Locking a Turd - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-08-2004, 11:07 AM   #1 (permalink)
Hvy_Chevy's Avatar
Member # 14094
Send a message via AIM to Hvy_Chevy
Locking a Turd
Looking at buying a used EZ-Lock for a D35.
When looking at TracTech's application chart, they mention a hub diameter. Does anyone know what this is? Noted as being 1.558in or 1.616in
My ride is a 93 ZJ, donor is a TJ
Hvy_Chevy is offline   Reply With Quote
Old 09-08-2004, 01:18 PM   #2 (permalink)
Member # 25999
Send a message via AIM to CanuckJeeper Send a message via Yahoo to CanuckJeeper
There was switchover on the YJ's on model year '94. They went to a smaller "hub" (it's really the side gears inside the diff) in '94. 94+ YJ's and all TJ's (as far as I know) have the smaller "hub". So I don't really have a good answer since you have a ZJ, but I'd tend to believe that the size would be the same as the YJ's of that era.
Why waste $$$ on a D35? If you want a cheap fix, weld the thing and run it 'til she breaks, and upgrade to a more serious axle.
JP
CanuckJeeper is offline   Reply With Quote
Old 09-08-2004, 02:57 PM   #3 (permalink)
Hvy_Chevy's Avatar
Member # 14094
$50 asking price for EZ-Lock
might be a while before I can throw 200-300 for a whole axle
Old 09-08-2004, 03:16 PM   #4 (permalink)
Member # 8713
Get lots of shafts. You'll need them.
Been on a couple missions into Maine to save poor locked d35 folk.
I have 2 sets but want $$ for them.
FiWi
preach is offline   Reply With Quote
Old 09-08-2004, 03:17 PM   #5 (permalink)
Member # 20592
Send a message via AIM to gumbojeepyj Send a message via Yahoo to gumbojeepyj
i welded mine... just in between the teeth, definately dont do that. it put too much stress on the cross pin and it exploded my carrier!
i did it jsut between the teeth so the would bind and i could take them out if i didnt like it. well i liked them but they didnt like me. never lost a shaft though.
learn from me. leave the damn d35 stock till you can replace it.
Blake
http://www.lockitupoffroad.net
gumbojeepyj is offline   Reply With Quote
Old 09-08-2004, 07:26 PM   #6 (permalink)
Member # 3587
Send a message via AIM to Recurve
Some of the innards(carrier and side gears) of the D35 changed with the advent of ABS. Sometime in 93 they started making D35's with the ABS innards irregardless of whether or not the Jeep was equipped with ABS. 94 and up all had the ABS capable innards and some 93 6 cylinders had the ABS innards. If you have the axle BOM you can call Tractech and they can tell you if the locker out of the TJ will work. If your ZJ has ABS then it will work.
Recurve is offline   Reply With Quote
Old 09-08-2004, 07:44 PM   #7 (permalink)
Bending light
BlueAngel's Avatar
Member # 24300
Just to add that when buying a lunch box locker for a TJ D35, you have to know if the carrier is a traclok or not. The lunch box lockers are different for each carrier type.
Project - Destroyer
BlueAngel is offline   Reply With Quote
Old 09-08-2004, 07:53 PM   #8 (permalink)
El Guapo
TexasBlake's Avatar
Member # 9722
The funny thing is..... Randy's calls that a "Super 35" (not the 30spline stuff) A coworker had to buy some ring and pinions for a shop doing a job on a Grand Cherokee, and it ended up having that.
Originally Posted by spork2367 View Post
I'm done with this site. Everyone is angry at the world. And they don't even know why.
TexasBlake is offline   Reply With Quote
Old 09-08-2004, 08:21 PM   #9 (permalink)
Corn_Smuggler's Avatar
Member # 28766
That $50 is going to get you to the $200-300 level *a lot* faster, especially if you're on the rocks. Don't press the gas and you should be fine.
-Dan ('63 Willys CJ5)
Corn_Smuggler is offline   Reply With Quote
Old 09-08-2004, 08:27 PM   #10 (permalink)
Member # 9516
even better yet stand on the brake pedal
mulescj8 is offline   Reply With Quote
Old 09-08-2004, 08:33 PM   #11 (permalink)
BEAR's Avatar
Member # 1746
I ran a D35 with a EZ-locker and it went on about 4 rubicon trips untill the locker broke, after that I welded the rear spiders into a ball and it worked fine for about 6 mo untill the welded spiders blew apart (no pre-post heat...Oops) and then I put in plain old spiders back in.
I never broke a shaft on the 35 though, even pulling a trailer through the con both ways.
I think the EZ-lockers are shit, I went through 3 front ones and one rear in a few months on my 30/35 with lil 33's.
If its only $50 id run it till something breaks though
Still Politically Uncorrect
BEAR is offline   Reply With Quote
Old 09-08-2004, 09:40 PM   #12 (permalink)
HeiserOilMotorsports
Member # 1515
Send a message via AIM to Po' riggity Send a message via Yahoo to Po' riggity
for 50 bucks, Id lock it up.. if you think upgrading to a stronger rear axle for 2-300 is going to happen.. you gotta live in a dream land.. I swung an 8.8 under mine for about 400 bucks when it was all said and done, and I got the actual axle, wiht 4.56 gears and a trac loc for free, so I haven't even put a locker in yet...
Scott
Black Star Status!
Po' riggity is offline   Reply With Quote
Old 09-08-2004, 10:52 PM   #13 (permalink)
Hvy_Chevy's Avatar
Member # 14094
I can do an 8.8 for 2-300 hundred... I can build and weld all the brackets, cut the shaft so it works. Just have to buy some brake bits.
Just have to find the right 8.8
Old 09-09-2004, 01:20 PM   #14 (permalink)
Member # 25999
That's 50$ that won't go into the new axle... not to mention axle shafts that you're likely to break
JP
Old 09-09-2004, 07:57 PM   #15 (permalink)
ZJim's Avatar
Member # 24099
Send a message via AIM to ZJim
Heh, I'd say it's more than likely.. it's basically GOING to happen...
ZJim is offline   Reply With Quote
Old 09-09-2004, 08:21 PM   #16 (permalink)
Member # 35042
Like others have said, keep the dana 35 open and spend that $50 on the ford 8.8 and weld the axle tubes to the diff so it doesn't spin. The dana 35 will not hold up long with 33's and a locker. At least get some spare shafts for next to nothing if you don't want to get the ford 8.8 or xj dana 44.
bigredjeep1 is offline   Reply With Quote
