Spidertrax 60 knuckles? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-10-2004, 08:19 AM   #1 (permalink)
Member # 36557
Send a message via AIM to BBBTruck
I was taking a look at some of Spidertrax's products and I noticed they developed a knuckle for the D60 that is supposedly stronger and lighter. From the picture it appears to be balljointed. Anyone know anything further about these?
Just another dude drivin' around in the woods.
BBBTruck is offline   Reply With Quote
Old 10-11-2004, 10:06 AM   #2 (permalink)
Member # 5326
They are a plate style construction knuckle that uses a unit-bearing 5 or 6 lug outer. I think stock is 33 spline and they can do 35 spline. They use willwood calipers, not sure about the rotors. No hubs.
The upper and lower joints are not a true ball joint, they are a ball and socket system so you can take them apart VERY easy.
Mainly its a very small and light knuckle that keeps strength of the D60 u-joint and 35 spline inner axles. They are saying that a complete 9" 35spline unit knuckle to knuckle is lighter than a traditional d44.
I don't know if they where suppose to go on a daily driver, but it is a very cool concept. There are a few other companies working on similar products. Some with CV joints, some with u-joints.
Mieser is offline   Reply With Quote
Old 10-11-2004, 10:30 AM   #3 (permalink)
Member # 7876
Send a message via AIM to Arya Ebrahimi
I forsee someone using these with a D44 housing and a 35-spline ARB to make a lightweight beefy axle. With enough crawl ratio in the T-case you could run 4.10 or 4.56s gears to retain R&P strength as well.
Info here: http://www.spidertrax.com/chassis.htm
DD/Tow-rig: '06 GMC Sierra 2500HD Duramax
Classic Rig: '88 FJ62, 100% stock
In the weeds waiting for resurrection: '94 FZJ80, 33s, locked
Arya Ebrahimi is offline   Reply With Quote
Old 10-11-2004, 10:38 AM   #4 (permalink)
Member # 24009
I haven't seen the knuckle. But there local for me, crazy sick stuff, crazy sick shop. Very professional. I buy stuff from em all the time.
I never went soooo fast, then I fell off...
ghettojeep is offline   Reply With Quote
Old 11-04-2004, 06:47 PM   #5 (permalink)
spidertrax33333's Avatar
Member # 37484
Hey guys, Jeff form spidertrax here... Cool to see some intrest in the knuckles... They use a dodge unibearing (33 spline)outers with willwoodbrakes and rotors... No ball joints, just a 3/4 or 5/8 bolt with an auroa bearing. Its a very simple product.
Life's a bitch, wear a helmet....
spidertrax33333 is offline   Reply With Quote
Old 11-05-2004, 03:09 PM   #6 (permalink)
Moderator
apeters89's Avatar
Member # 7647
I was up skiing in Estes Park last winter and decided to stop buy their shop. They toiok the time to give me a tour of their facilities even though they had a bit of work in the shop, AND they were in the middle of moving their shop to a different location.
Very nice guys and thry had some pretty cool looking stuff in their shop!
Check out our new Team Ape Eater Racing Like us on FaceBook
KF5EQF
Sniper Fab
4x4Oil SBwinVPS Custom Splice C2GFab
apeters89 is offline   Reply With Quote
Old 11-05-2004, 08:12 PM   #7 (permalink)
Member # 14731
Do you have any pics? This sounds pretty cool.
Road Head is offline   Reply With Quote
