#26 (permalink) |
Member # 16831
how big of holes can you fill with you tape and bondo method my willys has holes all over.
willys pickup with 4' long bed. dana 44s 375hp 465 205 front land cruiser springs buggy leaf in back with 36 tsls 83 toy stock on x terrains |
#27 (permalink) |
Moderator
Member # 5861
Hi,
Over a month now, baked in the sun, mud, etc, and the paint has been holding excellent still freaking people out trying to figure out what the heck type of Jeep I have
#30 (permalink) | |
Member # 48233
Well you obviously did read it enough times with much interest. Cuz I just read this thread drunk. Literally I'm drunk as I type this and he said he used 120 and 80 grit sandpaper YOU FAWKING TARD JUST READ. I"M DRUNK AND I READ BETTER THAN YOU!!!! |
#32 (permalink) | |
Member # 343
? And you thought by telling us we can't borrow her that you would stop this type of talk....LOL, that is funny!Good writeup....trail rigs need protection too....it is not about "looking" good but keeping her safe from the elements. More so in those states that have "moist" elements to deal with. |
#35 (permalink) |
Moderator
Member # 5861
Possibly starting another paint job in the next month, still have green od color, very tempting, nbut may be time to do some other color, any suggestions? Was thinking possibly Osha Orange, maybe another military color Navy? Desert? any suggestions? Rig will be a TJ, most likely extended wheelbase a la Unlimited style, or heck, keep it short wheelbase for a while, depending on after Xmas damage on my budget
![]() Gui |
#36 (permalink) |
Sticky Nomination!
'79 CJ5 350/3spd, D30F AMC20R,2 inch Body Lift, 1" shackle lift on 33's. A wise man once said: "I love my country. I love my freedom, and I appreciate the job our LEO's and military do. But if they are sent to take my guns, they are traitors, and will be dealt with accordingly." |
#38 (permalink) | |
Quit changin my shit
Can't do wal-mart pumkin orange rattle can. I already called dibs on that. Oh yeah, low gloss black and gloss white for the hood.
#40 (permalink) |
Member # 66647
Now, with only 12 cans are you able to cover an entire jeep with all the body on it... I'm wanting to paint my CJ7 soon as the bodywork is done but I was expecting to need about 20 cans. They are regular sized cans too.
Just a thought let me know what you think. Did you have any cans you didnt use or use up? I know you went by chaning them around, why is this? To mix the paints possible batch variations or just so you dont use the can? Thanks pm me if you need. I might post a paint kind of post about mine if you dont care, but not an step by step instruction set more like a build thread.
79 CJ-7 95 ZJ |
#41 (permalink) |
Moderator
Member # 5861
12 cans were enough for my rig, I think you coudl get away with less, but 12 gives you plenty of coverage andextra coats. I mixed the batch of cans when I could, just in case one of them was too different. The paint has survived excellent so far. I did not use the cans up to the end since they tend to sputter in the end, and saved those for areas like under the fenders and rocker guards where the paint would not be seen.
Gui |
#42 (permalink) |
Member # 50639
The Mil type paint looks cool in the pics... I used flat black on a few misc parts of my jeep and the smallest tree branch rubs tend to leave scratches. Does the semi-gloss OD hold up OK in an instance such as the one mentioned above - or did you have to spray clear over it so you don't get pin striping?
#43 (permalink) |
Moderator
Member # 5861
The OD is holding up surprisingly well, and it has been through branches, etc, even bent the front fender lip and bent it back and did not crack, etc. I think Aervoe's paint kicks butt, and has been resisting veryu well. I bought another couple boxes, so may be doing another TJ green as well
![]() Gui |
#45 (permalink) |
Member # 66647
I'll be using paint that has metel flake in it, which I'd basicly just call glitter that didn't look like fairy shit, and you can't sand it. After I use it, I wanted to clear coat it and use hand glaze and rubbing compound on it to give it a wet shine instead of a flat spraycan paint job. I think I can do it, already testing out areas on the jeep and other metel. A lot of the shine comes out of how flat the surface is. Sad thing is, the paint is white and its hard to tell so I had to put a small amount of primer on the surface, sand it off and bondo over the areas marked.
What do you think?
79 CJ-7 95 ZJ |
#46 (permalink) |
Moderator
Member # 5861
I think if you are trying in some parts it is a good start. Really depends on how you will use the rig, I personally think shiny white will get bashed up for what I do, and also scratched up, so think long arnd hard before you go deeper in this
#47 (permalink) | |
Moderator
Member # 5861
Wow, Excellent Job, came out extremely well! |
#48 (permalink) |
Member # 91654
I sent that PM to Gui with those pics to thank him for taking the time to put the write-up together. Because mine's going to be a resto-mod/Class VI light wheeler, I decided I wanted a gloss that should still be easy to touch up. The Moss Green is pretty close to the '53 Willys color I was going to pick, Willow Green Poly. He asked me to follow up with a little more info.
The primer was Rustoleum Automotive Primer The paint was Rustoleum American Accents Moss Green Satin The clear was Rustoleum Crystal Clear Enamel The progression I used was: 120 320 Primer 320 600 Paint 600 Paint 600 wet 1000 wet Paint 1000 wet 1500 wet Clear 1500 wet Clear 1500 wet Clear The total was 4 cans of primer, 13 cans of paint and 7 cans of clear. I probably could've gotten away with 2 coats of paint, and 2 coats of clear, but I bought enough to do 3 ahead of time, and just kept going. I know it was probably overboard for a rattle-can job, but it came together very well. There are just a few spots that could've used a little more prep, but it's easily a 5' job. I'm not sure I could've done better with automotive paint and a gun considering it was my first time painting. Anyway, I have no doubt anyone following the steps in this thread can put together a paint job that will surprise people. |
#49 (permalink) |
Member # 64466
looks good, I am in the middle of the same thing with Flat desert tan.
[URL="www.orvpark.com"]Superlift ORV Park[/URL] [URL="www.orvpark.com/events"]EVENTS![/URL] Hot Springs, Arkansas [URL="http://www.orvpark.com/download/trail-map.pdf"]Download the Trail Map[/URL] [COLOR="Red"][FONT="Fixedsys"][SIZE="4"]Say Hi on Facebook![/SIZE][/FONT][/COLOR] |
