Looking for engineering specs on 35 spline axles - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-27-2004, 12:11 PM   #1 (permalink)
Member # 16477
I am trying to find info on the actual splines of the axle.
Pitch
Pressure angle
Major & Minor Diameters
And any other specs that may be useful. I have some stuff I need broached and I can't seem to find this info.
Thanks,
Kirk Oden
tkojeep is offline   Reply With Quote
Old 01-27-2004, 12:13 PM   #2 (permalink)
LOPPY's Avatar
Member # 1108
Have you tried Billavista's site? He's pretty damn thorough. Try there.
Those who forge their swords into plows will plow for those who do not.
LOPPY is offline   Reply With Quote
Old 01-27-2004, 01:54 PM   #3 (permalink)
Member # 13232
Send a message via AIM to nosliw Send a message via Yahoo to nosliw
try search for "involute spline" i was researching this a while back and can't remember who it was that posted up some sweet info on common pressure angles. if i remember right, most dana axles are 30 degrees.
i've tried drawing them up a time or two, but end up running out of time or get tired of fawking with it.
the machinery's handbook has a good section on involute splines as well, but from what i've found, lacks drawing info.
12 valve farm truck.
nosliw is offline   Reply With Quote
Old 01-27-2004, 06:27 PM   #4 (permalink)
Member # 16477
Does this sound right?
1.420 - 1.423 pilot hole
24-48 Diametrical Pitch (DP)
30* Pressure Angle (PA)
Kirk
Old 01-28-2004, 11:00 AM   #5 (permalink)
Member # 13232
the diametrical pitch and the pressure angle sounds right...not sure on the diameters
