Low COG leafs for SOA - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-01-2004, 12:55 PM   #1 (permalink)
FNG
Member # 100
Send a message via ICQ to FNG Send a message via AIM to FNG Send a message via Yahoo to FNG
I want to lose some altitude on the YJ and am looking for some springs that won't sag in 6 months. Ideally something in a stock height would be what I want, trimming and such can pick up the difference.
I'm looking at the JC Whitney 7 leaf CJ stuff wondering about it. Anybody run these? What else is there out there?
John
FNG is offline   Reply With Quote Quick reply to this message
Old 06-01-2004, 01:27 PM   #2 (permalink)
Member # 14731
Get some JC Whitney heavy duty YJ replacements, and run bump stops so you don't negatively arch your spring. They will last much longer if you dont make them bend the wrong way BTW, what is your current setup.
Road Head is offline   Reply With Quote Quick reply to this message
Old 06-01-2004, 01:40 PM   #3 (permalink)
Moderator
apeters89's Avatar
Member # 7647
even though this is pretty newbie... I'm running 2.5" leafs SUA with 35's on my YJ.
Check out our new Team
Like us on
KF5EQF
apeters89 is offline   Reply With Quote Quick reply to this message
Old 06-01-2004, 01:56 PM   #4 (permalink)
FNG
Member # 100
-ish. I've got some 2.5" springs on there now, but I redrilled the hanger 1" back and up so it's more like 1.5" of lift. Way more then I need with the body lift on the Jeep.
I'd yank the BL, but the engine swap was tucked in TIGHT with it on there and I'm not in the mood to start fucking with all that again.
John
Old 06-01-2004, 03:09 PM   #5 (permalink)
Member # 11358
Send a message via AIM to AaronC
I run the JCW 7 leaf CJ7 rears. They sagged a bit in the back at first, but not too bad, and I think axle wrap had a lot to do with that since I didn't run a traction bar for a while. The front has seemed to hold up well. I've only been on a couple wheeling trips though, since I just finished the swap last fall. Anyways, I don't know if I'm just dumb or what, but it seems that the springs are a hair shorter length or something. I put a little longer (like 1-2" longer on center) shackle on the rear to let the 2nd leaf (military wrap) clear the frame better, and my shackle angle totally sucks. It's like 75-80 degrees . Oh well, I think I could clear 37 or 38's with enough trimming, and maybe some bumpstops, since I don't have any now, I know
Hell, I didn't know the 2.5 inch springs were that unstable. I was honestly thinkin of stepping up to them.
94 CJ-7, 60, HP44, 8274
AaronC is offline   Reply With Quote Quick reply to this message
Old 06-01-2004, 03:12 PM   #6 (permalink)
Member # 11358
oh yea, if you put the shackle bolt wherever you want, like I should, you wouldn't have any problem. But like I said, they are military wrapped, and might hit the frame, so mounting the bolt lower in or under the frame might be a good idea.
Old 06-01-2004, 03:30 PM   #7 (permalink)
Member # 5960
Send a message via Yahoo to LAME
the HD CJ's are good
crawl4cure.org
Rock Rash Racing #613, Trail Tampon Spotter
LAME is offline   Reply With Quote Quick reply to this message
Old 06-01-2004, 03:35 PM   #8 (permalink)
Member # 11358
They seem to flex pretty freakin well
Old 06-01-2004, 04:02 PM   #9 (permalink)
Member # 19876
http://www.full-traction.com/detail....TID=114&NOTES=
Anyone running these leafs? Have not heard to much about them. Look good on paper.
N24low is offline   Reply With Quote Quick reply to this message
Old 06-01-2004, 04:31 PM   #10 (permalink)
RCKRATZ's Avatar
Member # 2485
Send a message via Yahoo to RCKRATZ
I run the JC Whitney CJ7 Rears at all 4 corners on my rig. They flex like mad and seem to hold up pretty well. Mine are getting bent because I wasn't running bump stops and was going WAY negative with them. I run mine with no body lift and major cutting riding on 38's. CJ5 by the way. The only complaint I have about them is the spring clips, they are junk. You need to either make your own, or go to the spring shop and get some extras
Keith Ratzburg aka "El Rolo"
Ratz Racing #4821
Big thanks to the vendors that have helped us out!
Goatbuilt, South Bay Driveline, East Coast Gear Supply, Rugged Radios, 150tunes.com, Pro Comp, Raceline Wheels, FOX Shocks
RCKRATZ is offline   Reply With Quote Quick reply to this message
Old 06-01-2004, 07:22 PM   #11 (permalink)
Member # 27900
Still don't know if your running SUA or SOA??? You might want to look into RE Springs. They have both SUA & SOA in 5 and 6 leaf packs. I've been running the 1.5" SOA springs for the last year, and have had no problems sagging
mistertrustee is offline   Reply With Quote Quick reply to this message
Old 06-01-2004, 08:01 PM   #12 (permalink)
Wheelin 24/7
Beat95YJ's Avatar
Member # 22176
RE 1.5" springs are definately the way to go. Several of my friends run them and are extremely happy with them. There is a set in my CJ7, if and when I ever get it running again.
I swear sometimes this place should be called "Autism on bath salts".
:tank:
Old 06-02-2004, 05:16 AM   #13 (permalink)
Member # 613
I've built two rigs with the RE 1.5 springs both have been run hard for the past two years. The springs have held up well and done a really good job on both jeeps. My jeep is going back with the rear hd cj springs so I will see how it does.
odee is offline   Reply With Quote Quick reply to this message
Old 06-02-2004, 05:30 AM   #14 (permalink)
Member # 5960
Here are some rigs with HD Cj springs. 38.5's to 42's
crawl4cure.org
Old 06-02-2004, 01:02 PM   #15 (permalink)
FNG
Member # 100
Both actually, but the end I'm messing with is SOA. I'm getting those FT springs to see how they do. Comparable in price to the JCW stuff and they have a military wrap.
John
Old 06-02-2004, 01:20 PM   #16 (permalink)
RCKRATZ's Avatar
Member # 2485
ummmmmm so do the JC whitney's
Ratz Racing #4821
Old 06-02-2004, 01:46 PM   #17 (permalink)
FNG
Member # 100
Guess they just don't mention it
John
Old 06-02-2004, 02:06 PM   #18 (permalink)
RCKRATZ's Avatar
Member # 2485
what do you expect..... it's JC whitney for crying out loud
Ratz Racing #4821
Old 06-02-2004, 02:36 PM   #19 (permalink)
Hosejockey's Avatar
Member # 26577
are the CJ springs that are liunked in the jc whitney the same ones you have LAME
Hosejockey is offline   Reply With Quote Quick reply to this message
Old 06-02-2004, 02:39 PM   #20 (permalink)
Member # 11358
Damn Lame, thanks for the pics.
Now I can show my buddies who think that I don't have room for 38's
I don't think they understand what the sawzall is for.
But shit, I didn't think I could run 42's No sheetmetal left.
Yea FNG, I got mine from JCShitney and they are military wrapped.
Old 06-02-2004, 08:33 PM   #21 (permalink)
AKA Topper
Tuffjarhed's Avatar
Member # 14368
I know I'm a little late here, but mine is SOA with 2.5" YJ leaves from Alcan.
NEVER FORGET 9/11!!!!!
Hung like Einstein, smart as a horse.
Tuffjarhed is offline   Reply With Quote Quick reply to this message
Old 06-02-2004, 08:39 PM   #22 (permalink)
IndyCJ's Avatar
Member # 3645
So is your Mom but I don't go broadcasting it all over the internet.
IndyCJ is offline   Reply With Quote Quick reply to this message
Old 06-03-2004, 12:25 AM   #23 (permalink)
B.A.R.K's Avatar
Member # 8540
Quit being a TITTY and "JUST CUT IT" , Who gives a FAWK what you friends think.
92YJ/2.5L/HD4:1D300/F&R D44/5:38/36 SX/99"WB
Nothing is stronger than stupid...
B.A.R.K is offline   Reply With Quote Quick reply to this message
Old 06-12-2004, 11:16 AM   #24 (permalink)
Member # 26563
hey LAME, your fender trimming is just right. i was considering comp cutting but i'm starting to have seond thoughts. how did you cut your fronts? it looks like the rear is cut too. how did you roll your edges?
devil made me do it.
doomdog666 is offline   Reply With Quote Quick reply to this message
Old 06-13-2004, 08:28 AM   #25 (permalink)
Member # 11358
I will when I actually GET the tires.. unless someone else wants to fork over the cash for them, I'm content with my donor truck 33's
I could care less what people think, just like proving the fucksticks wrong
