what trans for my jeep? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-28-2004, 11:45 AM   #1 (permalink)
Got .45?
Chrisjeep7's Avatar
Member # 9274
well i have a 4.0 in my TJ and just exploded my trans (i ran a 176 just cuz i had it laying around and my ax-15 was dead)
i am looking at swaping in a cheap strong tranny
#1 it dont have to be a OD tranny
#2 manual or auto dont matter i like them both
#3 cheap
#4 has to be able to mate to a dana 300...fairly cheaply.
i was thinking np435 with the novac (or aa) adapter but
just wondering if anyone would swap in somthing else...
94 YJ w/ 5.3L, TH400, Atlas, and 42" Pitbull Rockers
Chrisjeep7 is offline   Reply With Quote
Old 10-28-2004, 12:03 PM   #2 (permalink)
Low Range Drifter
JohnnyJ's Avatar
Member # 7903
Wow, what are you doing to blow up trannies?
I've had good luck so far with my nv3550, how would that compare in price to a np435 after buying an adapter? Also, what about the CPS?
I guess with used parts, price will always come down to who you know or if you stumble on a good deal.
DEAK Racing #715 TREC B / Ultra 4 Mod Class Rig
Thanks to Drivetrain Specialists and PAC Racing Springs for your support
JohnnyJ is online now   Reply With Quote
Old 10-28-2004, 12:06 PM   #3 (permalink)
Member # 35194
i have blown 2 nv3550's i wouldn't recommend running one. if you are going to run used why not just get the 4500 then?
Matt_Pumphrey is offline   Reply With Quote
Old 10-28-2004, 12:20 PM   #4 (permalink)
Got .45?
Chrisjeep7's Avatar
Member # 9274
cps no big deal, just learn how to fabricate. Nv3500 = maybe nv4500 = nope
Old 10-28-2004, 12:32 PM   #5 (permalink)
Member # 24475
Send a message via ICQ to JeffsJeep04 Send a message via AIM to JeffsJeep04
What are you guys doing to gernade multiple trannies? Maybe it's just me, but if you are blowing new trannies, you need to learn how to drive. Auto's, change your gearing, but with a stick..dayum.
2000 WJ Limited 4.7 quadradrive
JeffsJeep04 is offline   Reply With Quote
Old 10-28-2004, 01:09 PM   #6 (permalink)
Got .45?
Chrisjeep7's Avatar
Member # 9274
mmm my ax-15 had 175,000 on it. the USED t-176 had god knows how many miles on it. i blew my t-176 up by backing up, not even that hard.
what does a nv3500 go for?
Old 10-29-2004, 02:42 AM   #7 (permalink)
Robert's Avatar
Member # 1050
Send a message via Yahoo to Robert
I run a T98 behind my 4.0L.
6.6:1 first gear is nice in the rocks. AA makes a bell housing to run these and the other T series granny trannies (T18/19/98). Depending on what you get, there maybe input shaft changes though.
If you don't want to buy the AA bell (I don't blame you one bit either), CJ bellhousings will work. Just require some reworking for your CPS.
Later model CJ with AMC V8 or I6, T5 or similar tranny, slave cylinder from a 81 CJ5 with the Iron Duke GM four cylinder (2.5L), GM 10" clutch disc, your current flywheel and pressure plate. The only bitch with this swap is I always have to have a pilot bushing cut for me. Just find something with the right inner diameter, then have a machine shop trim down the outer diameter to fit.
Parts Mike carries new new aftermarket CJ bellhousings, and all the slave cylinder junk you will need, for less than AA wants.
Ask me anything about a Cummins, I stayed at a Holiday Inn last night.
Robert is offline   Reply With Quote
Old 10-29-2004, 04:43 AM   #8 (permalink)
Member # 16838
How about an AW4? It meets all of your criteria: cheap, auto w/ od, easily mated to a D300, and actually a tough trans. If you decide to use one you can even bypass using the TCU with one of these - /forum/jeep-hardcore-tech/242965-new-auto-tranny-option-jeeps.html and here - http://awshifting.bravehost.com/
Just an idea. I use the AW4 shifter and love it. It makes swapping trans easy and gives you the ability of picking what gear you want to be in. This is great for compression breaking and may trail situations that a manual could leave you wishing you had a third foot. Good luck, Judd
79 cj 7, lift, 360, and 33's for now... yeah hardcore...
Judd is offline   Reply With Quote
Old 10-29-2004, 08:20 AM   #9 (permalink)
Got .45?
Chrisjeep7's Avatar
Member # 9274
yeah the aw4 is a good tranny but if i go auto i want it to be auto, as in i dont what to shift it all the time.
Old 10-29-2004, 10:42 AM   #10 (permalink)
Member # 16838
Just throwing out ideas, doesn't mean ya have to like it
Good luck, what trans are you thinking of running? Judd
Old 10-29-2004, 01:37 PM   #11 (permalink)
Member # 31804
how about an sm465? aa sales adapters and its I think 6.55 first gear but then you need an adapter for the d300.
FatMeats12 is offline   Reply With Quote
Old 10-29-2004, 02:17 PM   #12 (permalink)
Got .45?
Chrisjeep7's Avatar
Member # 9274
thats 2 adapters compared to 1 for most trannys....
i was not shooting you down i was just saying judd. i am thinking np435, 999, nv3550...
Old 10-29-2004, 03:37 PM   #13 (permalink)
Myanarchy's Avatar
Member # 14059
What about a 727. Strong, readily available, and shouldn't be hard for the 300.
Also what about the 999?
Jeeper89 is a bitch
Myanarchy is offline   Reply With Quote
Old 10-30-2004, 03:11 PM   #14 (permalink)
Member # 20754
NP-435 and T-18 are both strong, Cheap, well geared and can be bolted to the 4.0 with minimal fab work, Adapters are available for the 300, or you can fab your own NP-435 - EBD20 adapter fairly easily.
'99 F-250 PSD and a pile O' Parts that will some day be a Jeep again
Tall Grille is offline   Reply With Quote
Old 10-31-2004, 07:28 AM   #15 (permalink)
mdoffroad's Avatar
Member # 23103
Send a message via AIM to mdoffroad Send a message via Yahoo to mdoffroad
Havent killed THIS AW4 yet, last one wasnt happy thoguh
Mäττ
01 White WJ 4.0/242, STOCK for a few days
mdoffroad is offline   Reply With Quote
Old 10-31-2004, 07:08 PM   #16 (permalink)
Member # 34981
Semi-Hijack - You didn't by chance use the AX-15 hydro clutch actuator for the T-176 did ya? If so, what was involved in maiking it work? I'm gonna swap a T-176 for an AX-15 this week and would like to keep the hydro clutch if possible.
Thanx.
Wagoneer, 4cyl Crosley (magnesium block) with 2 turbos ( from FWD Mopars) Allison 4 speed auto (from an old bus, it has a PTO port for my winch that's why) Dana 300 twin-stick, D60/10.25" Sterling 6:54's spring over with 6" lift springs 42" Swampers and a big-ass winch off an old military truck
BannedWagoneer is offline   Reply With Quote
Old 10-31-2004, 07:40 PM   #17 (permalink)
Member # 10586
I'd go for the 999. 300 bolts right up & plentiful in yards. I run an 86 CJ one..no probs with it, light and takes abuse.
Canadian 4 Wheeling ~[URL=http://www.universityofjeep.ca]University of Jeep[/URL]~
Rebel GP is offline   Reply With Quote
Old 10-31-2004, 11:09 PM   #18 (permalink)
Got .45?
Chrisjeep7's Avatar
Member # 9274
i used the hydo slave and the stock fork and just fabbed a braket to make it work, it was easy
Old 11-01-2004, 05:29 AM   #19 (permalink)
YJ4RoX's Avatar
Member # 1930
go for the np435, cheap strong and short, nice tranny's.
YJ4RoX is online now   Reply With Quote
Old 11-01-2004, 06:22 AM   #20 (permalink)
sceep's Avatar
Member # 10798
Send a message via AIM to sceep Send a message via MSN to sceep
if you have the room for an OD slushbox, I've been more than impressed with my 46rh.
Should bolt right into your 4.0/300 with no adapters.
Originally Posted by USDA forest service website
It is every American's birthright to use the national forests and grasslands in multiple ways, including outdoor recreation in all its forms.
sceep is online now   Reply With Quote
Old 11-01-2004, 06:45 AM   #21 (permalink)
Member # 845
Can you give us more details about how you blew 2 nv3550s up?
CJ Lagos is offline   Reply With Quote
Old 11-01-2004, 11:43 AM   #22 (permalink)
Got .45?
Chrisjeep7's Avatar
Member # 9274
sceep, is that compy controled? what year grands are thoes out of?
