Member # 31695
5.0 swap questions
Sorry if this needs to be moved to newbie section. But, the more I search, the more confused I get about my 1st question.
I have a '93 mustang 5.0, an '86 F-250 4wd T-18, and a BH from a '85 F-150 w/ hyd clutch. 1. Flywheel? I know I need the 11" truck flywheel, but why do some guys recommend one from a 300 I6 ? What is the difference? And so after I get the flywheel, I have to take the mustang flywheel AND the truck flywheel to have it match balanced somewhere? Anyone know a shop near San Jose that can do this? 2. I was going to use the clutch slave that fits the bracket that came with my '85 BH, will the Jeep 4cyl stock master cyl work with the Ford slave? 3. I couldn't find the serp belt PS bracket for a saginaw pump, has anyone made a V-belt style one work? It looks close... |
Member # 17149
Probably need to post here.
http://www.pirate4x4.com/forum/showt...highlight=totw
90 YJ |
Member # 20092
One quick tip, but then go to the TOTW thread on 5.0 swaps.
Find an '87 ford E150 van with a 5.0 liter motor and swipe the serpentine belt set up from it. It is identical to the '86-'93 mustang belt set up but uses the saginaw ps pump. Bolt on swap and you can reuse your stock jeep pump. Just swap them out and install the ford ps pulley on your jeep pump.
'94 Toyota Land Cruiser FJZ80 - Vortec L33 5.3l, 4L60e, elocked, 3" OME lift, 315 KM2s, Warn 8074. |
#4 (permalink) | |
Member # 3013
As for the clutch, I couldn't see the stock YJ clutch master working with the Ford slave so I swapped in the Ford master. Be warned though, It's a pain to do, and opens up clearance issues with the brake booster. If you have a TJ, then I've heard of guys using a CJ slave with that. I swapped in an NP435 transmission behind mine, I used all 87 Ford F-150, bellhousing, clutch, T/O bearing, fork, slave bracket and slave. I used the 164 tooth 50 oz. imbalance flywheel, P/N E8TR-AA A tip if you plan to run headers, use 87 Ford F series truck. Hooker makes a set.
"Instead of being a trail guide, you should put on a clown suit and give pony rides at kids' birthday parties" 94 YJ. 5.0 HO, NP435, NP-203 W/3.2:1/NP-205 WMS doubler, Bilstein/Alcan suspension, 104" WB. 60's front and rear. |
#5 (permalink) | |
Member # 20092
On the other hand, the belt that was called for in my application (van) was too short. I ended up having to measure the length with some string to get the right belt. Odd.
