Dana 300 In A '84 Gw Who Has Done This? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-01-2002, 02:59 PM   #1 (permalink)
Member # 9681
Just finished rebuilding a D 300 with Currie Twinsticks and an axle from a '79 GW.
Plan on droping this into the '84 GW after the SOA is done.
Has anybody done this?
WINGO is offline   Reply With Quote
Old 02-01-2002, 04:06 PM   #2 (permalink)
Member # 6234
should work. if you've got an SOA, you'll probly have enough lift to clear a 1.5" front shaft. if you don't have enough lift you will bang the hell outta the shaft against the tf727 case.
it's a bolt on case for a waggy 727
85 W150, 94 YJ, 86 Bronco
WillyPete is offline   Reply With Quote
