Cable Shifted T-Cases - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-01-2004, 02:47 PM   #1 (permalink)
nobody20's Avatar
Member # 12393
Cable Shifted T-Cases?
Advanced Adapters (AA) has recently introduced cable controlled shifters for the Atlas. I was interested in adapting this to my D300 so that the shifters would be closer to the driver. The AA engineer says that they aren't readily adaptable.
I was wondering if anyone has designed/built cable shifters for a D300?
79 CJ-5 a bunch of stuff but no chrome, no Bestop, no Genuine Steel and no Steel Horse.
383 LT-4. D60, D44, D300 4:1, SM420, SOA, 4-link w/double shackles, etc.
88 YJ, 350TPI, 700R4, D300 4:1, rear SOA D44 w/Warn floating axles, coil front D44 w/Warn Axles
nobody20 is offline   Reply With Quote
Old 09-01-2004, 04:14 PM   #2 (permalink)
OCM
Member # 14091
I put a d300 in my jeep last year. I am running a hp 44 in the front so I flipped the case. To make the cable shifters work this is what I did: Cut the front of the rail housing just in front of the detents and make a plate to close it off. Shorten the front of the rails. Lengthen the rear of the rails- I drilled and tapped then and added a section to the back. The reason for all this is I wanted the shifter cables to come out the back because there was not much room under the front output (upside down case). I got cables with shifter levers from a local supply place, they are used to activate hydraulic valves. Then I made a mounting bracket for the rear of the case. I also machined the back of the case for seals for the rails. It sounds like a lot of work but it was fairly easy. I think if you had a regular d300 (not flipped) you could modify the original rails and make a bracket to mount the cables. I can email pics if you can post them, they are too big to post here and I suck at computers.
Karl.
OCM is offline   Reply With Quote
Old 09-01-2004, 06:09 PM   #3 (permalink)
Member # 27868
Send a message via AIM to cj8rckcrlr
i'd like to see them....and i'd post them if i was at my computer, but i'm at a friends house till thurs. night....but if nobody else posts them...i'll do it...
-can you buy the cable shifters from AA by themselves?
James
JV Fabrication
256.652.3029
cj8rckcrlr is offline   Reply With Quote
Old 09-02-2004, 08:07 AM   #4 (permalink)
nobody20's Avatar
Member # 12393
James
Yes, the cable shifters are available by themselves. Last week when I talked to AA they had 8 on back order.
Old 09-02-2004, 08:13 AM   #5 (permalink)
Here's Johnny!
frostytj's Avatar
Member # 12867
I want to see them as well. Was thinking about cable shifters for my D300 when I flip it. Send them to d.frost(at)adelphia.net and I will resize and post them.
frostytj is offline   Reply With Quote
Old 09-02-2004, 08:25 AM   #6 (permalink)
chumly2071's Avatar
Member # 8293
Send a message via AIM to chumly2071 Send a message via Yahoo to chumly2071
http://www.teleflexmorse.com/scripts...0_80Series.pdf
lists some different configurations available for the cables.
I'm an Engineer. Why leave it alone, when I can REALLY screw it up?
There is no mechanical problem so difficult that it can't be solved by brute strength and ignorance.
chumly2071 is offline   Reply With Quote
Old 09-02-2004, 08:36 AM   #7 (permalink)
nobody20's Avatar
Member # 12393
I was thinking about using Morse cables. They are a quality product and I have had real good luck with them in shipboard applications. Thanks for the link.
Old 09-02-2004, 09:25 AM   #8 (permalink)
Keith Strong's Avatar
Member # 477
Send a message via Yahoo to Keith Strong
This idea interests me greatly.......if you do it how about a write up?
[CENTER][SIZE="5"][URL="http://www.strong-arms.com"]Strong Arms "Survival Slings" For Sale PM me for a PBB only price[/URL]
[/SIZE][/CENTER]
Keith Strong is offline   Reply With Quote
Old 09-02-2004, 12:37 PM   #9 (permalink)
Evil Twin
yager's Avatar
Member # 10695
Send a message via AIM to yager
was brought up (not much discussion) here.... http://www.pirate4x4.com/forum/showt...=cable+shifter
and again in some toyota van thread but with no actual tech.
I have some pics of a cable shifed t-case i snaged from a thread few months ago. I was unable to locate that thread now, but ill re-post those pics later at home.. (not sure if anyone else has them, they were from over seas and very fuzzy w/ poor lighting... but still worth posting)
-mike
yager is offline   Reply With Quote
Old 09-02-2004, 03:45 PM   #10 (permalink)
OCM
Member # 14091
Nobody20 you have mail.
Old 09-02-2004, 08:08 PM   #11 (permalink)
Evil Twin
yager's Avatar
Member # 10695
ok, here are the cable pics i scraped off an older thread, lost that thread.
disclaimer: There are NOT MY PICS...
Old 09-02-2004, 11:57 PM   #12 (permalink)
Member # 27868
how much do that AA shifters cost? anyone know....
JV Fabrication
256.652.3029
Old 09-03-2004, 11:07 AM   #13 (permalink)
Here's Johnny!
frostytj's Avatar
Member # 12867
$200, part # 303009.
Old 09-03-2004, 02:55 PM   #14 (permalink)
B.A.R.K's Avatar
Member # 8540
DAM, thats cheeper than a flip kit and twinsticks.
92YJ/2.5L/HD4:1D300/F&R D44/5:38/36 SX/99"WB
Nothing is stronger than stupid...
B.A.R.K is offline   Reply With Quote
Old 09-03-2004, 05:16 PM   #15 (permalink)
Member # 27868
yea, thats not bad attall...plus they're universal as hell
JV Fabrication
256.652.3029
Old 09-04-2004, 05:39 PM   #16 (permalink)
Got .45?
Chrisjeep7's Avatar
Member # 9274
btt, i want to know more about this. so who is going to be the guinnee pig and buy one of these and see if it will work?
94 YJ w/ 5.3L, TH400, Atlas, and 42" Pitbull Rockers
Chrisjeep7 is offline   Reply With Quote
Old 10-09-2004, 01:12 PM   #17 (permalink)
Member # 22819
revisiting this thread....anyone taken the plunge on the Atlas cable shifters for a D300?
thanks,
Jay
87 Sami
DD Chevy....
jlake1 is offline   Reply With Quote
