89 Wrangler won't shift into 4x4 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-19-2003, 05:53 AM   #1 (permalink)
Member # 4979
A buddy of mine just got an 89 Wrangler. We took it fourwheeling @ LBL, and it did fine, other than a small carb issue. Now however, he can't get it into 4 wheel drive, the lever will not shift, and makes a good bit of noise if you try. Auto hubs and the NP231. Anybody got any tips?
Thanks,
Michael
85 4Runner on 36's - Trail Tested!
97 F250 - Tow rig
mrstang01 is offline   Reply With Quote
Old 12-19-2003, 07:45 AM   #2 (permalink)
Keith Strong's Avatar
Member # 477
Send a message via Yahoo to Keith Strong
Re: 89 Wrangler won't shift into 4x4
Dont piss into the wind
[CENTER][SIZE="5"][URL="http://www.strong-arms.com"]Strong Arms "Survival Slings" For Sale PM me for a PBB only price[/URL]
[/SIZE][/CENTER]
Keith Strong is offline   Reply With Quote
Old 12-19-2003, 08:12 AM   #3 (permalink)
Member # 18842
Re: Re: 89 Wrangler won't shift into 4x4
Thats funney as hell.
Check the Tcase linkage. After you move this to the Newbie forum.
But why is the rum gone?!?
[QUOTE=Supergper] you need to do some destructive testing to see how well you really penetrated[/QUOTE]
Rescue35 is offline   Reply With Quote
Old 12-19-2003, 06:52 PM   #4 (permalink)
Member # 20987
Send a message via AIM to ToyotaFreak
mine all you do is slip the clutch and give it hell until it engages lmao.
84 Jeep Cherokee 2 door, Ax-5/np-231, 3 inch lift, 33 inch swampers, home made cold air intake off a honda.... braaaap
Swampers Rule
ToyotaFreak is offline   Reply With Quote
Old 12-20-2003, 06:15 AM   #5 (permalink)
Member # 4979
I shoulda said I already searched, and first thing we did was check the linkage. Never piss upwind, but might up a rope.
97 F250 - Tow rig
Old 12-20-2003, 08:35 AM   #6 (permalink)
withamc's Avatar
Member # 1757
My Wrangler has an auto trans. Before I got the tranny rebuilt I had to shut off the engine and put the tranny in neutral to shift into and out of 4 LO.
Usually lost...
Eat your spaghetti
withamc is offline   Reply With Quote
Old 12-20-2003, 08:18 PM   #7 (permalink)
Mr. FixIt
DE Jeeper's Avatar
Member # 5295
Pull the t-case, inspect and re-build. It is pretty easy to do. If the case was ever run dry the plastic pads on the mode and shifter forks wear out and the chain stretches. This will cause problems. Also, I have seen the spring clips that hold together the shift mode syncronizer fail and this will not allow shifting into 4 wd. Open up a Quadratec or 4 Wheel drive Hardware catalog to get an expanded veiw of the t-case.
BTW, if pulling the t-case and rebuilding it seems too difficult for you then you are probably posting in the wrong forum.
'88 YJ with not much '88 YJ left
We-Rock Stock Class
Team Mall Crawler #609
Sponsored by:
The Drive Shaft Shop www.driveshaftshop.com
Delaware Jeep Assoc. www.delawareja.com
DE Jeeper is offline   Reply With Quote
Old 12-20-2003, 08:37 PM   #8 (permalink)
Jason R's Avatar
Member # 11598
Take said NP231 transfer case and throw it off a cliff. Then proceed to install a real tcase.
This space for rent.
Jason R is offline   Reply With Quote
Old 12-21-2003, 12:35 PM   #9 (permalink)
Member # 1441
sounds like the thermal coupler is discomboobyalated. where the seat interfaces with the input selector.
alimony: verb: The Efn ya get 4 da Efn ya got
kodak is offline   Reply With Quote
