Member # 24749
what to check for on rolled yj
I may be buying a Yj that has been tossed once, it rolled twice, and is completely stock. Besides the usual frame and body stuff, is there anything specific to look for that would be a sign not to buy, like things that usually crack or bend?
eventually it will be built, but still an on road vehicle as well.
[COLOR="Blue"][FONT="Fixedsys"][/FONT]New YJ 2"BL NO RUBBER AND A BIG WINCH[/COLOR] [COLOR=SlateGray][FONT=Impact]Old Toy 33's 4" FRONT, RAISED SHOCK MOUNTS, CHEVIES WITH DOUBLE SHACKLE, LEAKS LIKE HELL[/FONT][/COLOR] [COLOR=Red] |
Member # 33341
What year is it? Stay away from the year that has the Peugot tranny and 207 case. This is how I got my jeep, rolled in the junkyard.
[B]"It's like a swore peeder, you can't beat it!"[/B] '90 YJ, TBI 350, SM-465, hi609, Ford 9" 5.13, and 36SX's |
Member # 24749
it's a 90 6cyl, does that have the shitty tranny? (5spd)
Member # 24749
you should post a pic of yours for me, you sig looks like it would be huge.
Member # 33341
I have a '90 also. It had the AX-15 tranny and 231. The only thing that I wish it had stock was fuel injection. That was the main reason for going to the 350, and the 465 was all about gearing. Anyways, I am at work and all my pictures are at home. I will try to see if I can find any on the internet.
Member # 33341
If you go to midwestcrawler.com then pics, page two, album is called Jake. It is the blue YJ with the black hardtop. That was before I extended the wheelbase and the engine swap.
Member # 26440
That is how I got my YJ. Some kid rolled it down an embankment and ripped the winsheild and rear shock mounts off. He thought it was totaled and was about 5 sec from calling the junk yard. I did not even know him but I just overheard the conversation between him and someone I worked with. I told the kid I'd take it. He drove it over to my house the next day on 3 flat tires. I have been wheeling it since then. I had an offer of $2500 for it a couple weks after I got it. The only major problem is the windsheild cowel is pushed forward about 1" so it does not fit a hard top and soft tops don't work real well either. I'd say check the windsheild cowel for alignment if you are going to want any type of top other than a bkini.
Member # 24749
yeah the top doesn't fit real good, so it may be just that,
I thought that it would be just the windshield frame bent back about an 1", will have to take a closer look.
Member # 24749
crawlthis, it looks like you have stock steering, if it is how much lift is okay with stock steering? I have no idea about jeeps. Also if i spring over the front would it need steering mods?
Member # 33341
Well I have recently redone the steering to high-steer. In the picture I was running the tierod and draglink off of a '97 ZJ. If you just get rid of the front panhard bar and get a dropped pitman arm (stock ZJ pitman arm is what I used) you should be okay.
Member # 33341
I have close to 7" of lift in those pictures and never had a problem with steering with the panhard bar removed. It is sping over with 1.5" rubicon SOA springs.
#13 (permalink) |
Member # 24749
yeah, it runs and drive great, it was a high speed roll, flipped twice and barely touched the ground, landed on it's wheels. It sort rotated on the front clip.
#14 (permalink) |
Member # 9994
check the transfer-case for cracks or obvious fluid leaks. they seem to be the first to break.
the frame and body can be straightened fairly reasonably on a frame rack. fix it good enough to wheel it...and don't worry about it!
1984 CJ-8 1986 CJ-7 1981/1992 CJYJ 1994 RAM 1500 4x4 Custom Fabrication Parts: [url]www.troutindustries.com[/url] |
#15 (permalink) |
Member # 9991
I went over four times at least (Can't remember, head was beating against the cage). It starting tearing the spring shackles out of the frame. I'd look closely at these. Also, I now know why people bolt the cage to the frame. I bent one axle aswell. Look close at the suspension cuz it pounds as it comes around. Good luck
Oh yeah, couldn't you just buy a used frame cheaper than you could straighten that one if it's bent?
[url]www.scotthansen.net[/url] |
