Member # 6748
Some 4 link and 9" ford pics......
Here are a few pics of the 9” ford rear end, triangulated 4 link and shock relocation that we fabbed up on my TJ this past week. It’s done except brake lines and rerouting the exhaust. The axle has a strange nodular 3rd, 4.88’s, full spool, 35 spline Moser shafts and 11.5” discs. The arms are RE superflex lower TJ control arms that have been lengthened and sleeved with 2”OD X ¼” wall DOM tubing. The drive shaft is the front TJ shaft that we shortened and used a jump joint to the 1350 on the axle. All the brackets including the shock towers are ¼” plate TIG welded. The driveshaft only slides ¼” along the entire travel of the suspension. The pinion angle barely changes throughout the travel. The brackets are all above the bottom of the axle housing. Here are a few pics. Still deciding on what to do for the front axle. It’s either a HP44 or a 60/9 hybrid. Dave
#4 (permalink) | |
Member # 6748
Member # 62
how much did the third and related hardware (pinion support/bearings) cost you? I'm thinking of building a 35 spline 9" in the future.
Looks good.. I'm sure someone will post up telling to to add more braces to the upper axle side link mounts but I bet they will hold up.
Jeff Neves |
Doublewide engineer
Member # 6971
Planning on making another couple passes over all the tabs with the welder when its all set? Bit too much undercutting on a few of them.
Turning out pretty cool, good job on all the angles.
I'm the "tack tack tack" welding nazi. http://www.pirate4x4.com/forum/showp...&postcount=218 ![]() "I didn't mean to kill nobody ... I just meant to shoot the sonofabitch in the head. Him dying was between him and the Lord." R. L. Burnside |
#9 (permalink) | |
Member # 6748
The brakes are ford rotors, chevy calipers and flat stock 1/4" brackets. I'll use a wilwood adjustable proportioning valve. Dave |
#10 (permalink) | |
Member # 6748
#12 (permalink) |
Member # 1172
Got one pretty similar to that sittin in the garage. Really like the way it works offroad. My upper arms were mounted the exact same as yours. Never had any problems in a year and a half of wheelin. Recently added gussets to the mounts just in case..
98 TJ Buggy /forum/jeep-hardcore-tech/647639-axle-suspension-redo-3-link-4link-tru-hi-9-a.html http://www.jak4x4.com 1st place Dirt Riot Coppermines Race Mod Trail class. |
