diesel in a YJ???? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-15-2004, 12:37 PM   #1 (permalink)
Member # 26356
diesel in a YJ????
so what would it take to put a diesel in a YJ? i did some searching and no one has posted about it. just curious if it's even possible. with rising gas prices, a diesel would be nice.
[QUOTE=EndlessMtnFab]
When you've been doing it as long as some of us have ... then you have the right to get cocky. Until then ... wipe mom's milk off your chin. [/QUOTE]
95 YJ <-- the build
87 YJ <-- the DD
C_I_A is offline   Reply With Quote
Old 03-15-2004, 12:43 PM   #2 (permalink)
Member # 26890
Nope
Definatly not possible. I wouldn't suggest it at all. I think it's actually kinda silly.
Yes, it is possible, it's not like swapping in a chevy 350, it isn't bolt up, and will require welding and modification.
1985 CJ-7 SD-33T Nissan Diesel
1977 CJ-7 236 Perkins Diesel
DieselCj is offline   Reply With Quote
Old 03-15-2004, 01:10 PM   #3 (permalink)
Member # 14731
Apparently, there is a 4 cyl diesel version of the Liberty coming out next year. You might see if you could find any info from there. That doesnt really help you right now, but if you were thinking of doing it in a year or two, might be a possibility.
Road Head is offline   Reply With Quote
Old 03-15-2004, 01:46 PM   #4 (permalink)
Member # 13582
www.michiganjeepers.com screename deiselyj he may also post here, not sure.
www.misfitoffroad.com
UP_ROKTOY is offline   Reply With Quote
Old 03-15-2004, 01:46 PM   #5 (permalink)
Member # 10411
Send a message via AIM to Spike5421
this subject has been talked about you should search harder. Also, from what i remember, it was concluded that a diesel would wieght too much to swap in and that if you found a small one you could forget about driving at speeds above 50. There are just better options for torque and horsepower. Just my .02
82 Cj7 (SOLD)
'04 4wd Taco, S/C, Allpro 3.5", 4.88 gears, ARB bumper, Warn, rocker guards.
Spike5421 is offline   Reply With Quote
Old 03-15-2004, 01:49 PM   #6 (permalink)
Member # 13582
apparantly you didnt search either..... anyway here are various posts by dieselyj
http://www.pirate4x4.com/forum/searc...der=descending
Old 03-15-2004, 03:25 PM   #7 (permalink)
Member # 12795
THIS:
[URL="http://www.geocities.com/onetonyj"]http://www.geocities.com/onetonyj[/URL]
1tonyj is offline   Reply With Quote
Old 03-15-2004, 03:32 PM   #8 (permalink)
Member # 26890
Wow you guys really nailed it.
I got my diesel engine transmission and transfer case for $700. It doesn't weight a ton, yes it does weight more than your stock engine. But it gives you power where you need it, at the bottom of the RPM's.
Speeds above 50? I can easily hit 65-70, and that is with 101hp, 33x12.5 BFG MT's, 4.10 gears, and a 1 to 1 output on the transmission. If I had an overdrive, higher speeds would be no problem. I just don't have the time or money do put in an overdrive.
It is not a swap that is out of the question. I think it's a great one, I can go places much easier than a lot of guys with gas since I just idle up with tons of torque.
If you want more information about diesels in SUV's check outBinder Bulletin
Just don't tell them that you are going to put anything in a jeep. They don't like jeeps at all.
Old 03-15-2004, 03:38 PM   #9 (permalink)
nilla's Avatar
Member # 9017
i had a sd33t in my yj. hated it, pulled it out, and put a 383 stroker in it. all better now
AKA "NEO"
Team Branik Motorsports/Badlands #518
Spotter/Co-Driver for Brandon "Dino" Haynes in XRRA, KOH, TREC Series
Thanks to our sponsors:
Branik Motorsports,Badlands Offroad Park, Bulldog Winch, Greatlake Offroad, Fort Wayne Clutch, Metal Supermarkets, Superior Axle, and BFGoodrich
nilla is offline   Reply With Quote
Old 03-15-2004, 03:46 PM   #10 (permalink)
Member # 26890
Well I'm quite happy with mine. It's not going to win any drag races but it'll last forever and take whatever beating I can give it.
Old 03-15-2004, 04:29 PM   #11 (permalink)
No (.)(.) No (|)
XJUSA's Avatar
Member # 11132
Location: If I could start again, a million miles away.
Would this not be a nice engine for a YJ ? Commins 5.9 TD
Enough torque, enough HP, enough fun !
XJUSA is offline   Reply With Quote
Old 03-15-2004, 05:13 PM   #12 (permalink)
Member # 16373
And it is so big you would not be able to drive it. I have one in my 91 dodge and I have to replace the front springs every couple of years with only HWY driving.
yellowrover is offline   Reply With Quote
Old 03-15-2004, 05:32 PM   #13 (permalink)
Member # 5923
This is a local guy's YJ with a 5.9L CTD in it.
#@*?! Gravity!
Powered by Adrenaline and Driven by Insanity
Insayn is offline   Reply With Quote
Old 03-15-2004, 05:34 PM   #14 (permalink)
Member # 5923
#@*?! Gravity!
Old 03-15-2004, 05:35 PM   #15 (permalink)
Member # 5923
I should actually say it's a Dodge with a YJ tub on it.
#@*?! Gravity!
Old 03-15-2004, 05:56 PM   #16 (permalink)
Member # 17596
that is pretty nice.
is the grill sticking out further because radiator mounting issues?
hpi_jeep is offline   Reply With Quote
Old 03-15-2004, 06:26 PM   #17 (permalink)
Member # 26890
Pictures
Pics of my SD-33T CJ-7
Here are a few pics of mine, I don't have much more right now.
Old 03-15-2004, 06:32 PM   #18 (permalink)
Member # 16373
Re: Pictures
What was the donor vehicle? What all was involved in the conversion?
Old 03-15-2004, 06:39 PM   #19 (permalink)
Member # 26890
This is the 2nd one I did, so I took the easy way out. The donor was an International Scout 1980. I took the whole drive train, engine, transmission, and transfer case and just slipped it into the jeep. Put in new drive shafts, motor mounts, and a custom skid plate, and other odds and ends.
The other jeep I did, I don't have any pics of is a 236 Perkins Diesel. That engine was out of a street sweeper, and I had to customise the bellhousing, hooked it up to an F-150 transmisson/transfer case. It was my first swap, and so it took a lot more work, and didn't turn out as well.
I have considered once I graduate college opening a shop in Delaware to do Diesel Jeep conversions. I think if I can get it started there will be a market for it.
Both jeeps get 20-25 mpg with 33" tires.
Old 03-15-2004, 06:52 PM   #20 (permalink)
Member # 5923
I would imagine the YJ engine bay isn't quite big enough for a CTD, fan and radiator.
#@*?! Gravity!
Old 03-15-2004, 06:54 PM   #21 (permalink)
Member # 17293
The 4bt Cummins I put in my '91 YJ runs great. It won't run with a stroker v-8 but it'll put a 4.0 ho on the trailer, you could say it smokes 'em. Stock ratings are 105 hp, and 325 lb/ft torque. Its tweaked in a few ways to probably around 170 hp and 500 lb/ft torque. Decent power in a yj. It works great offroad with too much low end power, the stock axles didn't stand a chance. At idle if a tire didn't slip on a climb it would simply just snap the axleshaft like a twig. On the street the Jeep is way more fun to drive. The torque of the motor pushes the box shaped Jeep pretty well at any speed, I've had it around 95-100 mph with a little speed left to go if you felt like pushing it further. I was running a nv4500 from a '98 dodge. Worked fine but I just switched to a 727 auto. Haven't driven it with the auto yet.
As far as weight goes, the 4bt weighs just a little more than a straight 6 or v-8. I noticed no difference in front end ride height over the factory 4.0. I would definitly swap another, if not for the more power, but it gets well over 20 mpg also.
Tow unit:'91 Dodge 250 4X4,6bt Cummins
Trail unit:'91 Jeep YJ,4bt Cummins
dieseljeep is offline   Reply With Quote
Old 03-15-2004, 08:08 PM   #22 (permalink)
ibrocun's Avatar
Member # 26196
Send a message via Yahoo to ibrocun
You're right about the market for it, but I bet that market would be bigger on the west coast.
You are entitled to your own opinion. You are not entitled to your own set of facts.
ibrocun is offline   Reply With Quote
Old 03-16-2004, 12:07 PM   #23 (permalink)
Member # 16373
Originally posted by dieseljeep
The 4bt Cummins I put in my '91 YJ runs great. It won't run with a stroker v-8 but it'll put a 4.0 ho on the trailer, you could say it smokes 'em. . I would definitly swap another, if not for the more power, but it gets well over 20 mpg also.
what do you get a 4bt out of, a skid loader?
Old 03-16-2004, 03:43 PM   #24 (permalink)
Member # 17293
The 4bt came out of a Frito Lay truck. They are used in just about anything, trucks, tractors, hoes, you name it.
Old 03-16-2004, 03:53 PM   #25 (permalink)
JJSBADYJ's Avatar
Member # 14155
Send a message via Yahoo to JJSBADYJ
a few years ago there was a YJ at the Run-A-Muck event held in July just outside of Truckee. I dont remember his name I just remember he stuffed a CTD or a CAAT under the hood. He had louvered the hood and also had a few scoops to try to keep it cool. He said he would get 20+ mpg at 70+ no problem. It is possible just a little more work.
JJ
JJSBADYJ is offline   Reply With Quote
