Project "BDR" 98 tj ls1 full tube chassis fabricated 9s - Page 5 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-08-2017, 07:49 PM   #101 (permalink)
GIJEEPN
DriverJC's Avatar
Member # 135100
Looking AWSOME. you are definitely and artisan.
DriverJC is offline   Reply With Quote Quick reply to this message
Old 03-10-2017, 04:38 AM   #102 (permalink)
Member # 557906
Would you be willing to share your paint color? I'm ready for paint on my rig but have been going back and forth between a blue or green. Really like your color choice! Oh and great work by the way!
BAH07 is offline   Reply With Quote Quick reply to this message
Old 03-10-2017, 06:50 AM   #103 (permalink)
Member # 161721
It is camero synergy green. I also had a hard time deciding on a color so I asked my buddy Jeff "abigassbowtie" and he recommended the color. I think he nailed it. The color is looks amazing in person.
jeepyj2000 is offline   Reply With Quote Quick reply to this message
Old 03-12-2017, 03:35 PM   #104 (permalink)
Member # 78329
Hey does anything go in the holes in the bottom of the sub frame or are they drain holes
03 TJuggy project, Goatbuilt sub frame, 302, 60/shaved 14b, 42" pitbulls
Stretched TJuggy build HP60, Shaved 14 bolt, Coilovers... In build mode
JeepRocks86 is offline   Reply With Quote Quick reply to this message
Old 03-13-2017, 01:24 PM   #105 (permalink)
Member # 161721
I am guessing they are drain holes.
Old 03-13-2017, 01:37 PM   #106 (permalink)
mcutler1's Avatar
Member # 167368
Drew set it up so those holes correspond with the holes in his skid system, so you could bolt uhmw to his skid plate. (Clearance for nuts on back of his skid. )
Matt
90's throw back manche build
Last buggy Build thread;
LS2, th350, atlas 3.0, spidertrax 9's, 39's.
mcutler1 is offline   Reply With Quote Quick reply to this message
Old 03-13-2017, 01:40 PM   #107 (permalink)
Member # 161721
Duh! That makes sense thanks for sharing
Old 03-13-2017, 01:44 PM   #108 (permalink)
mcutler1's Avatar
Member # 167368
No problem. I'm considering welding them up. I won't be using uhmw. Those are the only openings in that subframe, basically sealed after I weld.
Matt
Old 03-13-2017, 08:06 PM   #109 (permalink)
Member # 78329
Matt
Makes perfect sense. Thanks.
Old 03-13-2017, 08:33 PM   #110 (permalink)
Member # 161721
I pulled the the jeep out of the shop to work on some other vehicles the other day so I figured I would snap a few pics of it outside while I was at it.
Old 03-13-2017, 10:34 PM   #111 (permalink)
Member # 236179
It looks fantastic.
Kevin
gt1guy is offline   Reply With Quote Quick reply to this message
Old 03-13-2017, 10:54 PM   #112 (permalink)
Member # 165670
Any chance you can weigh it? Curious where it ended up. Looks amazing!
My build.
rokk99 is offline   Reply With Quote Quick reply to this message
Old 03-14-2017, 03:47 AM   #113 (permalink)
Member # 168239
falkin sweet ! so clean !
chef717 is offline   Reply With Quote Quick reply to this message
Old 03-14-2017, 04:37 AM   #114 (permalink)
giles45shop's Avatar
Member # 197896
Really nice!!
giles45shop is online now   Reply With Quote Quick reply to this message
Old 03-14-2017, 06:51 AM   #115 (permalink)
Member # 161721
Thanks for all the compliments guys! I definitely plan to weigh the jeep once it is finished. I am guessing it will be right around 4500lbs.
Old 03-14-2017, 09:31 AM   #116 (permalink)
Member # 32217
Looks Great!
www.goatbuilt.com
SteelFish is offline   Reply With Quote Quick reply to this message
Old 03-17-2017, 07:23 AM   #117 (permalink)
Member # 78329
How much clearance do you have between your firewall and back of the engine? For the LS Goat mounts, it looks like they're set where they go. On the small block Ford mounts, here's a little wiggle room. Hoping to mock up the engine and trans in mine this weekend without the tub.
Old 03-17-2017, 07:44 AM   #118 (permalink)
Member # 161721
It is pretty tight. Probably 1/2" of clearance.
Old 03-17-2017, 08:13 AM   #119 (permalink)
Member # 78329
Thanks. Will have to play with mine this weekend.
Old 03-19-2017, 07:20 PM   #120 (permalink)
Member # 78329
Hey jeepyj2000, did you build yours at full bump?
03 Project Procrastination... a TJuggy Build, Goatbuilt sub frame, 302, 60/shaved 14b, 42" pitbulls
Old 03-19-2017, 07:23 PM   #121 (permalink)
Member # 161721
Yes I did.
Old 03-19-2017, 08:03 PM   #122 (permalink)
Member # 78329
Yes I did.
Thanks. I figured you did.
Old 03-20-2017, 07:20 PM   #123 (permalink)
Member # 78329
How far apart did you set your front and rear frame tubes?
At what point did you realize that you had to bend new front tubes to clear the shocks?
Old 03-20-2017, 09:14 PM   #124 (permalink)
Member # 161721
The rear part of the frame is 36" to the outside of the tubes. I think the front is around 28" I think. I realized the original front section was screwed the first time cycled the suspension.
Old 03-21-2017, 09:42 PM   #125 (permalink)
Member # 136551
This thing is rad. Can you show some detail how your rear coilovers are mounted? It appears that they lean forward pretty far but not leaned in very much. The tire doesn't get into them when flexed out? lookin for ideas on the rear of mine. Thanks
clarke2828 is offline   Reply With Quote Quick reply to this message
