Member # 34493
79 pontiac mc vs 68 corvette mc ???
I've searched & read all day on brake issues until my head hurt & I've determined one of these 2 master cylinders is what i need.
current set up. 85 cj7, dana 44 with wagoneer calipers & rear dana 60 with 85' caddy calipers with parking brake (tsm). stock mc currently & stock proportioning valve. power brakes. (originally disc front/drum year) I have excellent front brakes & hardly any rear braking. I didnt realize it until i broke my brand new stainless line on top of a mountain on the very 1st trail ride since my build up & then couldnt stop it until i drove it into a bank & slammed it into park while still moving some what. Pedal is soft & goes almost to the floor. it stops pretty good on the street & almost locks up the front sometimes. But its only the front that is stopping it & on the trail going backwards, it sucks!!!! I've bled & bled & bled, them. (no pressure bleeding yet though) I have even manually rachetted the caddy brakes to make sure they are adjusted. I'm not sure what the main difference is between the pontiac & vette MC. they both appear to be 1 1/8" diameter, is the stroke different? will one bolt up better than the other? any suggestions one way or the other are appreciated. thanks, |
Christian hater arg!
Member # 29527
Eliminate the stock prop valve and put in an adjustable, then try it. If your rears aren't working, it's not likely the M/C (unless it's broke), I have a stock drum/drum MC, 4-wheel discs with Monte Carlo front calipers in the rear (which are bigger than your e-brake calipers) and the rears are working juuuust fine, even though the pedal is soft.
Member # 13889
When I was looking at master cylinders, the difference I noted was that the Pontiac had a shallow hole to accept the rod from the power booster, while the vette MC had a deeper hole in its cylinder. The vette one wouldn't work for me for that reason. The bore was the same between the two.
CJ7, 1 tons, 5.7l, hummers, IROK's etc., etc. |
#5 (permalink) | |
Member # 25199
Member # 34493
I just did finally screw with the prop valve again. the 1st time i think i tried the wrong part of it & took the o-ring of the metering valve side of it. The CJ combination valve appears to be different than all the YJ postings on this web site. Or i just read them to late at night & didnt remember it right.
I put the 79 transam/firebird (i think are the same??) on it after this & then also pulled the o-ring from some plunger on the opposite site where the check valve feeds the rear lines & then tried it again & now I can get the rear tires to finally stop on jack stands in 4 low. still have to press pretty hard though. i have one bad break line so i had to order a new flex line & wont get it all back together until next week & then i can re-bleed the system. I might put the jeep MC back on just to see which thing actually fixed it. but need to do a street lock up before i'm satisfied. Last edited by billdorn; 11-23-2004 at 09:46 PM. |
Member # 1750
I left my prop valve in and used a 1979 T/A master cylinder. It works great..My jeep is a 1979 CJ with D60's front and rear..
Ricky...seeya...
401 LJ the " RUBINCON " |
#12 (permalink) |
I have almost the same setup in MY CJ. I tried the firebird but ended up with the corvette. I don't think the MC was the problem at that point though. The corvette had more equal size reservoirs than the firebird, which I like. I ended up with the corvette MC, adjustable prop valve to the rear and it still would not stop. I took off the CJ booster and built an adapter for a bigger wagoneer booster. Fired it up, taped the brakes and slid sidewayse in the road. Either the stock booster was too small or it was shot. Works good now though.
#13 (permalink) |
Member # 29527
I just swapped in a mid-70's chev 3/4 ton M/C. PERFECT! It's a direct bolt in on a CJ. This M/C has a 1.25" bore, compared to the Corvette M/C's 1.125" bore, and the stock CJ's 1" bore. The pedal is hard as a rock and this sucker stops like a dream. Did I say direct bolt in? Almost, except the front circuit is at the rear of the M/C, no big deal.
