AMC 20 gear set up (problems) - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-15-2004, 02:38 PM   #1 (permalink)
shaka 55's Avatar
Member # 17224
alright heres the deal. We are putting a 80' FS cherokee axles under my buddies 94' YJ.
The rear is a amc 20 and we are putting in 4.88's .
Here is the problem:
got the new pinion gear in and used the stock shim to get it close(we thought) and them set the carrier in with the stock shims it used to get it close( we thought)
The teeth barely mesh togather I shimmed it all the way over to engauge the gears farther but they are still only engauging about half way.?
I don't see what we are doing wrong.
here is what questions I have:
1) Does the Cherokee amc 20 take a different gear set then the amc 20 in a cj?
2) Will this carrier accept 4.88's ( we pulled 2.73's out, wered part is they were 41/15 R&P and a drivetrain website said they would be 30/11?)
3) if this gear ratio doesn't work in this housing because it came with a numerically too high of a gear, Does someone make a ring gear spacer to make it work (similar to the Dana 61 problem)?
ANY help would be great!
85 EFI 4runner
69 fj-55,76 fj-55
96 Taco
08 F-350
shaka 55 is offline   Reply With Quote
Old 02-15-2004, 02:59 PM   #2 (permalink)
Member # 7163
Re: AMC 20 gear set up (problems)
Randy's Website
M20 2.73 & down / 3.07 & up
Oxjockey is offline   Reply With Quote
Old 02-15-2004, 03:13 PM   #3 (permalink)
shaka 55's Avatar
Member # 17224
ANyone have any real information
Thanks for looking up what I already know
What I want to find out is why my gear count are so far off and if you can make these gesrs work with a ring gear spacer. (again, like the DANA 61)
NOW, would someone chime in that accual has some first hand experience.
Jesus Christ I'm not a newbie
85 EFI 4runner
69 fj-55,76 fj-55
96 Taco
08 F-350
Old 02-15-2004, 03:39 PM   #4 (permalink)
greasyjeep's Avatar
Member # 15997
Send a message via AIM to greasyjeep
I think he did answer one of your questions.
the carrier won't work, the break was at 2.73/3.07.
Is there a spacer out ther, not sure, but it may be cheaper/easier to find a carrier for 3.07 ^.
I am pertty sure (95%) that an AMC 20 is an AMC 20 and it doesn't care what it came under.
You can go post a wanted add at IFSJA for a carrier and probably get a good response. Those guys are very responsive and have lots of stuff like that laying around.
josh
[URL=http://www.simbur.com/toyota4runner.htm]4runner[/URL]
greasyjeep is offline   Reply With Quote
Old 02-15-2004, 04:20 PM   #5 (permalink)
Member # 7163
I have setup these diffs, and did not have to come on here asking if the carrier I was using was the one I needed. How much more first hand experience do you need?
If you know so well, why did you ask? I wouldn't use a spacer, I'd use a thicker gearset if it's available...but you'd might want to ask someone who actually knows.
Old 02-15-2004, 04:26 PM   #6 (permalink)
HybridPOS's Avatar
Member # 14442
Send a message via Yahoo to HybridPOS
you need a new carrier, the correct one for that gearset.... Brainiac.
The Waggy and CJ housings are the same, only difference is the tubes and axles.
83 CJ-7, 360 .030 over, shaved heads on the pane.
105 inches of noise and booger welds.
HybridPOS is offline   Reply With Quote
Old 02-15-2004, 04:30 PM   #7 (permalink)
Member # 18842
Get a full locker or a new carrier.
But why is the rum gone?!?
[QUOTE=Supergper] you need to do some destructive testing to see how well you really penetrated[/QUOTE]
Rescue35 is offline   Reply With Quote
Old 02-15-2004, 04:36 PM   #8 (permalink)
Member # 20092
You definitely need a different carrier. The 2.73s used a unique carrier, while all the other gears used a different carrier.
Ask me how I know
'94 Toyota Land Cruiser FJZ80 - Vortec L33 5.3l, 4L60e, elocked, 3" OME lift, 315 KM2s, Warn 8074.
rock-rod is offline   Reply With Quote
Old 02-15-2004, 04:38 PM   #9 (permalink)
Member # 12491
I've got a stock AMC20 carrier I pulled out to put in detroits. Originally was a 13:43 gearset (3.31 ratio). It's the carrier size you need, stock open gears, never had a locker in it.
I could strip it down and sell it to you, but shipping might suck, try to find one closer first.
CP
CP8071 is offline   Reply With Quote
Old 02-15-2004, 05:34 PM   #10 (permalink)
Member # 16362
I have a factory posi you can have cheap if you want to drive down and get it. The AMC 20,s are a pain because they only have 3 shims. I was working on one today, and the Superior gear install sets do not have enough shims ( how the f you going to put a factory .095 in the mix!). You can get clutch pack and shim pack cheap from Randy's
86 CJ7, OX's/4:56, 4:1, RE Extreme, MORE SR, Howell FI, Just Empty Every Pocket.
jessejeep is offline   Reply With Quote
Old 02-15-2004, 07:53 PM   #11 (permalink)
JeepinIan's Avatar
Member # 2510
I had a 1/4" spacer made for the AMC 20 in the rear of my CJ when I went to 4.10's. Works great
[url=http://www.jeeptalk.net/]Florida Jeep Forum[/url]
It is much easier to suggest solutions when you don't know too much about the problem.
- Malcolm Forbes
"I've been accused of vulgarity. I say that's bullshit." ---Mel Brooks
JeepinIan is offline   Reply With Quote
Old 02-17-2004, 09:45 AM   #12 (permalink)
shaka 55's Avatar
Member # 17224
Is that a ring gear spacer your talken about? Give me some more info on this.
Also, sorry Ox jockey! I shouldn't have flew off the handle but I was a little when I set the gears up in the housing and found out they didn't even mesh. I was really mad because it's my buddies axle and he didn't do the research to figure this shit out before giving me the axle to regear I had never seen a pinion gear that big before
Anyway, I apriciate the help from you guys and this is all good info. If I can't find a carrier all let you guys that posted know.
85 EFI 4runner
69 fj-55,76 fj-55
96 Taco
08 F-350
Old 02-17-2004, 12:25 PM   #13 (permalink)
JeepinIan's Avatar
Member # 2510
Yeah, I had one made that went between the ring gear & the carrier.
That was 7 or 8 years ago, w/ a lockrite in it, and no problems yet w/ the set up. I still run it on the street. My problem is abent tube!
- Malcolm Forbes
