5.0 HO and High amp alternators - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-02-2004, 06:06 PM   #1 (permalink)
Member # 1065
What type of high amp alternators are any of you 5.0 guys running, and how are they performing as far as amperage and reliabilty?
Ive heard that the Lincoln mark VII that came with the 5.0 HO, also had a high amperage alternator available as an option( I think it was 130 amps).
I need some suggestions and/or personal experiences with high amp alternators, for my 5.0 HO.
By the way, I am currently wired for and running the stock, externaly regulated 89 Lincoln Mark VII alternator.
Pirates of the Rubicon
Announcing is tough,..I need a beer
H8monday is offline   Reply With Quote
Old 05-02-2004, 07:18 PM   #2 (permalink)
ItsaCJ6's Avatar
Member # 6340
Location: Telluride CO, within site of of Black Bear Pass
alternator info
Jeff this place has alot of good info... Not sure if it will answer your questions..
http://www.mrreman.com/downloads.html
Here is another good info site with pic's
http://www.sloantrans.com/catalog/Al...or-Starter.pdf
http://www.alternators.com/a_auto.htm
This is good if you find the alt you want it doesnt fit...adapters
http://www.chromealternators.com/Alt...brackets_1.htm
Marc
In what appears to have been an understatement, the plant operator described the situation at the Number 4 reactor as "not so good."
Super conversion calculator website
Love and kisses, Zaphod..
ItsaCJ6 is offline   Reply With Quote
Old 05-02-2004, 07:51 PM   #3 (permalink)
ItsaCJ6's Avatar
Member # 6340
Jeff look here for options on upgrading your alt.
http://www.alternatorparts.com/ford_...grade_kits.htm
Marc
Old 05-02-2004, 08:30 PM   #4 (permalink)
withamc's Avatar
Member # 1757
94-95 GTs have a 130 amp alternator. Pretty easy swap. www.pa-performance.com sells the adapter harness for a pretty decent price.
Usually lost...
Eat your spaghetti
withamc is offline   Reply With Quote
Old 05-03-2004, 08:34 AM   #5 (permalink)
Grandpa Jeep's Avatar
Member # 1868
Send a message via MSN to Grandpa Jeep
I just swapped out my stock alternator for a 130A 3G alternator. I just had to cut a notch out of the bracket and it bolted right in. One plug was the same and the other one (the one that has the reputation for catching fire) gets replaced by a single plug and ring terminals for the stud. If I were running a winch on my mustang, I would replace the charge wires with a heavy gauge cable, but I haven't had any problems with frying the stock charge wires so far. I get far more amperage out of it than the stock alternator. No more dim lights when running the A/C.
'50 CJ-3A, SVO Turbo 2.3L, T-98, D18, Warn OD, PTO Winch, D30, FFD44, lockrites in both
Jeeps, they're not just a hobby, they're a freakin adventure :D
:usa:
Grandpa Jeep is offline   Reply With Quote
Old 05-03-2004, 08:57 AM   #6 (permalink)
NnF
Member # 24467
Try North West Power Product for a good HD, high output Alternator.
http://www.wranglernw.com/
I plan on their 200 amp unit almost bolt in, but they have a 190 amp unit that is a bolt up to the POD of the 5.0.
They also have HD Eco-Tech Alternators for Trucks (250 amps @ 2300 rpm), like you would find on an ambulance or emergency vehicle.
NnF
Scrambler 1982 / Ford
NnF is offline   Reply With Quote
Old 05-03-2004, 04:09 PM   #7 (permalink)
Member # 3013
I just threw a Powermaster on mine, for now.
Dude, did you get my PM? I thought you fell of the face of the earth.
"Instead of being a trail guide, you should put on a clown suit and give pony rides at kids' birthday parties"
94 YJ. 5.0 HO, NP435, NP-203 W/3.2:1/NP-205 WMS doubler, Bilstein/Alcan suspension, 104" WB.
60's front and rear.
doctor_G is offline   Reply With Quote
Old 05-03-2004, 06:27 PM   #8 (permalink)
Member # 1065
Yeah Doc, I got your message, and even went out and took my brand new HP camera out to the rig for some more pics of my slave set up,.... But, my desktop computer is down and Lance hasnt fixed it for me yet(you cant go wrong using the web daddy as your excuse), I went to download my pics and my old steam driven lap top that I am currently using would not except the HP download programming, and I cant send them without editing because the files are too big,. anyway, after a couple of days, I sort of forgot about it, but I left the message on my in box so that I wouldnt, eventually I think I assumed that I had answered it, and just forgot to delete it,..but now Im reminded that thats not the case,...wheeew that was a long sentence without taking a breath.
So thats the story!
In any case I havent rolled, or launched myself and my Jeep off of the planet,..."yet".
So how much was that Power Master alternator, I used a couple of them in the past on my old 4 banger and had terrible luck with their reliabilty.
Thanks everyone for the responses.
It appears that my Lincoln Mark VII 5.0 HO (my engine donor) was already set up for the higher amp version of the stock alternator, because as the dealer mechanic explained to me today, it has the double fuse linked voltage supply wires.
The links above have some great options for 200 amp 100 at idle version alternators. I think thats the direction I will go
Old 05-04-2004, 12:36 PM   #9 (permalink)
Member # 3013
H8, without going out and digging up old reciepts (from a year ago) I think I paid about $160. for it.
Thanks for the heads up about their reliability though.
I havn't tried it out yet...........I'm still working on this clutch issue.
I could probably get by without the pics of your setup. Thanks for trying.
My question is with the pushrods, did you have to lengthen the one at the slave?
When you moved your master, what did you do with it's push rod?
