got a hard on! - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-10-2002, 09:06 AM   #1 (permalink)
P&T Jeeps's Avatar
Member # 3916
Thumbs up got a hard on!
Call me late, but I finally got a look at the WJ passenger side knuckle. That is FAWKIN' cool! Really you only need the pass side, so one should be able to save some cash.
I'm fired up! Go check one out to make your day brighter!
TJ; ARB'd & ChroMo'd 1-tons; 42" IROK's; Atlas 4.3; 4-linked, 106" WB...
The Build
P&T Jeeps is offline   Reply With Quote
Old 01-10-2002, 09:22 AM   #2 (permalink)
Member # 4228
Send a message via AIM to AGGIECJ-7
just out of curiosity, what ni the heck are you talking about?
Steven W
My Website
82 CJ-7 - SOA, geared, locked, 35's
02 Ram 2500 - Cummins, 4x4, 6spd
AGGIECJ-7 is offline   Reply With Quote
Old 01-10-2002, 09:33 AM   #3 (permalink)
Not sure if serious
HighHooder's Avatar
Member # 1899
Location: Tacoma, Wa Where you can drink the water, but don't breath the air
put that thing away
I was the five hundred and fourty-second signer of the JV petition, what number were you?
HighHooder is offline   Reply With Quote
Old 01-10-2002, 09:33 AM   #4 (permalink)
P&T Jeeps's Avatar
Member # 3916
High-steer setup for D30 knuckles. It has two separate mounting points for the draglink and tierod.
Bolt it up to your D30 inner knuckle. Then all you have to do is run the draglink to the higher mount and drill out the lower mount to bolt up the tierod above the knuckle.
The Build
Old 01-10-2002, 10:31 AM   #5 (permalink)
Member # 3541
Any Pics???
Any pics of one either installed or not?
Mugsy is offline   Reply With Quote
Old 01-10-2002, 10:59 AM   #6 (permalink)
FNG
Member # 100
Send a message via ICQ to FNG Send a message via AIM to FNG Send a message via Yahoo to FNG
Call Scott at www.rockstomper.com
Somebody said he tried and couldn't get away from the bump steer. Didn't talk to him myself, so you may want to.
BTW, did you know that the WJ's bolt pattern is 5 on 5"? Strange, huh?
John
FNG is offline   Reply With Quote
Old 01-10-2002, 11:59 AM   #7 (permalink)
Imkunfused's Avatar
Member # 2804
Send a message via AIM to Imkunfused Send a message via Yahoo to Imkunfused
I just called my friend at the dealership.. if the hub assemblies are the same where they bolt onto the knuckle, all you have to change, would be the knuckle, but hes not for sure, because hes never seen it.. those knuckles are expensive, my cost on them is 245 a piece. damn... hmm i might call a wrecker but who knows if they have them yet
james
A conscience is what hurts when all your other parts feel so good
Imkunfused is offline   Reply With Quote
Old 01-11-2002, 05:58 AM   #8 (permalink)
Johann's Avatar
Member # 4251
Anyone know what the bolt pattern for the wheel bearing assembly is? If its not the same as a other D30s (XJ, TJ etc...) it might complicate the swap.
I know I'd like to do it for my crossover steering . At least on my XJ- raising the draglink connection on the knuckle would help solve what bumpsteer I have with my current hi/low drag-tie rod heim setup. Then I might not need to make a trackbar drop bracket.
Thanks for the info
Details removed for clarity
Johann is offline   Reply With Quote
Old 01-11-2002, 06:38 AM   #9 (permalink)
Member # 2147
Send a message via AIM to mbryson Send a message via MSN to mbryson
Bolt pattern is 5 on 5" I believe. Different than the CJ (5 on 5.5") or YJ-XJ-TJ-ZJ pattern at (5 on 4.5")
-It's a "real" Jeep TBI 350/700/D300 60/14 bolt 40" Kevlars
[url]www.marbryson.com[/url]
mbryson is offline   Reply With Quote
Old 01-12-2002, 01:28 PM   #10 (permalink)
Supergper's Avatar
Member # 2159
Send a message via ICQ to Supergper Send a message via AIM to Supergper Send a message via MSN to Supergper Send a message via Yahoo to Supergper
You are talking about wheel bolt pattern and they are talking about bearing bolt pattern...the XJ TJ YJ D30 have like three bolts holding the bearing assembly on...if you look at the back of your knuckle you will see the bolts we are referring to...they are 12 point
-Caleb Call
Supergper is offline   Reply With Quote
Old 01-12-2002, 06:10 PM   #11 (permalink)
P&T Jeeps's Avatar
Member # 3916
Exactly, the wheel bolt pattern ot the WJ doesn't matter. The hub should unbolt (w/ the 3 mentioned bolts) and then you bolt up your exixting hub w/ the 5" x 4.5" bolt pattern.
I was staring a a buddy of mine's 2wd WJ. I'm pretty sure they will work too. I told him if he wakes up and part of his axle is missing its me so don't call the cops...
The Build
Old 01-12-2002, 10:00 PM   #12 (permalink)
LOPPY's Avatar
Member # 1108
Oh NO! Not another turd polishing post!
j/k you guys. It happens. Your all but gone from POR for a few months, get a new puter at home, have some 's and the smack comes back. Have fun. You'll learn someday.
Those who forge their swords into plows will plow for those who do not.
LOPPY is offline   Reply With Quote
Old 01-12-2002, 10:15 PM   #13 (permalink)
P&T Jeeps's Avatar
Member # 3916
Loppy, what are you talking about?
The Build
Old 01-12-2002, 10:42 PM   #14 (permalink)
Imkunfused's Avatar
Member # 2804
Damn you jeff... its a little harder for us tj guys to swap axles
im thinking about doing it, so if im going to polish a turd, im gonna make it nice and fawkin shinny
Old 01-12-2002, 10:51 PM   #15 (permalink)
LOPPY's Avatar
Member # 1108
"polish a turd" Trying to make something of substance out of a pile of crap. Most often, effort is met with disappointing results.
Last time I was on POR at home, on the weekend was October? Computer died. I can do just about anything else but drink at work, so I'm just have'n fun.
"Bless me father, for I have sinned". Yes, I went through the stage. SYE - It's STILL a crappy 231!!! I actually spent the dough to swap a Puegot for an AX15!! Big $ to swap total crap, to simple crap!!! No more confessions.
Finally got smart. Tore out anything "Jeep" related to the drivetrain and threw a pick and pull 1 ton truck under it. Including a TBI350. . Now I get to laugh. Not AT you guys, but WITH you.
Old 01-12-2002, 10:59 PM   #16 (permalink)
LOPPY's Avatar
Member # 1108
Bweahahahahahhahaha. *THUD!* You were supposed to swing by today. What happened? Get your cast stuck to the shower? "hehehehehehe"
No worries. Been inside all day play'n with the new puter. I'm having so much fun. Comming off a 5 yr old P2, I'm blown away. This mutha kicks major ass!
Polish it. Shine it. Send it out and have it chromed! It's still a 30. . TJ smee jay. When you're serious, lemme know. We'll go pick and pull diving Loppy style.
Old 01-12-2002, 11:07 PM   #17 (permalink)
Imkunfused's Avatar
Member # 2804
Yeah yeah, try to be a 19 yr old on a fixed disablilty income. you find me a ford one ton to get the axles, and a engine, tranny and case. engine gotta be smog legal for a 97. at then buy me a lift so i can fit everything underneath, and sure, ill get a hold of you
Until then, im gonna make my 30 flat black and wish it was a 60. and swap my 35 before the 30.
and yeah sorry, i didnt wake up til 1. and well.. my computer beats your computer
i could almost park on a 37, when i was running 31's. Ill come by sooner or later.
whats this i hear about you makin ryan's jeep 1ton strong??
Old 01-12-2002, 11:20 PM   #18 (permalink)
Imkunfused's Avatar
Member # 2804
by the way, got yahoo, msn messenger or AOL lop? what nick?
Old 01-12-2002, 11:21 PM   #19 (permalink)
LOPPY's Avatar
Member # 1108
Just give'n ya sheeite dude. Been there, done that. Built it, rolled it. I remember being young, single, poor with little income. Now I'm married, have a big house, big mortgage, two kids and I'm STILL poor . Nothing changes. The size of your income just keeps up with the size of your bills. bills!!
I'm sure your puter stomps on mine. . You can tell me all about it as I park on your hood.
Yeah. Rod (aka RYSYJ) is going under the knife here soon. The short shaft for the T18 should be on his doorstep by Monday. A built F44 (Moser's and 727's ) and 31 spline 9" are being dropped off tomorow. He's also got the 3.15:1 gearset comming for the 20. Then we're gunna do SOA on his 4.5" RE extreme duties on 38's. She's gunna be a big mo fo. Stay tuned...
Old 01-12-2002, 11:24 PM   #20 (permalink)
Imkunfused's Avatar
Member # 2804
DAMNNNNNNNN.. you bastard, kid's now the small guy, you need to get me in the club so he can feel better
Old 01-12-2002, 11:24 PM   #21 (permalink)
LOPPY's Avatar
Member # 1108
Nope. Should I? My home email is: loppy@pdqnet.com
Old 01-12-2002, 11:25 PM   #22 (permalink)
Imkunfused's Avatar
Member # 2804
park on my hood and you will roll
i already had front end damage, and no mo for me
Old 01-12-2002, 11:26 PM   #23 (permalink)
Imkunfused's Avatar
Member # 2804
yeah get yahoo messenger. me, kid, and keith are on it.. easier way to talk back and forth
Old 01-12-2002, 11:27 PM   #24 (permalink)
LOPPY's Avatar
Member # 1108
Kid's ALWAYS been the small guy. I think you're getting tainted information . I was the first one to "go big". Been that way for over a year.
Old 01-12-2002, 11:28 PM   #25 (permalink)
LOPPY's Avatar
Member # 1108
Wanna bet?
