xj poor brakes w/ e350 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-16-2004, 02:50 PM   #1 (permalink)
pissnmetal
StudNuts's Avatar
Member # 12035
Send a message via AIM to StudNuts
I did the 86 e350 on an 88 xj. The pedal goes all the way to the floor.(the brakes were mush before the e350 swap) The mc was bench bled and bled when i bolted it up(ran lines from the output to the resevoir and pumped brakes madly until all air bubbles were gone). The brakes are still mush. When I pump the brakes up w/ engine off, they build up pressure and work fine. When I start the engine, pump the brakes, they just go to mush. There are no leaks in the lines that I can see. I bled the brakes starting from the pass rear.
The only thing i can think of is vaccuum. I pull the booster vaccuum hose, and the engine revs up to 1500 rpm.
Any suggestions.
BlackOut Autosports
Offroad & Performance Fabrication
Click Here For Awesome Metal Fabrication
Equipment From BAILEIGH INDUSTRIAL
StudNuts is offline   Reply With Quote
Old 08-16-2004, 04:27 PM   #2 (permalink)
Myanarchy's Avatar
Member # 14059
Sounds like booster problems. If your sure your getting good vacuum to the booster then its probably bad.
Jeeper89 is a bitch
Myanarchy is offline   Reply With Quote
Old 08-16-2004, 07:07 PM   #3 (permalink)
Member # 11588
A bad booster would be my guess too, just from what I've learned from my system. The single diaphragm booster's in the '88 are weak anyway. That's why I was talking about swapping in a '96 booster. That one's a more boosterific DOUBLE diaphragm model that supposedly has the same length/style pedal rod as an '88.
Never own anything you're not prepared to drill a hole in.
Kilby is offline   Reply With Quote
Old 08-16-2004, 07:15 PM   #4 (permalink)
pissnmetal
StudNuts's Avatar
Member # 12035
joel, we may have to talk a bit more about this. The 88 and the 96 boosters are about the same price. If the rod is the same, may have to upgrade to a double diaphram. Just have to do some research to see if the 86 e350 mc will bolt to the 96 booster.
BlackOut Autosports
Old 08-16-2004, 07:30 PM   #5 (permalink)
Member # 11588
I don't see why it wouldn't... the '96 is s'posed to be a direct swap for the '88. You would probably still have to drill out the flange holes on the master cylinder, though. Gimme a shout whenever.
Old 08-17-2004, 01:27 PM   #6 (permalink)
Member # 13349
my xj does the same thing. i have a e350 m/c , d44/14b. drums in back. when the engine off the pedal gets stiff. when u start it they get mushy.
86 pick up, 3.4, r151f, duals, dirty 30's, six shooters, tbe, hp8", det f/r
71cj5 is offline   Reply With Quote
Old 08-17-2004, 04:14 PM   #7 (permalink)
pissnmetal
StudNuts's Avatar
Member # 12035
just got a zj booster, will report back after its installed....
BlackOut Autosports
Old 08-17-2004, 04:17 PM   #8 (permalink)
Member # 5600
Ditto on my buddys 88 XJ..D60's front and rear with disk brakes....Wilwood Prop valve for the rear..mushy as hell....I've been researching this too..Havnt figured it out yet...This is some help..maybe we will try this route too!
I got two things for sure in this world..My word and my balls..I'm not breaking them for anybody!
Missing my 40...Shoe leather express jones
TLCA Member #13409
AZFJ is offline   Reply With Quote
Old 08-23-2004, 10:28 PM   #9 (permalink)
Member # 13349
anyone come up with anything?
Old 08-24-2004, 11:36 AM   #10 (permalink)
pissnmetal
StudNuts's Avatar
Member # 12035
well, we attempted the 96 xj booster swap. It is deffinitely not bolt in. The pedal rod would have needed to be cut/welded, and new lines run from the prop valve to the mc. Unfortunately, we didnt have time to do all of these mods(the xj is the guys dd) so we just got a new stock booster, put the e350 mc back on and the brakes work fine. They dont lock up 35"s though. Maybe one day with more time, actually do the booster swap.
BlackOut Autosports
Old 08-24-2004, 12:52 PM   #11 (permalink)
Moderator
ashmanjeepXJ's Avatar
Member # 10249
That is how the booster works, you have no boost with the engine off... when the engine is on the booster engauges so the pedal feals softer. if your pedal feals the same with the engine on or off, then you have a booster issue.
I Havent removed the proportioning valve in my e350 MC yet, Ive heard that is the problem. My pedal is stiff, with a new 88 booster and e350MC, with d60 front disks and d70 drums it couldent lock up 37s... I currently modifying to have 1ton calipers at each corner, and will try removing the valve.
ashmanjeepXJ is offline   Reply With Quote
