to order.
Got 40 spline? I have the hubs, spindles, and axles you need to kickass!
Custom Hummer wheels and centers
Axle Resplining
66CJdean is offline   Reply With Quote
Old 11-08-2003, 10:43 AM   #14 (permalink)
Member # 20092
I was going to say the only thing to watch for are the HP gears that use a crush sleeve. I don't think it would be a good idea to use that style, it would be better to use HP gears that use shims to set the preload on the pinion.
A HP gear in a rear axle application drives on the coast side of the gears, which is no problem for a HP Dana 60. There are a lot of guys running HP 60s in the rear and don't break the gears.
The biggest issue is oiling. You can't go crazy with pinion angle.
The second biggest issue is the load placed on the front pinion bearing when used in a rear axle application. As the rig goes forward, the pinion will try to pull itself in towards the carrier when torque is being applied to the drive shaft. That little pinion bearing has to hold the pinion in place, and if there is a crush sleeve involved, then the pinion will try to crush it even more than what it was set at. A arge enough shock load from say, dumping the clutch with a 502 big block in granny low, will probably cause that crush sleeve to give just a little and then you start to develop play in the pinion bearings. The rest is self explanatory.
hope that makes sense.
I had one for a while with a 401 and granny tranny and never had a problem. I don't think you will.
'94 Toyota Land Cruiser FJZ80 - Vortec L33 5.3l, 4L60e, elocked, 3" OME lift, 315 KM2s, Warn 8074.
rock-rod is offline   Reply With Quote
Old 11-09-2003, 02:25 PM   #15 (permalink)
Member # 11285
Talking
Awesome Gentelmen Thanks for the replys.
Old 11-09-2003, 03:43 PM   #16 (permalink)
Member # 3782
Send a message via ICQ to elusiv
I broke 2 sets of gears last year in my rear dynatrac 60. they use shims in their set up, so the sleeve couldn't have been an issue. The ring gear is shaved, but it broke in an odd way, not the entire thing..
the second gear set broke 3 months later when I plowed a rock with the rear diff and the bottom of the housing hit the ring gear.
since then I torched out the shavedsection on the housing and built the housing up a bit to accept a full size ring gear. I have had no problems since.
I run a stroked 4.0 and 5.38 gears with an atlas and 38's
~~Elusive~~
I just wanna wheel.
elusiv is offline   Reply With Quote
Old 11-09-2003, 04:49 PM   #17 (permalink)
MC
MC's Avatar
Member # 21997
hey elusive, look at your tires they are perfect, are you sure you werent doing burnouts.....LOL
1-651-257-7917
Old 11-09-2003, 05:51 PM   #18 (permalink)
Member # 3782
thats cause those are my street tires... which I havent used sinced I moved to CA...
~~Elusive~~
I just wanna wheel.
Old 11-10-2003, 07:15 AM   #19 (permalink)
MC
MC's Avatar
Member # 21997
1-651-257-7917
