D60: Standard vs High Pinion - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-24-2002, 04:52 PM   #1 (permalink)
Member # 6887
Who's running a Chevy/dodge/?? Standard D60 front, versus Ford high-pinion?
My CJ7's extended about 8 inches in the front with a shackle reversal and offset-centerpin springs, moving the front axle forward probably a good 5" or more.
I'd really love to do a high-pinion axle, but having to retube it for right-side diff, and the initial cost of the axle being a bunch higher is prohibiting...
So basically, is it worth it to wait (possibly a year) or should I pick up a cheaper chev housing? I doubt I'll be breaking gearsets, but is the higher pinion worth the expense, and the greater amount of work?
Who's running what?
-J
86 CJ7 Teralow4:1, 38" SXs, various other crap...
"No No not the stupid pedal!"
xBabyJesus is offline   Reply With Quote
Old 01-24-2002, 05:48 PM   #2 (permalink)
Supergper's Avatar
Member # 2159
Send a message via ICQ to Supergper Send a message via AIM to Supergper Send a message via MSN to Supergper Send a message via Yahoo to Supergper
Well especially with the extra wheelbase I wouldn't worry about the RC just get a standard...I am going to be running a RC in my Heep but only cause it is a wrangler and I needed a driver side drop...the best place for a RC in a Heep is in the rear IMO(flame suit on) since DL angle are usually so steep anyways
-Caleb Call
Supergper is offline   Reply With Quote
Old 01-24-2002, 05:58 PM   #3 (permalink)
Member # 6887
That's what I've been hearing, esp. since I have like a 22" front driveline or some ridiculous length, the angle hopefully won't be THAT bad...
Anybody else?
-J
Old 01-24-2002, 06:38 PM   #4 (permalink)
Member # 940
Roll the pinion up. Weld on a 6* shim and that alone will get it close to a RC60. Or use a a port-a-band and cut out a piece, turn it around and weld it back on.
WWW.PCRYO.COM
Deep Cryogenic Tempering Service
Find all my products at
www.KICKASSOFFROAD.COM
916-434-6978
Custom Axles built to order.
Got 40 spline? I have the hubs, spindles, and axles you need to kickass!
Custom Hummer wheels and centers
Axle Resplining
66CJdean is offline   Reply With Quote
Old 01-24-2002, 06:51 PM   #5 (permalink)
Member # 2095
Just put a Chevy or Dodge in
'79CJ5,soa,d44/60,t18,d18w/Obrian 3.6low,5.13's,35x14.5SSR's
'02 Z71
CJ-Jeeper is offline   Reply With Quote
Old 01-26-2002, 03:12 PM   #6 (permalink)
jp junkie's Avatar
Member # 7921
High pinion keeps the front driveshaft further away from the rocks.
http://trailsport4x4.com
jp junkie is offline   Reply With Quote
Old 01-26-2002, 03:52 PM   #7 (permalink)
TJP
Crazy Diamond
TJP's Avatar
Member # 7595
I never would have guessed that...
The high pinion is stronger but odds are you will never need the added strength.
Like 66CJDean said just tip a LP D60 and go for it.
Great spirits have always encountered violent opposition from mediocre minds.”
-Albert Einstein
TJP is offline   Reply With Quote
