5.0 tech - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-22-2004, 05:35 PM   #1 (permalink)
Member # 28458
5.0 tech
whats the difference between 93 5.0 mustangs wire harnes and a 93 crown vic 5.0 ho if any
zero is offline   Reply With Quote
Old 03-22-2004, 06:15 PM   #2 (permalink)
Member # 7730
The MAF wiring may be different as I think the air filters are on opposite sides.
RepoMan is offline   Reply With Quote
Old 03-22-2004, 06:24 PM   #3 (permalink)
Member # 18211
i dont believe the vic ever came with an HO... by 1993 i am almost positive the new style vic of that year had a 4.6 SOHC...
If you are sure it is a 93 vic with an 5.0 HO, is it a cop package, or did someone swap it in?
Either way the harnesses will be FAR different than a civilian mustang 5.0.
1979 CJ5/GM350/T150/D20/D44/9"/33x12.5
281 Quad Cam is offline   Reply With Quote
Old 03-22-2004, 06:44 PM   #4 (permalink)
Member # 7730
Good catch, '93 crown vic would be the 4.6L.
Old 03-22-2004, 06:48 PM   #5 (permalink)
Member # 28458
it may be an 92 but it is an 5.0 h o it is still in car i will check vin plate tomarrow
Old 03-23-2004, 07:56 AM   #6 (permalink)
Grandpa Jeep's Avatar
Member # 1868
Send a message via MSN to Grandpa Jeep
Pretty sure the crown vic never came with an HO. The difference in wiring would be the HO has sequential fired injectors and the non-HO is bank fired.
'50 CJ-3A, SVO Turbo 2.3L, T-98, D18, Warn OD, PTO Winch, D30, FFD44, lockrites in both
Jeeps, they're not just a hobby, they're a freakin adventure :D
:usa:
Grandpa Jeep is offline   Reply With Quote
Old 03-23-2004, 04:45 PM   #7 (permalink)
Member # 20092
Another tidbit of info: the crown vics also used 14 lb injectors and a different firing order. The cam used in these cars is the same as the vans, trucks, and any other low-po application. The good news is that at least it's a roller cam and it can be upgraded.
'94 Toyota Land Cruiser FJZ80 - Vortec L33 5.3l, 4L60e, elocked, 3" OME lift, 315 KM2s, Warn 8074.
rock-rod is offline   Reply With Quote
