power steering box - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-16-2002, 09:20 AM   #1 (permalink)
Member # 9082
Send a message via AIM to twistedspline
power steering box
Alright I did the search. I found nothing..... My powersteering pump is going out. Now that I added 35 inch tires it only works when I am moving I have a 258 engine and would like to find a replacment pump that would work with my engine. I want to try and find one at the pick and pull first but a jeep in the pick and pull in utah are non existant. So the question is........ Is there any non jeep pumps that will bolt up to the 258 engine without to many mods??? Also when this conversion is done I have a friend who is going to help me build a hydrolic assist so I need a good pump to run the box and hydrolic ram.
thanks all and I will help ya out by saying to the newbie and his dumb questions....
oh ya I know I cannot spell s#@t so go ahead and blast away.
I know i cant spell so sue me!!!
oops their goes my rusty old frame agine.
twistedspline is offline   Reply With Quote Quick reply to this message
Old 01-16-2002, 10:18 AM   #2 (permalink)
CSP
Member # 1533
Pull the pump out of any vehicle equipped with a Saginaw pump (that's what your CJ has). The only differences you might find are the port for the return line and the type of fitting used on the pressure line. Anything '79 and older will have a flare type fitting on the pressure line and '80 and newer will use o-rings. You can remove the fitting from your existing pump and install it on the donor pump. A pump from just about any GM car or truck will easily swap into your Jeep. Any other Jeep (look for Waggies/Cherokees/pickups) or Eagle pump will work also.
CSP is offline   Reply With Quote Quick reply to this message
Old 01-16-2002, 11:35 AM   #3 (permalink)
redruM's Avatar
Member # 7855
i have heard that the pump out of a caddilac works real well (it is suposedly the same as AGR)
98TJ 4.0L, Auto, 4.0 231, 60F Detroit, 61R Spool, 4 links F&R,5.38's, Hydro, Beadlocks, TSL&Boggers
redruM is offline   Reply With Quote Quick reply to this message
Old 01-17-2002, 05:03 AM   #4 (permalink)
HeyBeerMan's Avatar
Member # 4830
Just rebuild your pump. There is no reason for it not to work just fine. I'm still running the stock pump that came on my 84 Cj w/ a 258. Its been on 4 different motors. I'm presently running it with 38.5 X 14.50 swampers. Buy a rebuilt pump and swap it into your reservoir. Its only 2 or 3 bolts/fittings and a O-ring.
Make sure you flush your system! A small trans cooler on the return line will help too.
HeyBeerMan is offline   Reply With Quote Quick reply to this message
Old 01-17-2002, 10:25 AM   #5 (permalink)
Member # 9082
The rebuild will probbly be the way I go. I was just hoping I could find a junkyard unit that could put out little more pressure to help run the hydrolic assist im going to be putting in.
Old 01-17-2002, 11:00 AM   #6 (permalink)
Member # 2587
Location: 38*45.859N 120*34.534W (N. Ca) Future location of beachfront property.
rebuild it then try this: click here dumbshit! try search too!! you're welcome!
Aggro is offline   Reply With Quote Quick reply to this message
Old 01-17-2002, 10:20 PM   #7 (permalink)
Brad's Avatar
Member # 3239
Send a message via AIM to Brad Send a message via Yahoo to Brad
and get the box that has 7 6 stamped on the bottom too.
B-RAD Fabrication
TDO DYSFUNCTIONAL ROCKCRAWLERS
Brad is offline   Reply With Quote Quick reply to this message
Old 01-17-2002, 11:18 PM   #8 (permalink)
Member # 8956
Send a message via ICQ to Norhoss
I was wondering if it would be possible to increase the pumps power by replacing the stock pulley with a smaller pulley. Much like a supercharger, the smaller the pulley, the more boost it produces. But you would also need a better flow of power steering fluid, hence, do what Aggro's write-up says.
L8tr.
1983 CJ7, 2.5ton Rockwells(Detroit/Lincoln), 400 SB, TH400, NP205, Hydraulic Steering, 4-link F/R, 44" Boggers, 15x12 MRT Beadlocks
97 Tacoma 4x4, 2.7L I-4, 33" MTs, 15x8" 589s, Lock-Right(front) ARB(rear)
Norhoss is offline   Reply With Quote Quick reply to this message
Old 01-18-2002, 05:24 AM   #9 (permalink)
Member # 2587
NOT my write-up- It is from westtexasoffroad.com I just linked it.
Old 01-21-2002, 04:01 PM   #10 (permalink)
Member # 9082
Im gonna try out the wettexasoffroad.com rebuild this weekend. It should work out great and cheap to. Thanks for the info and to all yall.
Old 01-21-2002, 05:28 PM   #11 (permalink)
Team RedNeck
TheLakeRat's Avatar
Member # 3941
Send a message via AIM to TheLakeRat
Let me know how it works for you. I'm always looking for opinions on how you think it helps.
Matt Hodges, Owner
West Texas 4Wheel & Offroad
325-653-7001
1811 W. Beauregard Ave.
San Angelo, TX. 76901
Redneck is not a style, fashion, or something that occurs due to location Ė Itís way of life. You canít be one - either You Are or You Arenít. I AM.~SilverZuk
TheLakeRat is offline   Reply With Quote Quick reply to this message
Old 01-25-2002, 02:57 PM   #12 (permalink)
Member # 9082
Allright I played hookie from work today and did the wettexas modification. I also added a cooler to the system. Talk about a difference. I dont think im gonna need to rebuild the pumpanymore. I just wasent getting enough pressure from the stock system and now I have plenty. Thanks guys. Oh Aggro and Thelakerat thanks for helpin a newbie out.
