aod + clocking ring? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-06-2004, 10:32 PM   #1 (permalink)
norcaljeeper's Avatar
Member # 13124
ok i am sure it has been covered butt this is 1 very specific question. and the search doesnt respond well to aod.
the setup cj7 5.0 aod d300 axles stock. will be going to lp44/9" soon
just gott the tranny in and as it looks i have 2 options as far as front driveshaft clearance issues
1 notch the pan
prob w option 1 is i will gain the clearance needed...? hopefully
2 clock the t-case
prob w option 2 is the conversion is smog legal and it does not look like there will be room for the cats if i clock it.already went to 2 cats instead of 4
also i know a clocking ring only adds about an inch butt rear d-shaft already is very short.
or will it solve the problem if i go with a hp44?
so basically if you have this setup or built one what did you do?
[QUOTE]Also remeber you can't make fun of a guy at Wallmart cause the fact is, you were there to.[/QUOTE] originally posted by oh three
norcaljeeper is offline   Reply With Quote
Old 09-07-2004, 05:51 AM   #2 (permalink)
Go2Guy's Avatar
Member # 12158
Shortening a rear DS 5/16" should be a non issue. Have you considered a two piece drive shaft for the front? Only you can determine your needs for what'll fit. Can you relocate the cat? You can pull the 6 bolts holding the 300 on, with t-case still resting in place, clock it with a jack/jackstands and see what things look like. If you order a ring, ultimatlely it can be returned less shipping charges if it does not work out.
Good luck,
Ken
Ken Blume
Rock Rod Racing
Team #192/4192
Thanks to our partners
Maxxis, Trail-Gear, Yukon Gear, Goatbuilt, Tom Woods Custom Driveshafts, Ruffstuff specialties, Warn Winch, Rokit Enterprises, Viair, Edge Perf., Branik Motorsports, PRP seats, 12V unlimited, Bailie built, Baertrax, Raceline
Go2Guy is offline   Reply With Quote
Old 09-07-2004, 06:22 AM   #3 (permalink)
Member # 1636
Run single exhaust with the cat on the passengers side, then clock the t-case with go2guy's ring.
problem solved
[url]http://www.pirate4x4.com/forum/misc-stuff-sale/1192938.html[/url]
chris demartini is online now   Reply With Quote
Old 09-07-2004, 10:11 AM   #4 (permalink)
Member # 13124
yeah i know shortening the shaft for the clocking ring should be a non issue butt... and as far as running single exhaust i cant the smog nazis wont let me. and i know i can/could /should figure it out for myself butt my heep is 100+ miles away and i am looking for solutions that others may have done.what worked for you?
